[Case Gallery] HP rebuilt
Verizon
233 (0.03/day)
earth
System Name To Loud To Name
Processor AMD X2 6000+ 3.647GHz @ 1.75V
Motherboard AN-M2HD
Cooling Crappy Coolermaster cooler
Memory Geil Blck Drgn PC6400
Video Card(s) HD3870 Turbo Fan Modded
Storage raid every other week
Display(s) 17in sony
Case Depends on the day of the week
Audio Device(s) realtek hd
Power Supply reap power pro 650w
Software different every day
Benchmark Scores does it really matter?
Specs:
AMD 4200+X2
asus m2npv-vm
infineon 2gb dual channel ddr2 533
evga 7600gt-oc
soundblaster live! HD
360gb storage
linksys wrt54g
1 300watt hipro modded, and 1 quiet 175 watt
12 volt rail an 11.76
bootscreen and tgtsoft stylexp
windows xp home GENUINE
Mods:
linked the green wire to allow both psu's to run. redirected air over north bridge. mostly i rebuilt from where hp cut ties with me. got a new motherboard to replace there cheapy and added extra usb fixed to ultra slow fan in the hipro psu that stabilized voltages and to compinsate for the vid i got another psu that mounts on my 80mm fan port and vent air out the side of the case. and loaded everything but the motherboard onto the 175 watt now both rails are within 3% of 12
added an extra pic of my kind of entertainment system. this is here because people complained that my last mod wasn't a mod. ran 3dmark06 with all stock settings got the pic in this update
Verizon
233 (0.03/day)
earth
Motherboard AN-M2HD
BTW no definite cable management due to shortage of zip ties but because this is an open case desktop im not to worried
994 (0.15/day)
SoCal
Processor Intel C2D E6420 (3.2 gHz @ 1.365v)
Motherboard Gigabyte 965P-DS3
Cooling Zalman CNPS9500 LED
Memory 4 x 512mb Corsair XMS2 DDR2 667
Video Card(s) Visiontek HD 4870 512mb
Storage 200gb Maxtor SATA, 400gb WD SATA
Audio Device(s) Audigy 2 ZS
Software Windows XP Pro SP2
If you were going to switch out the motherboard, why not just move the whole thing into a new, more spacious case?
Verizon
233 (0.03/day)
earth
Motherboard AN-M2HD
this is the new case because of the lack of any form of money i cant really get a more spacius one. this one had expanded capabilities and could mount the extra psu easily with the 80mm fan port.
1,193 (0.18/day)
Bellevue, WA
System Name 0BL1V10N
Processor Intel Core i7 11700K @ 5.1GHz all-core turbo
Motherboard ASRock Z590 Taichi
Cooling Cooler Master MasterLiquid 360 (with stock CM fans), 12x Pccooler Moonlight Series ARGB 120mm fans
Memory (4x16GB) 64GB Mushkin Redline Lumina 3600MHz 16-19-19-39 XMP
Video Card(s) MSI RTX 4090 SUPRIM LIQUID 24G (not using stock fans) (+150MHz core, +1000MHz memory)
Storage Western Digital Black SN850X 2TB Gen4 NVMe
Display(s) 1x Alienware AW3821DW (3840x1600@144Hz), 2x Dell SE2717H (1080p@75Hz)
Case Phanteks Enthoo 719 Anthracite Grey
Audio Device(s) Schiit Modius + Drop THX AAA 789 + Custom Planar Magnetic Headphones
Power Supply Thermaltake Toughpower GF3 1200W (12VHPWR)
Mouse Logitech G502 X Plus
Keyboard Too many custom mechanical builds to list...
Software Windows 10 Pro 22H2
Uhm.. Heh..
6,959 (1.03/day)
Australia, Sydney
Verzion, a $35AUD case would blow this HP one away... example my one.... i only use... one, two, THREE Zip ties :)
c`LoW
49 (0.01/day)
Processor Intel Core2Duo E6300 @ 3.01GHz
Motherboard MSI P6N SLI-FI
Cooling Zalman CNPP9500
Memory 2GB G.Skill DDR2 800
Video Card(s) nVidia eVGA 8800GTS 320MB 650/1000
Storage Western Digital 250GB
Display(s) Samsung 997DF
Case Coolermaster Centurion 5
Audio Device(s) Steelsound USB Soundcard
Power Supply Zumax 550WATT
Software Windows XP Professional
ugly to the max.
