Need help OC'ing OCZ DDR400 RAM
at0msk
32 (0.01/day)
I've recently installed 4GB of OCZ DDR400 PC3200 RAM. Previously I only had 2GB. CPU-Z would report the following and Vista gave my RAM a performance rating of 5.9.
After adding 2GB more to up the RAM in my system to 4GB I had to drop the BIOS to defaults for RAM and now Vista reports my RAM as 4.8 based on the timings. The current CPU-Z captures are as follows along with BIOS shots. I'm not sure how to do it but I would like assistance OC'ing this RAM if possible. Even if just by a little.
Current Memory Timings and CPU
BIOS:
CPU
DDR Voltage Menu
Memory Settings (not current)
ASUS A8N-SLI Premium board, 1303 BIOS
Any help would be greatly appreciated.
1,043 (0.15/day)
USA
I can't remember what the safe voltage levels for DDR1 were (2.7?), but bump the voltage and see if it can clock higher. As the bus speed increases, more chipset voltage may be required.
sneekypeet
not-so supermod
29,711 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
so did someone OC this rig for you or whats the deal?
If you go into bios and reset the same setings you had previously the ram should run at 255MHz again, as long as the 4 sticks play well together.
First of all I would OC the second set by itself and see if it was capable of running the same spec as the first set. At that point you should already have the timings and voltages from before to use.
The screenshots show
#1 timings that they used to run at...those need to be set in bios.
#2 tighter timings set by SPD on the ram...why they wont OC well.
#3 only thing is as said before, may need to bump the chipset voltage to suppord 4GB of ram.
#4 I say 2.8-2.85V without a fan.
#5take timing mode and set it to manual, then apply the timings from image #1. Also you need to change the memory divider to run 1:1 with the FSB again to achieve this.
at0msk
32 (0.01/day)
The chipset voltage only goes to 1.6. :( I do not think there is hope. :(
p_o_s_pc
F@H&WCG addict
13,006 (1.98/day)
Newark ohio
System Name el'lappy|Cruncher | Cruncher 2
Processor intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz
Motherboard some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3
Cooling dual 80mm cooling fan | WC'ing ) |cheapo
Memory 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s
Video Card(s) onboard | 60 1GB(hd7770 ) |8800GTS
Storage Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD
Display(s) 17in | 42" 1080P HD 3D TV
Case lappy case | CM HAF XB |none yet
Audio Device(s) onboard | onboard | onboard
Power Supply Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon)
Software Windows 7 Ult. 64bit---->------->
what was CPU speed before? (bus and mult)
1,192 (0.18/day)
scotland
System Name spuds K8-X2
Processor amd athlon X2 4200+ toledo s939 2794mhz 254x11 1.4 vcore
Motherboard MSI K8N Neo4-F v1.0 (MS-7125) nforce4 sata2 mod, laptop cpu heatpipe copper nb cooler
Cooling akasa evo "blue" + 90mm fan, 2x120mm front, 250mm side, 120mm rear, 120mm in psu, pci slot exhaust.
Memory OCZ Platinum XTC DDR PC3200 4GB(4x1024) @254mhz 3-3-3-8 2T
Video Card(s) sapphire HD3870 512mb GDDR4 vf900cu, several ramsinks on components / nvidia 7300gt 256mb secondary
Storage hitachi 160gb (slightly fried) / hitachi 120gb ATA / Seagate 160gb / 2x ps3 seagate 60gb
Display(s) CTX EX1300F 20" flat CRT, 1280x1024@100hz / 19" benq FP91G X / 19" hanns-g (all free)
Case mesh server/gaming black case, 9x 5.25' drive bays, silvestone auto fan controller
Audio Device(s) onboard realtek alc850 7.1/soundblaster LIVE! ct4780 + kxaudio - sony home theatre surround
Power Supply winpower 650w, system draws around 470-500w under load(+all screens)
Software win7 64bit
Benchmark Scores ~16m trips/sec using mty trip generator. triple monitor gaming using SoftTH. 3840x1024
heres what im running mine at, cpu speed is meant to be 2750(250x11) default is 2200(200x11)
2.8v is default for these sticks
2,265 (0.38/day)
System Name Budget AMD System
Processor Threadripper 1900X @ 4.1Ghz (100x41 @ 1.3250V)
Motherboard Gigabyte X399 Aorus Gaming 7
Cooling EKWB X399 Monoblock
Memory 4x8GB GSkill TridentZ RGB 14-14-14-32 CR1 @ 3266
Video Card(s) XFX Radeon RX Vega₆⁴ Liquid @ 1,800Mhz Core, 1025Mhz HBM2
Storage 1x ADATA SX8200 NVMe, 1x Segate 2.5" FireCuda 2TB SATA, 1x 500GB HGST SATA
Display(s) Vizio 22" 1080p 60hz TV (Samsung Panel)
Case Corsair 570X
Power Supply Seasonic X Series 850W KM3
at0msk
32 (0.01/day)
Sigh. I've tried. Thanks for all of your suggestions. I'm not sure what the problem is. The system either halts at BIOS or Windows reports a corrupt/missing system file until I set the default timings for the RAM. :(
Edit: I forgot to set the Read to Write Delay to 4T from 6T when trying spud's timings. Would that have made a difference though?
