Need help Custom Loop
I'm jealous my strix hits 68/69c heavily overclocked though.
That's the reason why you need a custom loop ;). The Nvidia boost scales every step with 15 MHz up or down. If you have for example 2100 MHz gpu clock with 68 degrees you will achieve easily 2130 to 2145 if you can settle it as about 50-55 degrees. Sure that's not that much but a few fps more in games or better values in benchmarks.
Here is my Superposition value:
Not that bad and in front of many other RTX 2080 users. Cranked up the memory with 1100 MHz and the GPU to 2130 MHz. The assured oc mode boost clock of Asus is 1980 MHz, so pretty more.
Outperformed a few 2080 Super also, lol
My strix hit 72-74 during gaming too and the boost clock drops below 2ghzNow it stays above 2.1ghz all the time. But Im not sure about taking care of the loop. Do we need to replace the coolant every few months? And need to clean the cpu block and gpu block?
My loop now runs for 1 year without replacing water. Temps are still the same, but I think I will replace it in the next few months, just to get new color in it ;)
I dont like the mounting mechanism of this block. Thats why I order a different one and see of anything good happens.
I have the same block and encountered some self foot shooting during my initial install. I think it's a good system, but I did a poor job using it
I tightened down one or more of the posts too much so when I got to the last one I just couldn't seem to get a good grab into the female threads. But I kept trying and got it in there and it held but when looking at the MB from the rear it was apparent that last post I tightened was not quite as deep as the others. This being my first time using such a device I thought, well, do I need to be that picky, it's on and holding and that is what counts. So I left it as is. Actually, I took it off, and did the same thing because the paste looked like it had a good spread/pressure from the mounting so I put it back on in the same fashion.
However, about a week or two later I noticed my temps were going up a couple degrees. Then I happened to touch one of the posts and heard a little metal popping sound and went "oh fuck" lol. Just lightly touching that post made it come out of the female threads. Temps got real bad after that and couldn't handle the 5.1GHz all core OC I had going on anymore, even at a respectively low voltage of 1.3V
I could feel if I shoved on the particular corner of the block that it had just the slightest amount of give to it. I knew what I did and had to just suck it up and fix it. Drained my loop and had to uninstall everything since I had to get the MB out and put the block on properly.
This time around, I made sure to get a little bite on each of the blocks posts before tightening them down as far as I can. results looked much more even when looking at the MB from the rear. I haven't had an issue since. Nothing was at fault of the block or mounting mechanism, it was my inexperience and being complacent with what I kinda sorta thought was a poor mounting job the first time around.
So if you think your temps are high because of mounting pressure then remount it making sure you get good even pressure.
Otherwise, I think your temps are totally normal given that OC you have on there. My spikes are in the same range. Again, those are SPIKES not where the general avg temp is.
5.2ghz 1.36v in bios load during realbench hits 1.376v. Max spike 75, avg temp is around 70. All fans stay at 1300rpm and I just hear some air moving from my case
In perusing the thread .... some things for now and some things for the next build.
1. Look at this thread for info on selecting appropriate radiator size. You can download a simple spreadsheet based radiator size calculator which is based upon test data from MartinsLiquidLab.
CPU = 180 watts
GPU = 360 watts
So with a total theoretical maximum water cooling load of 540 watts ... Accounting for the fact that peaks are intermittent, much heat is surface radiated, we'd be looking at a radiator load of about 60% of the theoretical max or 324 watts
With 1250 rpm fans, a medium thickness rad should deliver about 183 watts of cooling. The 280 about 166 with just one set of fans in push blowing into the case ... If you use as exhaust, you will have to de-rate that performance. That totals 349 watts which should give you a Delta T of about 9.23 C. Your radator shrouds, tubing, fittings and the blocks themselves will all radiate heat.
2. I generally recommend rads with the following features:
a) Two bottom ports
b) Two top ports
c) Two side ports (not critical)
d) Drain port
e) Screw protectors
In the pic above it's about 50mm to the bottom of the case grille. I used a a MxM adapter and a 400mm FxF extension and cap to extend the port from one the top rad ports w/ cap to just below the case grille. This makes an ideal fill port. Build a portable extension to use when filling the system ... with a 12" rigid acrylic tube, MxM fitting, (2) tube adapters, and valve, Take the screw cap cap off, attach your fill tube placing funnel in top of valve until system appears full and the acrylic tube is about 85% full. Close the valve and run the system.
As the system runs, the level in the tube will drop and air will collect on its place.... 'Rinse and repeat refilling the tube a few times closing the valve and running till all coolant is gone from the rier tube .... Tilting the case as needed.
2. As for the bottom drain, the above pic is one design we incorporate often. Of course, both these things no workie if you only have 2 ports. To what you see, I add an extension a Quik-Disconnect fitting, the other half of which is on a 36" flex tube for draining into a bucket.
Those side ports can be used for temp probes measuring the in and out temps at each rad ... Can display those on a Reeven 6 eyes.
3. For the reservoir, recommend a 3 port top. One is used as fill tube which extends below the water line, preventing splashing which make the coolant absorb air. Another port make a convenient bleed port to adjust water level.... Leave about 15% of res height unfilled.
4. As to the temp question ... CLCs generally operate at about a Delta T of 20C, you will be under 10C. The custom loop will make the H115i look like a toy ... And with far, far less noise... Your system should never break 850 rpm. With SLI systems and close to 600 watts of GPU power, a good block should deliver temps in the 30s at 1250 rpm... I would run mine at 800 or so rpm and GPU temps would be 42-44C/ CPU would get into mid to high 70s under ROG Real Bench. That box hit 50s - mid 60s in gaming. If you are sitting in front of the box in those pics, you can not tell the system is running a stress test ... it's completely inaudible and that box had twin 300 watt GFX cards. Compare that with the Cosair AIOs which are 50-60 dbA ... that's 6 - 8 times as loud.
5. Prime95 and other synthetics will reduce your potential OC as it will cause temps that the system will never see. Kinda like testing your SUV to see if it can tow your SeaDoo to the shore 8 miles away by testing by towing a flatbed up the rocky mountains. And since RB is a multitasking stress test I find that 24 hour stable OCcs are unstable under the last RB test. P95 is a great tool for rapidly cycling temps up into the 80s and back down to room temps to cure your TIM.
6. See fill procedure for getting rid of entrapped air back in item 1
7. Unless you go all out gorilla w/ the screwdriver, the EK blocks should prevent you from over tightening... you are looking for about 70 pounds of clamping force
8. No, there is no way to make the coolant cooler w/o chilling it. You never want your coolant temp ever to be lower than ambient air. This causes condensation.
9. Happy to see your are using RoG RB .... I am surprised that you are not seeing the typical Intel voltage bump of about 0.13 when AVX instrutions are present
