System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
It has a 128 GB SSD and 1 TB 5400 RPM HDD
Here's a link of one YouTube video,that say that the throttling is not an overheating issue,but the HDD that turns off something...
Please see this:
Maybe this would help you to give me an exact advice!
System Name | AlderLake / Laptop |
Processor | Intel i7 12700K P-Cores @ 5Ghz / Intel i3 7100U |
Motherboard | Gigabyte Z690 Aorus Master / HP 83A3 (U3E1) |
Cooling | Noctua NH-U12A 2 fans + Thermal Grizzly Kryonaut Extreme + 5 case fans / Fan |
Memory | 32GB DDR5 Corsair Dominator Platinum RGB 6000MHz CL36 / 8GB DDR4 HyperX CL13 |
Video Card(s) | MSI RTX 2070 Super Gaming X Trio / Intel HD620 |
Storage | Samsung 980 Pro 1TB + 970 Evo 500GB + 850 Pro 512GB + 860 Evo 1TB x2 / Samsung 256GB M.2 SSD |
Display(s) | 23.8" Dell S2417DG 165Hz G-Sync 1440p / 14" 1080p IPS Glossy |
Case | Be quiet! Silent Base 600 - Window / HP Pavilion |
Audio Device(s) | Panasonic SA-PMX94 / Realtek onboard + B&O speaker system / Harman Kardon Go + Play / Logitech G533 |
Power Supply | Seasonic Focus Plus Gold 750W / Powerbrick |
Mouse | Logitech MX Anywhere 2 Laser wireless / Logitech M330 wireless |
Keyboard | RAPOO E9270P Black 5GHz wireless / HP backlit |
Software | Windows 11 / Windows 10 |
Benchmark Scores | Cinebench R23 (Single Core) 1936 @ stock Cinebench R23 (Multi Core) 23006 @ stock |
Please tell me which temps are normal for playing GTA V for around 10 minutes?
I have just played for ten minutes,and the CPU temp reached 71 degrees Celsius,and then dropped to 67!
Which temps are dangerous ?
System Name | All the cores |
Processor | 2990WX |
Motherboard | Asrock X399M |
Cooling | CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL |
Memory | 4x16GB G.Skill 3600 |
Video Card(s) | (2) EVGA SC BLACK 1080Ti's |
Storage | 2x Samsung SM951 512GB, Samsung PM961 512GB |
Display(s) | Dell UP2414Q 3840X2160@60hz |
Case | Caselabs Mercury S5+pedestal |
Audio Device(s) | Fischer HA-02->Fischer FA-002W High edition/FA-003/Jubilate/FA-011 depending on my mood |
Power Supply | Seasonic Prime 1200w |
Mouse | Thermaltake Theron, Steam controller |
Keyboard | Keychron K8 |
Software | W10P |
How can I test it if it is really throttling,for what period of time playing?
I will test it now and report the results!
Yes I hav tried,but never finished it!
What do you think about the YouTuber?
Is he right about the HDD,and could that solution really help me?
And about the dust filter,what do you think,if the techs remove it,for which period of time then they should open it to clean it?
Which program for an example?
And how to run it while playing?
For how much time should I test it?
Software | W10P |
The CPU overheats for a short period of time ~ 5 minutes,and reaches temps up to 84 degrees Celsius for 15 minutes of playing GTA V !
So you have no idea if it throttled and have built a thread of anger off of something you have no idea how it works?
Some people use the Exclaimation mark in a wrong context, bud read his first post and at least to me doesn't sound angry lol.
Speaking of which, at first I thought your username was eidairaman!.
System Name | ibuytheusedstuff |
Processor | 5960x |
Motherboard | x99 sabertooth |
Cooling | old socket775 cooler |
Memory | 32 Viper |
Video Card(s) | 1080ti on morpheus 1 |
Storage | raptors+ssd |
Display(s) | acer 120hz |
Case | open bench |
Audio Device(s) | onb |
Power Supply | antec 1200 moar power |
Mouse | mx 518 |
Keyboard | roccat arvo |
Tjunction is 100° for this processor
Which temperature would be optimal for this CPU while playing GTA V for an hour for example?