sneekypeet
not-so supermod
29,711 (4.27/day)
System Name EVA-01
I seriously think the second set of ram isnt as capable as the first set you started with. Possibly the Ram doesn't even have the same IC's. As I stated, test both kits seperatly before you try to run it all at once.
If my hunch is correct one set will clock as it did before and the other will not clock near as far.
at0msk
32 (0.01/day)
I see what you're saying there. The only thing I'm getting caught up on is that these aren't just similar sets of RAM from the same manufacturer. They are the same. I bought two, saved, bought two more. I'm not mixing RAM here.
*I did try spud's timings to the letter. Windows just reported a corrupt system file.
sneekypeet
not-so supermod
29,711 (4.27/day)
System Name EVA-01
Well as it is in the ram world, IC's can last for months as the same chips or weeks depending on how much they bought for a run. They may be the exact same kit by part number, but as production moves down the road, memory manufacturers can swap the IC even if its just a revision. Also not every part is created equal. The ram is sold as DDR PC3200. this means it is only spec'd to run that, no guarantee that every set of ram they make clocks the same.
at0msk
32 (0.01/day)
So disappointing to not get what you paid for. :( I can't say either way here. I'll just chalk it up to that and leave this alone. I'm just happy it runs at DDR400.
p_o_s_pc
F@H&WCG addict
13,006 (1.98/day)
Newark ohio
as i see it you did get what you paid for. You have it running ddr400 and you paid for ddr400 everything else after that is just a bonus
at0msk
32 (0.01/day)
touche, sir, touche
To clarify though, I would expect to get the exact item. No revisions hidden behind the same model number. Just 100% exactly the same. As one would expect from a production line.
at0msk
32 (0.01/day)
As a consumer, I say better QA on the manufacturers part. When you get down to it, even the slightest change to a product warrants notice. If I buy RAM A and then a few weeks later buy a second set of RAM A but the manufacturer made a revision it's not RAM A anymore and should be sold as such. When I buy a second set of RAM A, I want a second set of RAM A not RAM A revision 3.4.5.3zalphapoop. I see this as false advertising and not getting what I paid for.
1,192 (0.18/day)
scotland
Software win7 64bit
at0msk
32 (0.01/day)
dont know if you seen this page,
http://www.ocztechnologyforum.com/forum/showthread.php?t=15898
i got the settings for mine from here,(http://www.ocztechnologyforum.com/forum/showthread.php?t=19883) but i used the timings from a pc4000 set.
That's cool. I see this post here: http://www.ocztechnologyforum.com/forum/showpost.php?p=129912&postcount=3
Do I have to mirror the Jumper Free Configuration?
Current CPU Configuration
Timing Mode: Auto
Memclock index value: 333 mhz
Cas latency (TCL) : 2.5
Min ras active time (TRAS) : 5
Ras to Cas delay (TRCD) : 3
Row precharge time (TRP) : 2
Row Cycle time (TRC) : 19
Row refresh cycle time (TRFC) : 21
Read-to-write time (TRWT) : 6
Write recovery time (TWR) : 2
1T/2T memory timing : 2
S/W Dram over 4gb remapping : Enabled
H/W Dram over 4gb remapping : Enabled
Hyper transport frequency : 4
Amd K8 Cool'nQuiet : Disabled
Current Jumper Free Config:
Overclock profile: Manual
CPU frequency : 255
PCI Express : 100mhz
DDR voltage : 2.8
Chipset voltage : 1.5
HT voltage : 1.20
CPU multiplier : 11
CPU voltage : 1.450
PCI clock syncronization mode : Auto
JrRacinFan
Served 5k and counting ...
20,126 (3.04/day)
Youngstown, OH
System Name Snow White
Processor Ryzen 7900x3d
Motherboard AsRock B650E Steel Legend
Cooling Custom Water 1x420
Memory 32GB T-Force Deltas
Video Card(s) PowerColor 7900 XTX Liquid Devil
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Tt CTE 600 Snow Edition
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Corsair K65 Mini
Benchmark Scores Avermedia Live HD2
Try your chipset voltage up a notch. Sorry it's been a long tme since I OC'd DDR1. Try for 3-3-3-8 and work your way from there.