43,628 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Wow C'Low, just joined the forums to make a comment on this case... and I can't blame you! If there was such a thing as computer cruelty the pics that I'm looking at very much resemble a beaten runt pit-bull and his dead friend next to him. Nice monitor though, cool icons!!!
*edit: the little fans everywhere are just darling!!!
6,959 (1.03/day)
Australia, Sydney
Its utterly gross, can't you fix it up man? Seriously, its not that hard to tidy up the cables, and considering that you have barely any hardware it makes it even more unworthy. If ur posting it here, put some effort into it, and not make people feel bad, I get really worked up looking at stuff this bad so sorry if i offended you.
Improvements you could make:
-Buy a new PSU, like 400W from any non-generic brand is enough to power that, two PSUs are just plain stupid
-Cable management, having no zip ties does not make an excuse to make it messy
-Single PSU. I must stress this, your system is dying from heat there is no substantial outake.
-Get a new case, if you got that hardware, then why not get a new case? Your case is seriously limiting the thermal performance of all the hardware, making them fail early, whats worse is the fact that you don't have a lot of money!
-Tidy your room up Its very messy IMHO, no offense intended but you could really do with throwing away your junk, selling as well.
-FINALLY, Your graphics card is preoverclocked... dont expect it to last long if you keep this setup.
I'm not voting on this one... might offend you.
6,959 (1.03/day)
Australia, Sydney
http://www.dealsonic.com/apsupcblatxm.html
This would blow the crap out of what you have atm... the case is good, it has ducting, .8mm SECC and pretty easy to use for cable management. You don't have to pay a lot for space, this case is more spacious than the thermaltake soprano... so yeah.
2THPIC
60 (0.01/day)
lonsdale, ar
Processor AMD Sempron 2 G -Socket A-
Motherboard K7MNF-64 AGP (SOCKET A)
Cooling (2) led fans (1) red (1) blue
Memory 2 G DDR SDRAM
Video Card(s) EVGA 6600LE 256 GeFORCE
Storage 300G / 7200 rpm / 16 MB buff
Case black bio-hazard clear side panel
Audio Device(s) integrated
Power Supply Enermax 535-watt fma II twin fans
Software XP, the basics & wow
case option
umm.........wal-mart has toolboxes for sale around $15.00. i think that would look a lot better. ;-)
If needed I have step by step photos to guide you through the process on how to make a mod case out of a toolbox.
c`LoW
49 (0.01/day)
i think you should reconsider what you said in the begining...
Kammster
188 (0.03/day)
Guyana, South America
Processor Sempron 64 2800+ DH-E6 (@2Ghz - bios limit)
Motherboard DFI NF3 250-AL (@250 FSB - 2000 HTT)
Cooling 92mm + 80mm Exhausts / Amd HSF mod:80mm fan + VF700 cuLED [mod to x800 fan control]
Memory 1GB Buffalo DDR 400 @416 3-4-4-8 1T
Video Card(s) Sapphire X800 GTO (broken- sapphire is BAD)--256mb 6200
Storage WD 120 GB Caviar SE + 1GB Flash [80GB 7200.9 offline]
Display(s) 19" Samsung Widesceen LCD
Case Xtech cheapo
Audio Device(s) onboard - Realtek 6Ch
Power Supply Coolermaster eXtreme Power 550W w/ Antec 120mmLED
Software Windows XP SP2 + nforce 76.45 + nforce 5.10
interesting!!
this reminds me of my athlon xp case and the 450 watt psu that died in it.
i giving a 4: because at least your trying to get u stuff running without spending. but :
1. a dual power psu only one needs to be in the case (u can extend the wires to outside)
2. high qualtity PVC electrical tape could be used for "neat sleeve look"
3. can't u cut holes in the case side panel...even at a work shop to fit the fans.
Verizon
233 (0.03/day)
earth
Motherboard AN-M2HD
im in process of cutting the hole and the second psu's cables are to short so that is the place it goes. most of the modding in this case is live because of the server running on it. so drilling holes in the main case is out of the question but the panels are already being worked on.
