Intel lying about their CPUs' TDP: who's not surprised?
1,067 (0.68/day)
System Name The Sparing-No-Expense Build
Processor Ryzen 5 5600X
Motherboard Asus ROG Strix X570-E Gaming Wifi II
Cooling Noctua NH-U12S chromax.black
Memory 32GB: 2x16GB Patriot Viper Steel 3600MHz C18
Video Card(s) NVIDIA RTX 3060Ti Founder's Edition
Storage 500GB 970 Evo Plus NVMe, 2TB Crucial MX500
Display(s) AOC C24G1 144Hz 24" 1080p Monitor
Case Lian Li O11 Dynamic EVO White
Power Supply Seasonic X-650 Gold PSU (SS-650KM3)
Software Windows 11 Home 64-bit
Lying about power consumption numbers to make your products look good is just despicable.
Thank God I have a 4690k which means I don't have to deal with this mess.
11,095 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
1) that's been true for a while - for both vendors, the chips will boost past specs if allowed to,
2) peak power consumption depends on mobo turbo limits, and most of the mobo manufacturers 'cheat' and allow the chip to boost beyond specs (which is fine, it's a type of overclock) as per that article.
3) yes 10 cores on 14nm is power hungry, but it still more efficient than a 4690k perf/watt. A 4690k can peak at 152W which is really not that far behind the 10700k and slightly over the 10600k.
Neither one of those is a 'mess' nor is it a reason to stick to a 4690k.
1,067 (0.68/day)
hat
Enthusiast
21,753 (3.23/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
That's turbo boost for you. TDP is rated at "base frequency", that depressingly low figure well under the turbo speed. For example, take the 10900k, base frequency 3.7GHz, 125w. All bets are off once turbo kicks in.
11,095 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
Also the idle -- the 4690K doesn't have all the newer power saving tech so it idles at like 56W stock, where the 10 series sit at 15-35W depending on flavor... if you leave your computer on alot you would actually save a bit of power going to the newer chips.
Ruru
S.T.A.R.S.
13,764 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
Their TDP should have been considered as a joke for few years already. But I wouldn't mind if just the cooler is fit to do its thing.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
The worst part is i know intel fanboys who rabidly defend these stats and say its lies
one is still on an i7 970 "intels done me great all these years, i trust them!"
11,095 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
I'm so confused... AMD and Intel have been doing the same thing for FOREVER ?... the phenoms were rated for 94W that sucked down over 200W... Zen 3 while extremely efficient also consumes over its rated TDP... OP is posting on a chip rated for a TDP of 88W that at stock config will eat over 150W. Thermal Design Power (TDP) != Power Consumption.
What exactly is the problem? Is it that motherboards are yolo boosting to the moon because they can? Is it because intel can't get its sh*t together and is still on 14nm? I guess I am missing the part where we decided this was Intel's fault for lying...
Ruru
S.T.A.R.S.
13,764 (3.05/day)
Jyväskylä, Finland
What exactly is the problem? Is it that motherboards are yolo boosting to the moon because they can? I guess I am missing the part where we decided this was Intel's fault for lying...
My opinion would be that
a) the cheap motherboards have hard time with their crappy VRMs on higher end chips
b) getting better cooling always costs more
11,095 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
Ok but... this is partially true. GIGABYTE and ASROCK cheap boards have severe VRM issues and are terrible but - you can get $140-150 z490 boards from Asus and MSI all run a 10850K/10900 at 5+ghz with no vrm issues whatsoever.
Cooling a hot chip is expensive for sure -- but considering that the 5600x is going roughly for the same price as a 10850K right now (within about $25) , you're still looking at the "budget" option. 5800x comes with no cooler either and is about $120 more.
hat
Enthusiast
21,753 (3.23/day)
Ohio
Like I was saying, TDP is measured at "base frequency". Both Intel and AMD are using some form of turbo boost that will go very close to the limit of the silicon, provided the power delivery and cooling is good enough.
TDP wasn't terrible with older chips, like my 2600k, because turbo boost wasn't as aggressive and we were stuck with quad cores until the 8th Core generation. With 8 and even 10 core chips pushed to the limit, you're going to see a lot of power consumption. I can make my 2600k draw tons of power too, if I slapped a huge cooler on it, clocked it to 5GHz and flooded it with enough voltage to keep up.
Ruru
S.T.A.R.S.
