Need help with a $600 build for a friend.
  • Thread starter Deleted member 27327
  • Start date
So I have been asked by a friend to help her build the best possible computer for $600 that would allow her to do all her normal things like Facebook, watch movies, check emails and so forth. She also mentioned she wanted to play some games such as Diablo III, Skyrim and others that I may suggest to her. My problem is that I have only $600 to get this done and everything is needed to be purchased including a monitor. The only thing I might be able to get a hold of without purchasing is a case. Already have a keyboard/mouse to give her.
Just as a quick note I want to say that I am fairly close to Micro Center which I know seems to have the best pricing on CPU's.
CPU: Thinking AMD Phenom II X4 965 Black Edition, but not set. Was told i3 might be better?
Motherboard: Must have onboard sound.
Memory: 8gb
Video: Thinking 6870, but not set.
PSU: ~600watt needed in case she wants to learn to overclock as well.
DVD-RW: Any is fine. Cheaper is better.
HDD: 500GB is fine. Sadly hdd's have gone up in price and stayed there.
Case: Not 100% sure this is needed as I might be able to get one for free.
Monitor: At least 19-20in, but larger wont hurt if price difference is small. I have seen a few 21in for $130.
OS: Windows 7 64bit not counted into the $600.
Any help and/or suggestions are greatly appreciated. I have never had to build a system for someone with such a small $ limit.
Feänor
512 (0.08/day)
A Sandy bridge pentium will be as good as a phenom, gaming wise :70-100$
Some small lga1155 motherboard: around 80$
8gb of Samsung 30nm ddr3-1600 (my personal choice, pickup whatever suits your need): 50$
Corsair 430w power supply (good 28A 12v), again pickup any good brand special:50$
Monitor wise a 21 inch can be found in the 120$ zone (in my area at least)
Spinpoint F3 1 tb hard drive 80$
Some radeon 6850 or 6790 140$
A little over 600$ when taxes and shipping are added, but you could downgrade the video card and/or the hard drive a little.
Fourstaff
10,024 (1.90/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
I would pick the Sandy Bridge route, price wise they are more or less the same but power consumption in SB is much better. 500W should be plenty.
If anyone can suggest a better PSU, Memory, Monitor, or HDD for the price that would be great.
CPU: Core i3 2100 - MicoCenter - $97.43
Motherboard: ASRock H61M/U3S3 - Newegg - $60
Memory: G.SKILL Value Series 8GB - Newegg - $40
Video: XFX 6870 - Newegg - $140 (Comes with Dirt 3)
PSU: Corsair CX600 - Newegg - $43
DVD-RW: Samsung 22x DVD Burner - Newegg - $15
HDD: 500GB Samsung Spinpoint F3 - Newegg - $80
Case: NZXT Source 210 - Newegg - $34
Monitor: Acer G215HVAbd - Newegg - $105
OS: Windows 7 64bit (not counted into the $600)
Sell Dirt 3 for about $10 and end up only $4.43 over budget.
4,012 (0.75/day)
Sarasota, Florida, USA
System Name Awesomesauce 4.3 | Laptop (MSI GE72VR 6RF Apache Pro-023)
Processor Intel Core i7-5820K 4.16GHz 1.28v/3GHz 1.05v uncore | Intel Core i7-6700HQ @ 3.1GHz
Motherboard Gigabyte GA-X99-UD5 WiFi LGA2011-v3| Stock
Cooling Corsair H100i v2 w/ 2x EK Vardar F4-120ER + various 120/140mm case fans | Stock
Memory G.Skill RJ-4 16GB DDR4-2666 CL15 quad channel | 12GB DDR4-2133
Video Card(s) EVGA GTX 1080 Ti Hybrid SC2 11GB @ 2012/5151 boost | NVIDIA GTX 1060 6GB +200/+500 + Intel 530
Storage Samsung 840 EVO 500GB + Seagate 3TB 7200RPM + others | Kingston 256GB M.2 SATA + 1TB 7200RPM
Display(s) Acer G257HU 1440p 60Hz AH-IPS 4ms | 17.3" 1920*1080 60Hz wide angle TN notebook panel
Case Fractal Design Define XL R2 | MSI
Audio Device(s) Creative Sound Blaster Z | Realtek with quad stereo speakers and subwoofer
Power Supply Corsair HX850i Platinum | 19.5v 180w Delta brick
Software Windows 10 Pro x64 | Windows 10 Home x64
I'd love to say that monitor is a good deal, but I bought one last week and it is quite washed out and has poor viewing angles (honestly my 6yo Samsung 940BW and the 7yo Dell I found at the curb look a lot better). Wish there were more options in that price range as anything reasonable is like $140+. :(
Is a 1600*900 monitor out of the question? HANNspree HF Series HF205DPB Black 20" 5ms Widesc...
I had a 28in Hannspree monitor some years back and had terrible issue with ghosting. Since then I tend to stay away, but if its gotten better than it should be looked at.
JrRacinFan
Served 5k and counting ...
20,073 (3.21/day)
Youngstown, OH
System Name Dual Build Streamer
Processor Ryzen 7900x3d : Ryzen 4600G
Motherboard AsRock B650E Steel Legend : Giga B450i Aorus
Cooling Custom Water 1x420 : Stock
Memory 32GB T-Force Deltas : 16GB Dominator Platinums
Video Card(s) PowerColor 7900 XTX Liquid Devil: iGPU
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Custom White Painted Phanteks Enthoo Pro 2
Audio Device(s) Onboard : Onboard
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Hyperx Origins 65
Your ram can be dumbed down a notch. Remember the H6x board's don't support over 1333 unless running an Ivy proc.
Also this might end up getting you under-budget a little.
Computer Parts, PC Components, Laptop Computers, L...
PowerColor AX7770 1GBD5-2DH Radeon HD 7770 GHz Edi...
G.SKILL NS 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1... (Unsure if you want 8GB or not)
EDIT:
OH btw, Good choice on board. Got the same model on the way from 'Egg myself for the HTPC upgrade.
Here's an alternate ....
http://www.techpowerup.com/forums/showthread.php?t=159827
The ITX bundle.
4,012 (0.75/day)
Yeah, I have a friend who has 2 Hanns-G 20" monitors and she's fine with them. My new work Acer is fairly ghosty as well (my 5ms 1080p TV was the same way) but maybe I'm too used to my 2ms ASUS VG236HE 120hz monitor. I suppose it depends on the model as it seems like every company has great and terrible models regardless of the price.
Good luck in your quest for a nice, on budget build. :)
JrRacinFan: Thanks for posting buddy as always. The reason I want to get 1600 memory for her is in the case she decides she wants to move up to an i5 she is ready to go. Plus price difference due to MicroCenter is $3 from 8gb of 1333.
Jstn7477: Thanks I will keep that in mind.
I will take her to the local Fry's to have a look at a few monitor so she can decide on her own. I am hoping I can talk her to pay a little more to get a lot better since a monitor is something you can keep even when upgrading the computer.
Should order the whole setup tomorrow so I will post final results of order and how everything turns out 2-3 days later depending how long Newegg takes with Shoprunner.
JrRacinFan
20,073 (3.21/day)
Youngstown, OH
Storage 20+ TB
You're pricing counterparts between the 2x2 and 2x4? What I am saying is 4GB may be enough that's all. If you can get faster ram and just underclock/undervolt then by all means :rockout: Likewise, you're always welcome. :)
JrRacinFan
20,073 (3.21/day)
Youngstown, OH
Storage 20+ TB
