Need help troubleshooting internet connection
1,018 (0.14/day)
Processor 2500K @ 4.5GHz 1.28V
Motherboard ASUS P8P67 Deluxe
Cooling Corsair A70
Memory 8GB (2x4GB) Corsair Vengeance 1600 9-9-9-24 1T
Video Card(s) eVGA GTX 470
Storage Crucial m4 128GB + Seagate RAID 1 (1TB x 2)
Display(s) Dell 22" 1680x1050 nothing special
Case Antec 300
Power Supply PC Power & Cooling 750W
Software Windows 7 64bit Pro
I'm trying to fix my girlfriend's family computer without much luck so far. They cannot connect to the internet with either explorer or firefox. We took it to our place, can't get an IP address from the router (hardline connection). Ran antivirus in safe mode, tried turning off antivirus and firewall, nothing helps. Put in a PCI ethernet card, still can't acquire an address so it's not the MB port that died. Loaded XP on an extra HD I had around and it access the internet just fine so it is a software setting and not hardware. Anyone have any ideas I can try later tonight when I get home from work?? Thanks in advance.
Only thing I can think of off the top of my head for you to try is to re-install both chipset and ethernet drivers. Good luck .. :)
Does you ISP use a dynamic IP or a static IP?? This has caused problems for me in the past. Going through the router, you should set the machines IP to dynamic, but if your ISP uses a static IP, you should set the routers IP to static.
Using a router, tried letting the pc acquire the IP automatically and tried setting it up manually. With the clean hard drive the system connects no prob. using auto settings.
I thought about that too but with the PCI card unable to connect I figured that kind of ruled that out.
if all things don't work.. try to reformat the pc while the internet connection is still plug-in maybe it was set-up on an offline mode...
or just fix it :P
