- Feb 19, 2006
- 6,270 (0.89/day)
- New York
Processor | INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts |
Motherboard | ASUS PRIME Z390-P ATX |
Cooling | CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull |
Memory | CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz |
Video Card(s) | EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING |
Storage | ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND, |
Display(s) | 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved |
Case | BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE, |
Power Supply | 1600 Watt |
Software | Windows 10 |
HEADS UP
Like the title says if you are seeing MB services using HUGE amounts of Ram its a known issue as of today and a few hours ago....I did all trouble shooting unintall reinstall clean try again and then found out it is a KNOWN ISSUE AS OF A FEW HOURS AGO! I uninstalled and will leave it that way until fixed!!
https://forums.malwarebytes.com/topic/219918-ram-usage-what-is-going-on/
https://forums.malwarebytes.com/topic/219928-mbam-taking-20gb-of-ram/
Also web Protection will not activate and that's part of the above issue too!!
https://forums.malwarebytes.com/topic/220045-web-protection-off-unable-to-contact-license-server/
Sometime errors on contacting MB servers too.
I have two laptops on line right now that run Malewarebytes Pro and I had to uninstall the app from both laptops to get out of the memory leak that's going on, The Malewarebytes Service will need to be killed in the task manager in order for the MB app to even uninstall and you may have to kill the service more than once to get it to uninstall but after reboot of uninstall the issue will be gone but so will the app be gone as well and I recommend leaving it that way until MB gets the issue resolved!
FIXED & and I must admit that was pretty fast but not as fast as the embarrassment was for them!
https://forums.malwarebytes.com/topic/220025-malwarebytes-has-been-hacked-uninstall/?page=4
EDIT: I can confirm that the database update to Update Package version 1.0.3803 does indeed fix ALL the mentioned TODAY issues!
"Hi everyone
This issue has been resolved. We have just released a patch for this issue with Database 3803. Please update to the most recent update database by clicking on Updates on the Dashboard.
Head here for more info:
Thanks,
Cecile"
