- Jul 2, 2007
- 40,435 (6.58/day)
- Republic of Texas (True Patriot)
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
I had a xclio Good power It ran my 7900GS@700/1000 just fine. I put in my 8800GT and it ran fine for less then a month... Replaced it with a Hiper(it was loaned by a friend) just for a temp then i got the Silverstone Zeus..I thought that the Xclio took out my mobo and CPU because they both wouldn't work but come to find out they both are living. with all of the other PSUs out there around the same price as a Xclio i recommend getting one of them
im sort of confused with what your saying, are you saying the XClio still works, because if im not mistaken the 9800GT is just a Rebag of the 8800 lineup thus power output is about the same.
