Intel Optane memory not configuring.
118 (0.03/day)
Australia
System Name Gladiator
Processor i7 7700k (Kaby Lake) 4.2-4.4ghz
Motherboard Gigabyte Z270m-D3H
Cooling Exhaust fan: Corsair - CPU: Coolermaster liquid
Memory Kingston Hyper-X Fury 16GB DDR4 @3200mhz
Video Card(s) Asus 2060 Dual OC
Storage WD 1TB 450ssd
Display(s) Samsung 23inch curved@ 1080
Case Cougar 330G
Audio Device(s) Logitech 5.1 Stereo
Power Supply Antec 650w Gold
Mouse Logitech G300S
Software Windows 10 64bit
Hi there, I've just recently bought an intel optane memory 16gb module and have just installed it into my m.2 slot. I'm having trouble enabling it and have read that I might even have to reinstall the operating system just to get it working. I've tried updating all drivers but still it only comes up with this. If I have to re-boot my pc then I'll just return the damn thing. Cheers.
125759
My mother board.
GA z270m d3h
My HDD WD 1TB
3,244 (1.16/day)
System Name Grunt
Processor Ryzen 5800x
Motherboard Gigabyte x570 Gaming X
Cooling Noctua NH-U12A
Memory Corsair LPX 3600 4x8GB
Video Card(s) Gigabyte 6800 XT (reference)
Storage Samsung 980 Pro 2TB
Display(s) Samsung CFG70, Samsung NU8000 TV
Case Corsair C70
Power Supply Corsair HX750
Hi there, I've just recently bought an intel optane memory 16gb module and have just installed it into my m.2 slot. I'm having trouble enabling it and have read that I might even have to reinstall the operating system just to get it working. I've tried updating all drivers but still it only comes up with this. If I have to re-boot my pc then I'll just return the damn thing. Cheers.View attachment 125759
My mother board.
GA z270m d3h
My HDD WD 1TB
Is your BIOS set up for Intel Rapid Storage Technology (RST)? It needs to be. Some newer boards make it even more straightforward and also have an Optane label there.
118 (0.03/day)
Australia
Case Cougar 330G
How would you have to set up the bios for intel rapid storage? Would I need to reinstall the entire os again? My motherboard says its intel optane ready.
Or could I just go into my bios options in the boot menu?
Solaris17
Super Dainty Moderator
27,605 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
Audio Device(s) Moondrop S8's on chitt Gunnr
Keyboard Wooting 80 HE White, Gateron Jades
VR HMD Quest 3
RAID is an extension of AHCI, so probably not.
118 (0.03/day)
Australia
Case Cougar 330G
Solaris17
27,605 (3.84/day)
Alabama
VR HMD Quest 3
So meaning I would have to reinstall everything again?
nope. You probably wont need to. Just switch it to RAID mode instead of AHCI and install the Intel RST again.
118 (0.03/day)
Australia
Case Cougar 330G
Alright, I'm not quite sure on how to switch them. How would I go about doing that. Within the boot menu or within a command? And would switching them alter anything (programs and documents and such?)
Solaris17
27,605 (3.84/day)
Alabama
VR HMD Quest 3
you have to do it in BIOS. It will generally be somewhere with a list of all of the hard drives. PCH menu maybe. It really varies alot by board. Just take a look around, or google how to enable optane on your specific model, some kid probably uploaded it to youtube complete with terrible mic quality for you to enjoy for 11 minutes.
118 (0.03/day)
Australia
Case Cougar 330G
Alright, but would changing this setup from ahci to raid cause a reboot. Such as loss of files and programs?
Solaris17
27,605 (3.84/day)
Alabama
VR HMD Quest 3
I mean anything’s possible you should always backup what you need before modifying hard drive configs, but in the case of AHCI to RAID generally not a problem.
3,244 (1.16/day)
System Name Grunt
Case Corsair C70
I doubt that'd be a problem since those same BIOS menus let you select specific drives. All you're expected to do with Optane is turn on RST and then set up the M.2 slot with your Optane drive to be in RST mode. It won't be readable as a regular SSD drive afterwards, but will show up in the Windows RST or the Optane app and allow you to pair it with a hard drive.
866 (0.22/day)
Processor ryzen 5 5600x
Motherboard AB350m Pro4
Cooling custom loop
Memory TEAMGROUP T-Force TXKD416G3600HC18ADC01 16gbs XMP
Video Card(s) HP GTX1650 super 4gb
Storage MZVLB256HBHQ-000H1 PM981a (256GB)/3TB HDD
Display(s) Nitro XF243Y Pbmiiprx
Case Rosewill CULLINAN
Power Supply Corsair 750w
Mouse Best Buy Insignia
Keyboard Best Buy Insignia
Software Win 10 pro
if its like in the windows 7 days of intel rapid storage technology you may need to edit the registry in windows 10 before you switch from ahci to raid mode in the bios.
my reseach has come up with this method for win 10. its actually for windows 8 but it appears to work. try at your own risk.
    1. If currently installed, uninstall your RAID or AHCI SATA driver (for intel, intel rapid storage technology)
    2. Basically open msconfig -> boot tab -> check safe boot -> restart
    3. Go into UEFI/BIOS and set SATA mode to which ever one you want
    4. Boot up into windows safe mode
    5. Open msconfig again -> under the main menu tab (general) click the normal startup circle - > restart
    6. Your system should boot into windows fine and you can install your AHCI or RAID driver.
source: https://www.overclock.net/forum/20-...ge-sata-modes-after-windows-installation.html
1,909 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
If you switch to RAID you'll have to reinstall everything, cause your system wont see it.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
That isn't true, with Windows 7 you need to do a registry edit to get it to work after changing from AHCI to RAID with Windows 10 all you have to do is boot into Safe Mode once and it will do the changes for you.
