- Jul 28, 2016
- 167 (0.05/day)
- Sydney, Australia
System Name | Main Gaming Rig |
Processor | Intel Core i7 14700K |
Motherboard | Asus ROG Maximus Z790 HERO (Wi-Fi) |
Cooling | Noctua NH-D15S chromax.black |
Memory | G.Skill Trident Z5 RGB 64 GB (2 x 32 GB) DDR5-6400 CL32 Memory |
Video Card(s) | ASUS ROG Strix RTX 4080 GAMING OC |
Storage | 3 x Samsung 980 Pro 2 TB M.2 nVMe SSD's |
Display(s) | Asus ROG VG27A 27" 16:9 2560x1440 144/165Hz & Asus PB278Q 27” 16:9 2560x1440 |
Case | Fractal Design Torrent RGB ATX Mid Tower Case |
Audio Device(s) | Onboard |
Power Supply | Seasonic Vertex ATX 3.0 80 Plus Platinum 1000W |
Mouse | Razer DeathAdder Chroma v2 |
Keyboard | Razer Blackwidow Chroma v2 |
Software | Windows 11 Pro 64 Bit |
Hi All,
So, I have an old Core2 Quad Q9650 paired with a EVGA 790i FTW mobo and 8GB of Corsair XMS3 (Big silver heatsinks) RAM and the issue I'm having with the machine is that I cannot get a video display out of it (using the old GTX 285 with it). From memory, the last time this rig was used, it was working fine with no issues (it was the wife's old PC). I've just recently pulled it out of my storage and have moved it into a new case and changed the CPU cooler (from the stock cooler because the fan had stopped was making horrible noises) to a spare Cryorig R1 Ultimate (Was a very tight fit with the huge heatsinks on the board) I had lying around and for some reason, as mentioned, I cannot get a display out of it. The mobo displays the post codes of FF on it, and from the manual for the board, it just means "boot" which I take to mean as good.
I've tried booting the system with all the different configurations of the RAM that I can (1 stick, 2 sticks, etc etc) but that's made no difference. Also tried booting the machine with only the minimums attached, no drives or SSD's, only the GPU in addition to what needs to be on the board, again, no difference. At the timing of this post, I've removed the BIOS battery and am leaving the machine disconnected for a while to discharge it to see if that helps at all, but I'm not 100% sure what else I can try on the hardware. I would welcome any suggestions/recommendations.
If any further information is required, please let me know and I'll post.
Cheers!!
Cheers!!
