Is it possible to set max gpu voltage in the gpu bios ? how to do that ?
192 (0.37/day)
Processor 5900x
Motherboard MSI 570s
Cooling AIO 240
Memory 32 GB G.Skill @ 3200MHz
Video Card(s) 6800 xt
Storage Many
Display(s) Two QHD
Power Supply SilverStone Hela 1200W
Hi
I am new to modify or read gpu bios values but I need to set the max gpu voltage in the gpu bios so whenever a new driver installed or computer/windows changed the value remains , how I can do that ?
192 (0.37/day)
Processor 5900x
Cooling AIO 240
Storage Many
Display(s) Two QHD
I have gigaybyte rx 6800xt gaming oc I wanted to undervolt the gpu. What are the instructions to do this ?
2,336 (4.40/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) 1080P 144hz
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Just use the driver software in gpu performance tab. Select tuning. Then you set desired settings. Then have the app start up with windows and apply the settings.
Yes, occasionally you may have to re-set the settings, but usually only after a driver update, or the driver crashes.
If you cannot do this, then you shouldn't be modifying a bios. Imo.
192 (0.37/day)
Processor 5900x
Cooling AIO 240
Storage Many
Display(s) Two QHD
Another person will have the card. He will not be able to do that in the driver and without doing this the temp goes 110c, fan too loud and throttle problem
2,336 (4.40/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
It's a hot GPU even with an under-volt.
Is there a way to get better case flow? Maybe some upgrade fans or reposition them?
192 (0.37/day)
Processor 5900x
Cooling AIO 240
Storage Many
Display(s) Two QHD
The case has good airflow with 6 fans
2,336 (4.40/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
Teach your friend how to tune this. It's pretty easy. Otherwise, I have no more suggestions at this time.
3,978 (1.93/day)
Thessaloniki, Greece
System Name PC on since March 2025, upgraded from 5900X
Processor Ryzen 7 9700X (March 2025), 150W PPT limit, 85C temp limit, CO -25, +100MHz (up to 5.65GHz)
Motherboard Asrock X870E NOVA, BIOS v3.2, AGESA PI 1.2.0.3a Patch A
Cooling Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off-center mount for Ryzen, TIM: Kryosheet
Memory 2x32GB G.Skill Trident Z5 RGB (March2025) 6200MT/s 1.42V CL30-36-36-36-28-64 1T, tRFC:500, Hynix A-D
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (370W current) PowerLimit, 1060mV, Adrenalin v25.3.1
Storage NVMe: 990Pro 2TB(OS 25), 980Pro 1TB(22), 970Pro 512(19) / S-III: 850Pro 1TB(15) 860Evo 1TB(20)
Case Thermaltake Core P8 TG Gaming Full Tower, Fans: 9x140mm + 3x120mm
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3775), Install March 2025
It’s better to not mess with bios modifications and reflash procedures nowadays with modern cards.
Nothing like the old floppy drive on dos where you could do the reflash even with no display on in case of anything wrong.
it’s literally a few clicks within Adrenalin and you can save profile(s) with different settings. Each for any circumstance for example.
3,107 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB Samsung 990 Pro
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
just repaste the card and let him use it stock.
undervolting does not affect the hotspot that much. maybe it ends up in the low 100s instead of 110°C. almost all except of really high end coolers can do that since the Die is not flat in the center.
140 (0.02/day)
Netherlands
System Name Whitewonder
Motherboard Asus Proart X670-E Creator
Cooling Corsair custom Watercooled
Memory 64 Gb
Video Card(s) RX 6800 XT, 2080
Storage Too much to mention in all 1190 TB
Display(s) 2 x Dell 4K @ 60 hz
Case White XL case
Audio Device(s) Realtek + Bayer Dynamics 990 Pro headset
Power Supply 2100 watt
Mouse Corsair cord mouse
Keyboard Corsair red lighter cabled keyboard ages old ;)
Agree with all others do not mess with ANY bios if you have no experience in doing it
It looks easy but small mistakes can lead to absolute failure and possible brick your hardware.
Yes i have bricked a few times some of my hardware and to be honest i hardly see any reason todo that anymore either unless your a hardcore overclocker :D
But even they hardly ever use it anymore as the super tools from this era makes fixing it as easy as eating pie ;)
Make a profile and save that so in case you get any change you load the profile and poof all is back at what you made it do.
These cards are really able to handle the heat and just throttle a bit when they become too warm to its taste.
I got a "ASUS TUF RX 6800 XT GAMING OC" myself and cranked the speed a bit down even though it does not even hit 110 C.
Now having 6 fans does not mean that your airflow is good, in fact it could be a mess as you need to use any smoke to see if you flow is good, most people put in tons of fans and have a total blocked airflow i use the little stick with the smell
I admit i forgot the name of them but have a huge pile of them, with that i test how my airflow is in my case
So assuming that (232 billion) fans make it cooler is absolute a fail thought :D
So to be honest i see no result in performance at all with the profile setting i did in Adrenalin in any of the games and it stays very cold for this kinda card now.
I run most of my games with max settings (aka 4K) with my dual 4K monitors except when there is a insane amount of glowing bs happening in the games i play :)
It runs so good that i really do not find the need for the XFX 7900 cards at all
2,176 (0.80/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
@Martin007
you can use something like Afterburner, doesnt need bios mod and is driver independend.
you can set a profile, set as default, and load at win boot.
ignoring that if someone cant use the gpu panel, to change stuff (after update), your probably better off using
something like TeamViewer for remote help/access.
much easier and way faster than explaining stuff to ppl.
edit: make sure to not use/disable hw monitoring, at lest not for anything "power"..
