My cpu overclock is no longer stable
529 (0.12/day)
st. louis missouri
Processor Ryzen 5 5600
Motherboard Asus b450F ROG Strix
Cooling 3 case fans plus deepcool maxx V2 cpu heatsink
Memory 16 GB Crucial Ballistix DDR4
Video Card(s) Zotac RTX 3060 TI
Storage 3 SSD's, 1 Samsung 970 Evo NVME and 2 sata (Crucial 1 TB and ADATA 480 GB) and 2 sata hardrives
Display(s) 27 inch Asus 75hz gaming monitor
Case NZXT h500i black
Power Supply Corsair cx650m 650 watt psu
Mouse Corsair M65 Pro RGB
Keyboard Inland RGB mechanical keyboard with blue optical switches.
Software windows 10 64 bit
Hey guys,
So I am having an issue with my cpu overclock, for some reason it is no longer stable. I built my pc about a year ago and set my system to auto overclock my cpu and it set my 2600k to 4.3 ghz. I ran several test and everything was good.
However my pc started acting up a couple of weeks ago. I would get blue screens and random game crashes. I disabled the overclock and set everything to default and my system has been fine, but I would like to get my overclock back. So what would cause my overclock to become unstable all of a sudden? Is this a sign of failing hardware or something else?
My main specs are an I7 2600k, asus p8p67 deluxe, gtx 1070 and an 800 watt psu.
Thanks.
44,267 (6.80/day)
Could be memory, board, psu, cpu...
What are your temperatures, what bsods were you getting?
7,973 (3.29/day)
California
System Name His & Hers
Storage lots of SSD.
By using auto OC setting you likely degraded your chip due to too high a voltage.
529 (0.12/day)
st. louis missouri
0x0000004e, 0x0000001a and 0x0000000a are the 3 error codes i retrieved from blue screen viewer. It also has a couple of memory erros. I have ran memtest several times and it has passed everytime, but I may get a replacement kit in the near future.
44,267 (6.80/day)
The first 2 certainly point at memory.
Check the built in event viewer and see if you can see anything right before it crashed
326 (0.16/day)
Nuremberg
Processor Core i7 8700K@5 GHz
Motherboard MSI Z370 Gaming Pro Carbon
Cooling 2xEKWB Rads, EKWB Reservoir 250, Aqua Computer Kryos Next CPU Cooler, Phanteks Glacier GPU Cooler
Memory 16 GB DDR4 GSkill Trident Z 3200
Video Card(s) Asus ROG STRIX RTX 2080 O8G (GPU@2115 MHz/VRAM@7800MHz)
Storage 1x Samsung Evo 840 SSD 256, 1x WD Blue 1 TB HDD
Display(s) Asus ROG Swift PG248 1080p Display/144Hz/G-Sync
Case Fractal Design R6 with Window
Audio Device(s) Realtek onboard
Power Supply be quiet 650W Straight Power
Keyboard Cherry KB
Benchmark Scores FireStrike: 25953/Extreme: 13141/Ultra: 7099/TimeSpy: 11426/Superposition: 7667/CinebenchR20: 3916
Could be degredation like oxrufiioxo said. If so you need higher VCore voltage to get stable again.
hat
Enthusiast
21,753 (3.23/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Could be memory controller, the memory itself, or the vcore now being too low...
7,412 (2.63/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
could be anything,but I have experienced some degradation on my 2500k
it was running 5050MHz though,on air.
Ruru
S.T.A.R.S.
13,770 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
My guess would be also degradation because of the auto volts. NEVER EVER use those damn auto-OC features just because of that.. :|
Also, Sandy Bridge overclocking just starts at 4.5GHz. ;)
529 (0.12/day)
st. louis missouri
Ok can you guide me with overclocking manually? I have attempted it myself but Im not very good at it and I seem to make things worse. I would check the event viewer but I havent had a bsod in sometime now since I have been running everything at stock for the past few weeks.
Ruru
S.T.A.R.S.
13,770 (3.05/day)
Jyväskylä, Finland
I have to admit that it's been a long time since I've played around with Sandy Bridge, I don't remember almost anything how to OC this platform so I need to learn it again.