13,764 (3.05/day)
Jyväskylä, Finland
I'd still get a 3600 for a bang for buck setup like I did several month ago.. :toast:
Mussels
58,412 (7.78/day)
Oystralia
its because the numbers have meant less and less every generation, to the point a 65W CPU use more power than a 125W in *INTELS OWN PRODUCT STACK*
AMD's current ones are more the accepted norm, with TDP being an 'average' and the reality being a little higher (65W = 85W, 105W = 140W)
Intels OTOH... 65W = 214W and 125W = 204W
7,832 (1.78/day)
AMD's definition of TDP is something else & doesn't really translate into power consumption directly. We've been over this, also I'll add that AMD does enforce their "TDP limits" more stringently & there's a whole host of other settings that affect it as well like PPT, EDC,TDC et al.
tabascosauz
8,301 (2.31/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
I really don't see how any of this is "lying" if one has the brain capacity to put two and two together, and figure out that TDP doesn't govern jack shit related to actual power consumption for either company, and hasn't ever in recent memory. The only reason it's in the spotlight now is because of the wide gulf between base clock and boost clock. PL1 isn't some new kid on the block.
Now for mobile chips, Intel does some nefarious marketing manipulation using its TDP-up and TDP-down mechanism to misrepresent what its chips actually do in a practical TDP configuration. Now THAT's borderline lying.
As for the "but my 4690K is efficient" LOL nice one, try putting an AVX load on that chip for once and see what "TDP" means. Sitting here looking over at my 4790K, trying to think of all the times when 88W ever meant anything to it
Mussels
58,412 (7.78/day)
Oystralia
please use your logic to explain how the 65W 10700 uses more power than the 125W 10700k
Frick
Fishfaced Nincompoop
20,042 (2.86/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
This is all there's to it.
Disable boost and it's fine.
Boosts slightly higher?
Mussels
58,412 (7.78/day)
Oystralia
That explains why it uses the power.
I want you to explain why intels marketing has the lower TDP CPU using more power than the higher wattage one.
The marketing and TDP ratings are the problem here, not the technical reasons why they use the electricity - the magical lighting inside the melted sand make zappy zappy hot, but intels fudging the numbers really badly here.
397 (0.12/day)
System Name 06/2023
Processor R7 7800X3D
Motherboard ROG STRIX B650E-I GAMING WIFI
Cooling Custom 240mm cooling (for CPU) with noctua nfa12x25 and Phantek T30
Memory 32gb Gskill 6000 CL30
Video Card(s) RTX 4070 dual asus deshrouded with 120mm NF-A12x25
Storage 2tb samsung 990 pro + 4tb samsung 870 evo
Display(s) Asus 27" Oled PG27AQDM + Asus 27" IPS PG279QM
Case Ncase M1 v6.1
Audio Device(s) Steelseries arctis pro wireless + Shure SM7b with Steinberg UR
Mouse Corsair scimitar pro (this mouse need an overall guys pls) + Logitech G Pro wireless with powerplay
Keyboard Keychron K5 max QMK red switches
Software windows 11
Benchmark Scores Over 9000 !
Mussels
58,412 (7.78/day)
Oystralia
Lower quality silicon.
best answer so far, tbh.
Still doesnt excuse intel from advertising half the TDP (THERMAL design power) for the chip that uses more power and produces more heat
7,973 (3.29/day)
California
System Name His & Hers
Storage lots of SSD.
Most likely down to most Z motherboards running the chip without power limits to begin with or the reviewer manually doing it and it having a worse ihs than the k chip and most likely being a lesser bin so higher voltage to hit whatever boost frequency.
Asus is the only company afaik that enforces power limits at least till you enable xmp lol
74 (0.02/day)
hope you didn't pay more than $180 or so... i think i lucked out at ~$150-160, however you want to calculate the $20 combo savings at Microcenter... (before the fall hardware stock madness)
3,983 (1.33/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
That article is about 3.5 years too late.
The CPU that started this was 8700K which ran at~130W at full blast (the "boost" 4.3GHz on all cores) and that came out in autumn 2017. High-end Intel CPUs have only gotten worse since.
AMD isn't slouch any more either, since Ryzen 3000-series there is this complex system for power limit which in large picture boils down to power limit at 1.35x TDP.
This has not been going on forever. There have been CPUs that exceed TDP to some extent but this was not a major issue until a few years ago. Top-end Phenom was 1100T and it generally stayed in its 125W TDP. There was the FX 9590 that went over 200W but it also had TDP of 220W :)
TDP was not terrible because it was enforced as power limit. The part about not having to fudge the numbers or outright lie because the chips genuinely did not draw more than TDP of course helped :D
