p_o_s_pc
F@H&WCG addict
- May 2, 2007
- 13,006 (2.10/day)
- Newark ohio
System Name | el'lappy|Cruncher | Cruncher 2 |
Processor | intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz |
Motherboard | some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3 |
Cooling | dual 80mm cooling fan | WC'ing ) |cheapo |
Memory | 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s |
Video Card(s) | onboard | 60 1GB(hd7770 ) |8800GTS |
Storage | Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD |
Display(s) | 17in | 42" 1080P HD 3D TV |
Case | lappy case | CM HAF XB |none yet |
Audio Device(s) | onboard | onboard | onboard |
Power Supply | Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon) |
Software | Windows 7 Ult. 64bit---->-------> |
I need advice on what heatsink to get for one of my rigs its a Celeron D 3.3ghz in a Micro ATX Emachines case i will NOT be overclocking i just want to replace it because i can't sleep in the same room when its on and temps are too hot (52-60c idle) If needed i can take a pic of the inside of the case. I was looking at the Xigmatek HDT S963 but not sure if it would fit. If it won't could someone place recommend a somewhat cheap heatsink that will?
EDIT: nevermind only need advice on 1 rig now
