Ok..A little introduction if i may..Basically, the goal is to watercool the case all internal without ruining the case's simple and minimalistic design. Yet maintaining a cool and quite system. The system will be overclocked to its highest stable clock(3.4ghz) on stock vcore.
So i present Project[Thessa] < named after my significant other as a tribute for financing this whole project. LOLZ! ;-D
Loop 1: Ek Res 250> MCP655>TC PA120.3> Q6600> NB> SB (EVGA 680i)
Loop 2: Ek Res 150> MCP655> BIX II 240 > 2 x EVGA 8800gts 512mb (Will Be changed later to BIX II 360)
Pics!
Top Mounted PA120.3
Lasercut Acrylic PA radgrill
Powdercoat done..mounted the res and top rad
front rad mounted in custom hd cage bracket
window cut
misc mods
thats it for now..some minor adjustments will be done later..
the parts i will be using
tubes will be replaced to a tygon 3400 1/2id 3/4od on compression fittings on the cpu block. the rest of the fitting will be the dangerden fatboyz
Pics!
Top Mounted PA120.3
window cut
misc mods
