- Apr 29, 2006
- 5,105 (0.74/day)
- Sydney, Australia
System Name | UltraPC |
Processor | E8500 Core 2 Duo, 1333Mhz FSB, 3.16Ghz @ 4.5GHz (got into Windows @ 4.75GHz) |
Motherboard | ASUS P5Q-e |
Cooling | CPU Cooler - TT V14 Pro, 2x120mm CM Blue LED fans, 1x90mm CM Blue LED fan |
Memory | G.Skill Pi 4GB (2x2GB) Dual Channel DDR2 PC8000 (1000MHz), 5-5-5-15 |
Video Card(s) | Sapphire HD4850 512mb with ASUS EAH4850 BIOS |
Storage | 2x 500GB Seagate 7200.12 Raid 0 |
Display(s) | Acer AL1912, 19" LCD screen |
Case | Thermaltake Soprano Black ATX case |
Audio Device(s) | Onboard 7.1, Speakers - 5 + Sub + Monitor speakers |
Power Supply | Thermaltake 850W Toughpower Cable Management - Quad (2x18A and 2x30A) 12V rails |
Software | Win 7 Pro x64, MSN, CS:Source, etc etc |
Hey everyone,
I got a big problem with my mobo. Firstly, its a GIGABYTE GA-8KNXP. The comp specs are on the side under my name (its exactly the same specs, just a GIGABYTE GA-8KNXP as mobo, not Foxconn 661-M03).
Now, here is the problem. I just put the board in and connected everything up. I push the power button on my comp, all the fans work, everything lights up, except absolutely nothing happens. Like, no writing or anything, just a blank screen (monitor dusnt even do nothing). After about 20-30 seconds, the computer just powers off again, without me touching anything. In the 20-30 seconds, the cd drives come out if u push the button and everything, it just doesnt do anything.
All help is GREATLY appreciated!
Cheers
Pinchy
Cheers
Pinchy