Edit: thanks for the 4 at least someone saw the creativity
Verizon
233 (0.03/day)
earth
Motherboard AN-M2HD
tkpenalty i have no money at all. buying parts is out of the question. a customeer just gave me an old slot1 pos and i might use the case but for now iv got got a very large phone bill needs to be payed before i can spend any money
Kammster
188 (0.03/day)
Case Xtech cheapo
had the same problem when i was testing dual power, but when i throw out old psu i gut them, for wires and fans.
i try post a pic, but if u had molex set of wires, then simply insert them into a molex plug like an extension wire. i cut and psu molex and connecter the wires with connectors from an electrical store.
note: i think the longer the wire may cause a drop in voltage, 0.02 or something.
Verizon
233 (0.03/day)
earth
Motherboard AN-M2HD
im actually later goign to modd this extra case and throw them both in it but i have school and a massive headache so ill try it later
i also save the wires and fans from old psu's but i also take the HS's off the resistors
6,959 (1.03/day)
Australia, Sydney
Save up, then buy a case that will actually do good.
Verizon
233 (0.03/day)
earth
Motherboard AN-M2HD
iv got othr things to spend money on then a computer, it works even without cooling fans so its fine. its very low maintenance.
Wile E
Power User
24,318 (3.59/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
I'm not gonna rate it as of yet. You really need to do something about the wiring. Bust out the soldering iron if you have to. If you get the wiring cleaned up, then airflow will be much easier to mange. There's a lot of potential here tho.
53 (0.01/day)
Los Angeles
Processor i9 13900KF @ 6GHz
Motherboard Gigabyte Z790 Aorus Master
Cooling Corsair H150i Elite LCD
Memory 32GB G.Skill Z5 A-Die @ 7000 CL34
Video Card(s) Zotac RTX 4090
Storage 2x Samsung 980 Pro 2TB Gen 4 NVMe
Display(s) 48” Gigabyte FO48U OLED
Case Hyte Y60
Power Supply Corsair RM1000e
Mouse Corsair M65 Ultra
Keyboard Corsair K60
VR HMD Pimax 8KX
Benchmark Scores https://www.3dmark.com/sw/198235 https://www.3dmark.com/spy/34048773
6,959 (1.03/day)
Australia, Sydney
Yes, and lets just ask, what would you do if your PC fails? I would never call the 7600GT a low matinence card under poor thermal conditions. Heat moves up man, not sideways, thats why having the side panel off is virtually useless when you dont have any active exaust.
CH@NO
901 (0.14/day)
Toluca, Mexico
System Name Thank God you're back!!!
Processor Intel Core i3 2100 @ 3.1GHz (stock)
Motherboard ECS H67H2-M3
Cooling Stock + 1 X 80mm Thermaltake red LED
Memory 1 X 4 GB Kingston 1333MHz DDR3
Video Card(s) coming soon
Storage 1TB Seagate SATAII + 500GB Hitachi USB (External)
Display(s) Samsung 20" LED Widescreen
Case coming soon
Audio Device(s) Onboard Realtek HD 6ch Audio
Power Supply Generic 450W with 20A on the 12v+ rail
Benchmark Scores coming soon
Hi Verizon.
I must agree with the other members and say your PC is really a MESS......the case are not to expensive and if you has the money to buy a 7600GT you'll try to consider to pay a 50-60 bucks to buy a descent ATX case (even a generic one).
If you post here is 'cause you have something NICE to show, not only a powerful PC....the appereance also counts A LOT.........So, please re-build your PC and show some respect to the other posts of this topic.
Hope I wasn't so rude.........and sorry for my bad english.
DaMulta
My stars went supernova
16,168 (2.36/day)
Oklahoma T-Town
System Name Work in progress
Processor AMD 955---4Ghz
Motherboard MSi GD70
Cooling OcZ Phase/water
Memory Crucial2GB kit (1GBx2), Ballistix 240-pin DIMM, DDR3 PC3-16000
Video Card(s) CrossfireX 2 X HD 4890 1GB OCed to 1000Mhz
Storage SSD 64GB
Display(s) Envision 24'' 1920x1200
Case Using the desk ATM
Audio Device(s) Sucky onboard for now :(
Power Supply 1000W TruePower Quattro
5/10 for the worst cable system I have ever seen.
You got extra points for that:)
