- Nov 30, 2021
- 29 (0.03/day)
- Canada
System Name | Lenovo S30 ThinkStation / FTW |
Processor | Xeon E5-2690v2 3Ghz Boost 3.6Ghz (10c 20t) / i9 10980xe |
Motherboard | Lenovo X79 Chipset C602 / EVGA X299 FTW k |
Cooling | OEM / CoolerMaster Hyper 212 Black Ed |
Memory | 32 GB ECC (8x4GB) / 32 GB Corsair Vengeance 3600MHz |
Video Card(s) | Nvidia Quadro K4000 / EVGA GTX1080 SC |
Storage | Samsung Evo860 500GB Disk, 2x WD 1TB SSD / 2x nvme m.2 SSD 1TB |
Display(s) | Lenovo 24" ThinkVision FHD / MSI 27" QHD |
Case | OEM Tower / Phanteks |
Power Supply | Lenovo 80PlusGold 610W / EVGA SuperNova1000W |
Software | Win10 Pro |
Benchmark Scores | CINEBENCH R20 3205 / R20 8690 (no overclock) |
Here's my take from an owner of a Broadwell-E system i7-6950X, I'd buy a 6950X (again) and overclock the hell out of it. Hopefully you have a good X99 motherboard with the latest Bios to do so, install a Noctua NH D15S CPU air-cooler, and an NVME 512GB boot drive. With turbo boost you should be able to overclock (to the extreme) select individual cores (from within your bios settings) up to 4 cores of the 10 cores available, I think. Some newer 4 X 8GB sticks DDR4 3600Mhz Corsair Vengeance memory also helps to achieve a significant improvement of the CPU overclock.
Your i7-5820K is really no better than an i7 3960X (top of the Sandy Bridge-E hierarchy). A move from the i7-5960X, top of the Haswell-E, (you have the lowest of the Haswell-E) to the i7-6950X (top of the Broadwell-E) gives two more cores at the same frequency, a 3 to 5 ipc improvement, giving about 25% more performance. So likely a 40% improvement from your i7-5820k before overclocking.
I believe that the top overclocked Broadwell-E on a good X99 system could support an RTX4080 or the up and coming RTX4070ti quite handily at 1440p without bottlenecking. These upgrades listed along with quad channel memory will provide quite a versatile HEDT suitable for gaming, machine learning, deep learning, and scientific processing tasks. The only caveat is that a used i7-6950X still commands a hefty price on eBay, somewhere around 400-500 USD, and 1000+ NIB. Baring these upgrades, you may as well buy a whole new system, preferably i7-13700k with a Z790 motherboard and DDR5 memory, which would likely keep you satisfied for 4 or 5 years.
Resizable Bar requires 10th generation or later Intel CPU's
FWIW good luck.
FWIW good luck.