I'm sure that someone else knows better. :)
326 (0.16/day)
Nuremberg
Keyboard Cherry KB
According to your system specs you have the ASUS P8P67 Deluxe. First I would check the VCore with CPU-Z in idle and under load. VCore in idle should be higher than under load. After that set your VCore in BIOS to manual mode and set the VCore to the value you get from CPU-Z in idle. Check again with CPU-Z the voltages idle and load and if there is a huge drop from idle to load you can adjust it in BIOS with the option Loadline Calibration. Choose a value starting from value „regular“ that you get nearly the same VCore in idle as under load. Then it‘s time to test oc. Raise frequency and check if it is stable, if not then raise VCore a little till you get stable and so on. Raise also CPU Current Capability to 140% that CPU can draw more power.
Edit:
Also set long duration Power Limit and short duration power limit to max, max value should be 255 or 256.
23,830 (6.15/day)
7 years is kinda the golden number for electronics in my book. Pump more voltage through and you can extend the life a bit. Then start saving.
326 (0.16/day)
Nuremberg
Keyboard Cherry KB
To test how far you can oc I would definitely use manual VCore first. After you know what your needed VCore is, for example to get 4.300 MHz stable, you can switch to offset mode afterwards.
FreedomEclipse
~Technological Technocrat~
24,779 (3.77/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Heres a good basic sort of guide but it explains a lot of the changes you'll need to make within the bios.
Vcore varies from chip to chip so 1.38v for my 2500k@4.9Ghz might take you 1.40v
if youre using the stock intel cooler, you'll want to throw that away and get yourself like a coolermaster Hyper 212 or a Snowman T4 or T6 from aliexpress if youre willing to deal with the shipping from China. (search on youtube for Snowman CPU coolers) Reviews have been extremely positive as far as i have seen and they are damn cheap compared to the bigger more well known brands that charge almost 2-3x more for their products.
This post here can kind of be an outline for a lot of the tweaking, especially when it comes to limits on voltages and temperatures. You can use it to cross reference my first link against this one but for Sandy Bridge. Keep it under 1.40v as much as possible on the vcore.
SB was super easy to OC - I had my 2500k at 4.9Ghz within hours of building it.
khinh
11 (0.01/day)
no one said anything about overheating? the component he have is decent just wonder the cooler he have
529 (0.12/day)
st. louis missouri
I have a thermalright 5 heatpipe tower style heatsink with an 140 mm fan.
I will have to check my voltages and get back to you guys.
And the auto oc would set my ram to 1680 mghZ. I tried to push it higher but when I did my system wouldn't even boot.
I also had my ram at 1600 mghZ which was more stable but for aome reason I can't set it back to that speed.
44,267 (6.80/day)
Thats fine for you considering I use a Scythe Ashura with the fx 8350 at 5.0G.
Have you pulled the cpu to verify any damaged/burnt pins, have you replaced the cmos battery?
326 (0.16/day)
Nuremberg
Keyboard Cherry KB
Disable your auto oc and do it manually. Do it first only with cpu to see how far you can push it and leave RAM with default settings. If you have your cpu stable then you can push your RAM higher. Watch always temperatures and VCore when you do stress tests with Prime95 or similar.
khinh
11 (0.01/day)
you need apply manual overlock forget auto oc and leave your ram to stock speed, sometimes your xmp profile is enables if can disable it, the overclock cpu carry overlock ram frequency as well. hope this help.
529 (0.12/day)
st. louis missouri
I have tried to in the past and wasn't successful, can you help or point me to a guide?
FreedomEclipse
24,779 (3.77/day)
Hello???
529 (0.12/day)
st. louis missouri
I apologise, I didn't see your full reply since I'm on mobile.
I will try what you suggested when I have some free time. For now I am going to leave everything at stock but I plan to overclock sometime in the future.
khinh
11 (0.01/day)
Run everything at stock until your computer boot up stable everytime consistently for about a month or longer. best to leave the overclocking, this is my best advice to you so you can maintain the system with longer running lifespan.
Apply this when overclocking
Disable your auto oc and do it manually. Do it first only with cpu to see how far you can push it and leave RAM with default settings. If you have your cpu stable then you can push your RAM higher. Watch always temperatures there should a limit best to not go over 70- 80c if it run consistent over 50 or just 60 above then leave it, and of course lower the temp the better it is and VCore when you do stress tests with Prime95 or Aida64. so temp if the system run on full load and struggle with it, best to get it lower temp even the overclock is not 4.3.
And remember stress test everytime you apply a new overclock.
