I have the same board/cpu and was worried about the new normal high tempts and vcore compared to my Ryzen 2600. At build I put on a new Wraith Prism cooler with it's stock TIM. Set on it's highest it would get over 80*C gaming, Yikes! I pulled the cooler to put on some Arctic Silver 5. I realized the base of the cooler was complete rubbish in it's design with it's exposed, uneven heat pipes. I had a Vanilla Wraith cooler from the 2600, with it's solid copper base. It is a few mm's shorter with it's fins though, but the same in every other dimension. I put the RGB fan assembly from the Prism on to the Vanilla, with AS5, and the temps have lowered in to the 70's now. Still higher then I like, but I'll live with it. I leave it at stock in the bios and run the Ryzen Balanced power plan. I wont be oc'ing nothing in this rig. I am happy with it's stock performance, minus the temps and power draw. (pics are web examples)
Pairing these new chips with a good cooler and good TIM is a must. I will prob keep my Ryzen 2600 around in case the 3600 cooks itself.