Why would you switch to RAID mode? That doesn't sound correct.
Because Optane requires the storage controller to be in RAID mode to work.
552 (0.13/day)
System Name Can I run it
Processor AMD Ryzen 9 7950X3D @ 2200Mhz FCLK (The rest is still tuning)
Motherboard Gigabyte B650E Aorus Master
Cooling Thermaltake TH420 V2 White
Memory KLEVV CRAS V RGB DDR5 48GB (2x24GB)7200 MT/s 34-44-44-84 @ 8000 MT/s 36-49-46-76 1.52V VDD/1.4V VDDQ
Video Card(s) ASUS Strix RTX 4090 LC OC with two more T30 @ +100mv +150Mhz core +1963Mhz mem (~3045Mhz core)
Storage 990 Pro 4TB (Game) Transcend 220S 1TB (Win) WD 250GB (Linux) Galax 120GB (OC test) Seagate HDD 4TB
Display(s) Samsung Odyssey OLED G9 49" 5120x1440 240Hz calibrated by X-Rite i1 Display Pro Plus
Case Coolermaster HAF 700 White with 9x Phanteks T30
Audio Device(s) Q Acoustics M20 HD speakers with Q Acoustics QB12 subwoofer
Power Supply Thermaltake PF3 1200W 80+ Platinum
Mouse Logitech G Pro Wireless
Keyboard Logitech G913 (GL Linear)
VR HMD Logitech G923 with Logitech Driving Force Shifter
Software Windows 11, Ubuntu 24.10
This
I also have Optane. Everything will work fine after you change AHCI to Raid or Intel RST Premium mode (depend on what is your motherboard call it) in BIOS. It is just 2-3 clicks.
bug
14,337 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
349 (0.12/day)
Optane acceleration requires uefi boot mode, bios/legacy isn't supported.
What boot mode are you using, OP?
Check this way -> LINK
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Wow, I never knew that was a requirement for Optane caching. That makes no sense considering Optane is just a rebrand of Intel's SRT which has worked since the Z68 days without needing the OS to boot in UEFI mode.
Seems like a classic case of Intel locking something down just to force UEFI on us.
552 (0.13/day)
Just finish testing Optane vs HDD side by side comparison in programs and games. :D
180 (0.08/day)
South Africa
System Name 1.Archimedes 2. Ianna
Processor 1. i7 7700k 2. R5 1600x
Motherboard 1. MSI Z270 Gaming Pro Carbon 2. ASUS Prime X470 Pro
Cooling 1. U12S with IPPC 3000RPM 2. AMD Wraith Prism
Memory 1. 16GB Crucial 2400MHz (4x4GB) 2. 16GB Crucial 2666Mhz (4x4GB)
Video Card(s) 1. MSI 1060 Gaming X Plus(6GB). 2. MSI 1050TI Gaming X (4GB)
Storage 1. 32GB Optane+120 GB SSD, 4TB X300, Firecuda 2TB. 2. Kingston 240GB SSD, 4TB X300, 2TB WD Blue
Display(s) 1.Samsung Q7FN 55 Inch 2. AOC G2460VQ6
Case 1. S340 Elite. 2. S340
Audio Device(s) 1. Q70R Soundbar 2.Lenovo Y Gaming, Galaxy Buds
Power Supply 1. Antec TPC 750W 2. Antec EAG650 Pro (Both Seasonic OEM)
Mouse G502, G102
Keyboard G413
I didnt want to lose data on my hard drive so i installed windows on a laptop ssd and linked the optane to that instead. Didnt lose any data on my old boot drive which was AHCI. Didnt change anything in bios only made sure that flash drive was formatted for UEFI only.
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
I would really like to know the reason for this as well. It seems odd that they would shove this down your throat just to gain adoption since UEFI is basically the law of the land for any new hardware that's produced these days. It's also been around for quite some time as even my aging machine supports it. It could be possible that they're starting to abandon legacy BIOS support all together because that's code that has to be maintained and UEFI was designed to eventually succeed the legacy BIOS. I guess it's possible that its operation depends on features provided to the OS by UEFI, but that's speculation and not something I'm super familiar with.
I'm just skeptical of the idea that Intel is doing this to force UEFI on us since that doesn't really get them anywhere.
180 (0.08/day)
South Africa
Mouse G502, G102
Keyboard G413
Well I can think of a good reason in my case, Windows 7 support. My only HDD was formatted MBR, can't remember how exactly but I used to dual boot both Win 10 and Win 7 (Mainly) from that drive. When optane didnt work, due to same error as OP I guessed that there was a chance something would go wrong during conversion to GPT. (Please correct me if im wrong) Convinced a friend to buy a SSD and linked Optane to his old one. @Dovah88 , I've corrupted this (worthless) boot drive a couple of times messing around in the BIOS. If your Hard Drive is already GPT, you should be able to enable UEFI Boot in bios and M2 Storage Remapping only, and the Optane application will install. If MBR currently, then either convert to GPT (Chat to someone more knowledgeable regarding the risks, if any) or link optane to another disk. I know my settings are technically incorrect yet works perfectly for my use case. SATA 2 boot drive lol.:D
180 (0.08/day)
South Africa
Mouse G502, G102
Keyboard G413
Edit: Please forgive my stupidity, dual boot was Win XP and Win 7, not 7 and 10.
