- May 30, 2007
- 9,019 (1.37/day)
System Name | Black Panther |
Processor | i9 9900k |
Motherboard | Gigabyte Z390 AORUS PRO Wifi 1.0 |
Cooling | NZXT Kraken X72 360mm |
Memory | 2 x 8GB Corsair Vengeance RGB Pro DDR4 3600Mhz |
Video Card(s) | Palit RTX2080 Ti Dual 11GB DDR6 |
Storage | Samsung EVO 970 500GB SSD M.2 & 2TB Seagate Barracuda 7200rpm |
Display(s) | 32'' Gigabyte G32QC 2560x1440 165Hz |
Case | NZXT H710i Black |
Audio Device(s) | Razer Electra V2 & Z5500 Speakers |
Power Supply | Seasonic Focus GX-850 Gold 80+ |
Mouse | Some Corsair lost the box forgot the model |
Keyboard | Motospeed |
Software | Windows 10 |
So I have this weird problem. It is on our main pc at work so I can't experiment.
When I first assembled it and installed Windows 7, I had made a 65GB partition for Windows.
In the other much larger partition there is our accounting program.
There is no junk on this pc, and nothing gets saved in the 65GB partition, we only use it for our accounting program where everything gets saved to the ''B'' partition.
The OS is still Windows 7 to date.
The problem is that now the smaller partition dedicated to the OS is nearly full... (I had thought 65GB was more than enough for the OS?) I remember reading (when I built this pc around 2 years ago) that 20GB was sufficient for an OS partition, and to be on the safe side I made it 3 times larger! So I can't figure out how this happened.
But most importantly, is there a way I can re-partition the drive, say increase the OS one by 40 GB which I remove from the ''B'' partition?
Formatting the pc is not an option, because probably then our accounting program won't work - and I can't reinstall the accounting program myself because one of the conditions of our contract is that installations are always done by our supplier against a (rather hefty) fee...
