Mices making buzzing noise ?
25 (0.02/day)
Is it okay for gaming mices to make noise ? my both mices Redragon m711 cobra and CoolerMaster mm710 making same sound, but its louder on the mm710 ? i can only hear the sound when i put my the mouse close to my ear, could it be caused by non grounded outlet ? if yes is it okay ?
13,952 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I have never heard, or heard of a mouse making a buzzing noise before, let alone two mice. That is really odd.
Even if the wall outlet is not grounded to "Earth" ground (and you should get that repaired by a qualified electrician), the mouse should be connected to the system's "common" ground. So I don't see how it could be causing any harm.
What if you move the computer to a different and grounded outlet? Have you tried a different USB port?
What if you find someone with a laptop and try the mice there when the laptop is running on battery, do they buzz then?
468 (0.10/day)
Lithuania
Processor Intel Core i5 4670K @ 4.8 GHz
Motherboard AsRock Z87 Extreme 4
Cooling Lepa NeoIllusion RGB CPU cooler
Memory 2*4GB Patriot G2 Series RAM
Video Card(s) MSI Radeon R9 380 4GB
Storage Transcend SSD 740 256GB + WD Caviar Blue 1TB
Display(s) Samsung SA 300 24" Full HD
Case NZXT Phantom 530 + Bitfenix Recon fan controller
Audio Device(s) Creative SB0770 X-Fi Xtreme Gamer
Power Supply PC Power and Cooling Silencer MkIII 750W 80+ Gold
Keyboard Steelseries Apex RAW
Benchmark Scores IT WORKS
The only mouse I ever saw that make noise is Thermaltake Black Element Cyclone
As colleague said, you should try different system, or at least different USB port
259 (0.06/day)
System Name maipc
Processor 4790k @ 4.4Ghz / 1.16v
Motherboard Asus vii hero
Cooling Noctua NH-D14
Memory 16GB (2x8GB) Hyperx fury 1866 / CL10
Video Card(s) MSI RTX 3060 Ti Gaming X 8GB
Storage 1TB 860EVO + 1TB 860EVO + 4TB WD Red + 4TB WD Red
Display(s) Asus VG259QM (1080p IPS 240Hz)
Case Cooler Master Centurion 6
Power Supply Seasonic Prime GX-650
Mouse Logitech G Pro X Superlight
Keyboard Wooting 60HE
Software Win 10 64bit
Some mice can make sounds that are similar to coil whine.
My steelseries sensei RAW produces a high pitch noise.
But it can only be heard when I put my ear close to it.
3,419 (1.02/day)
Buenos Aires
System Name Ryzen Monster
Processor Ryzen 7 5700X3D
Software Windows 11 Start 11
Mouses, if you don't mind!
:D
Frick
Fishfaced Nincompoop
20,055 (2.87/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Keyboard Dell SK3205
Mouses has coils?
AsRock
TPU addict
19,255 (2.95/day)
UK\USA
Cooling D15
Mouses has coils?
Yeah really just a lens, crystal,caps, resistors and transistors, or and maybe a battery\leds.
I would try the mice on another computer and see if they still do it.
EDIT: seeing a lot more mouse problems popping up for as of late.
13,952 (2.04/day)
Nebraska, USA
Mouse Logitech M190
The thing is, there is only +5VDC and such a tiny amount of current in the mouse, it seems impossible (to me anyway) there would be enough potential to cause coil windings to vibrate enough to make audible noise.
7,607 (1.44/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
It is the RGB PWM driver that whines... Class II MLCC... cheapest you can get... so no that's not something surprising.
