- Apr 23, 2006
- 3,558 (0.51/day)
- Enschede, The Netherlands
System Name | Lian Li Carbon fiber ed. |
Processor | Intel i5 2500k 4.6Ghz 24/7 Max OC 5Ghz |
Motherboard | Asrock Z68 Extreme3 Gen3 |
Cooling | Swiftech blocks, 360 Xflow rad, Swiftech 120 rad, Liang with XSPC res/pump top. |
Memory | 8Gb Mushkin 1600Mhz 8-9-8-24 |
Video Card(s) | Sapphire HD6950 2Gb |
Storage | OCZ Vertex 4 128 / Western Digital 160 |
Display(s) | ASUS 25,5" wide VW266h |
Power Supply | Corsair HX620 modular |
Software | Windows 7 64 |
Can you?
Last week i tried everything outside the case. Installed all the mobo drivers, added 1 card + 1 bridge. Installed Catalyst 9.2 drivers with ccc added second card. Did not work.
Kept in both cards while removing driver again.
Reboot, both cards are in device manager. Installed driver again. Reboot. Success.
Enabled Crossfire in ccc and everything worked.
Since i had to return a psu. And get another one, i disconnected everything and let it rest for a week.
So yesterday i started on the Crossfire thing again. Still on Vista 32. Could not get it to work.
I tried one card, then adding a second. Tried both at the same time but nothing.
Removed drivers and ran driver cleaner in safe mode.
So i tried to install the graphic drivers again and then i got the message ''inf file not found''
Did not know how to fix it so i decided to install Vista 64.
At one time i got to the point that i got 2 cards in device manager but when i try to install the drivers again then it hangs on Vista booting up.
Could you give me some advice on how to get this working.
Btw. I can feel that 1 card is warm and the other stays cool. And i can only boot up with the DVI cable connected to the Club3d card if i try the Sapphire. It won't boot.
I really hope that the Sapphire card is not dead.
Because when it comes to bad luck on hardware, i had my share for this year.
