IEEE 1394 (firewire) Help
gamer210
136 (0.02/day)
University of Texas San Antonio
Processor Intel Core 2 Quad Q9450 @ 2.66 GHz
Motherboard ASUS P5Q Pro
Cooling Zalman CNPS 9700
Memory Mushkin XP 4GB DDR2 1066
Video Card(s) 2x Radeon HD 4850
Storage Seagate 750 GB w/ 32MB Cache
Display(s) Dell 2007WFP Rev A04 S-IPS
Case Tuniq 3
Audio Device(s) Asus Xonar DX
Power Supply PC Power & Cooling 610
Software Microsoft Windows Vista Business 64-bit
I just bought a new digital camcorder with a DV link on it. My case has a firewire plug (6 pin), but my motherboard doesn't have a 1394 header. I don't have any spare PCI slots, so buying a card is out of the question. Does anybody have any suggestions? I would really appreciate your help.
hmmm....
the only way i know to get it is to buy a pci card. theres no such thing as a usb->firewire thingy that i know of. hmm.
yea, unfortunately i don't think usb to firewire available. if you have a sound card, you could replace that with a diferent sound card that has firewire (a lot of them do)
otherwise.... idk
otherwise.... idk
Sound card, or pci card.
USB->firewire is not possible directly.
do you have a USB card? replace it with a USB/FW card for a 2 in 1 deal..
My board only has 2 PCI slots. I have my X800 w/ Silencer that takes up the pci slot beneath PCI-E. Under that Is my SB Audigy 4. I have an open PCI-E 1x, but I've only found a few of them, and they are relatively expensive.
the only option i see for you is a different mobo that has 1394, or replace your sb with one that has 1394
Dump the Audigy 4 and get the Audigy 2ZS as it has a firewire port and an internal header I believe.
you cuold get a usb soundcard and then as if by magic a pci slot opens up or you could just use the intigrated stuff it is not really all that bad anymore
confused motherboard?
I got a firewire port built into my PC and whenever i plug in my camera via firewire, my PC dont detect anything. i go to device manager and it reports that the thing is enabled and there are no problems, but if that were the case i wont have any problem. i get the bios for my computer and the driver for the firewire port updated from the technical support page for my PC still it doesnt work. i go to my friends house to check if it my camera and cable work. i plug it into his and it detects instantly. there was no difference appart from computers.
any1 got advice 4 dis problem?
is firewire enabled in bios and in the jumpers (read your manual)
yh da firewire is enabled in da bios setup page dats y it shows up in da network connections
but i dont know wot ur on about wen u talk bout da jumpers, tell me bout dem plz
maybe dat might b da solution
