Are you plugging in the 4-pin 12v line for the cpu, If your psus are older than they may not have one at all, you need that 4pin 12v for any new CPU's.
Without RAM and the CPU in the motherboard does it still shut off after a few seconds?
If it does then their is either something wrong with the PSU or motherboard, try the both PSU's just incase, if neither of them work (outside of the case) with nothing but the motherboard then just take the motherboard back, the lights should light and the fans should spin until YOU turn it off.
Make sure the PSU's work in other pc's also.
If it keeps spinning without the cpu and ram then buy a new psu and if it still doesnt work you could always take back the motherboard for another...
Anyway 400-450watts its what you will need, I would recomend 25A on the 12v line(s).
Do not buy that LC powersupply, they are known to use cheap parts.
Good Brands:
Fortron
Sparkle
Antec
Enermax
Zalman
Tagan
Seasonic
Zippy/Emacs
PC Power and Cooling
Remember watts does not really matter at all just how many amps are on the 12v line(s), you can tell a good psu from a cheap one usually just by lifting them up (Heavier = Better), also alot of companies like to trick you by having similar names.
Good Brands:
Fortron
Sparkle
Antec
Enermax
Zalman
Tagan
Seasonic
Zippy/Emacs
