need help with oc-ing
DOM
7,628 (1.17/day)
TX, USA
Processor Intel i7 4770K
Motherboard Asrock
Cooling Water
Memory Team Xtreem LV 16GB (2x8GB)
Video Card(s) EK Full WB HD7970
Display(s) CROSSOVER 27Q LED-P 27"
Case Danger Den Torture Rack
Power Supply CORSAIR Professional Series Gold AX1200
Software W 10 Pro
what about SPD tab
DOM
7,628 (1.17/day)
TX, USA
Motherboard Asrock
Cooling Water
Software W 10 Pro
this one have you checked it yes lol
beck92
30 (0.00/day)
btw when i take a screenhot, paste into paint and save it i cant upload it here how should i do to be able to upload those images?
p-jack
333 (0.05/day)
Arheilgen
System Name Ironjack
Processor AMD Opteron 165 @ 2,4GHz, stock voltage
Motherboard Asus A8N-E (nForce4 Ultra)
Cooling Scythe Infinity, Thermalright HR-05SLI, AC AcceleroX1Rev.2
Memory 2x1024MB Patriot PC3200 @ 2,5-4-4-8
Video Card(s) Powercolor X1900XT 512MB @ stock clocks
Storage 320GB Seagate ST3320620AS, 160GB Samsung HD160JJ
Display(s) BenQ FP91GX 19" TFT
Case Coolermaster Centurion 534
Audio Device(s) Realtek ALC850 (onboard)
Power Supply Coolermaster iGreen 430W
Software Ubuntu 6.10 + Windoofs XP
tpu image uploader located here:
http://www.techpowerup.org/upload.php
p.s. when i said the temp sensor was "off" i meant that it probably is inaccurate... sry i should make myself more clear, but also i´m not a native english speaker...
beck92
30 (0.00/day)
well here is the SPD
Module Size: 1024 Corection:none
max bandwitch: PC2-4300 (266 Mhz)
manufacturer: kingston
part number: KC6844-ELG37 EPP: NO
TIMING TABLES:
FREQUENCY 200 mhz 266 mhz 266 mhz
CAS# Latency 3.0 4.0 5.0
RAS# to CAS# 3 4 4
RAS precharge 3 4 4
tras 9 12 12
Trc 12 16 16
WELL now i have submittet my ram,SPD, motherboard and bios. So how much should i overclock each of these things? how do i do? what do i do if computer wont start after overclocking. how do i see the results after ocing.
BTW: when i look in CPU-Z THE core speed is almost all the time 1596 mhz and almost never 2394 mhz even though i have a duo 2,4 ghz processor is this normal?
beck92
30 (0.00/day)
WHAT IS THE BEST TO INCREASE? BUS SPEED OR MULTIPLIER right now my bus speed is 266 and the multiplier switches between 6 and 9
caveman_1990
269 (0.04/day)
Sydney, Australia
Processor Intel C2D E6600 [380fsb] 3.42Ghz (O.C)
Motherboard ASUS Commando bios ver.1001
Cooling CPU :ZALMAN CNPS9500 WATERCOOL MOD CASE:120mm LED front,2X80mm exhast
Memory A-DATA Vitesta DDR2 800(380mhz) with Pentium 3 HSF
Video Card(s) SPARKLE 7950GT DIY HSF with 2X80mm fans oc'ed(core:600 mem:1600)
Storage SAMSUNG SP2504C (250GB)
Display(s) BENQ FP71G+ 17inch
Case icute 0408SL series
Power Supply cheap ~_~"" 500w
Software FULL OF PORN
BECK92 just click on the left of my box and there is a CONTACT WITH MSN just click on that and add me ok =)
DOM
7,628 (1.17/day)
TX, USA
Motherboard Asrock
Cooling Water
Software W 10 Pro
beck92 ur MEM is 533MHz, and on CPU-Z thats what I noticed with the 1.39v of CPU-Z is that it shows MULTIPLIER at the lower # and thats why the speed is lower when its does'nt have any load so its normal cuz mine is like that, and it better to Increase the BUS SPEED cuz with the MULTIPLIER at 9 since your ram is lower but since its a dell right ? your going have to do it in windows
PuMA
724 (0.11/day)
Finland
Processor lapped C2D e6850, 3600mhz
Motherboard ASUS P5N32-E SLI (680i SLI)
Cooling NOCTUA NH-U9, 3 2x120mm 1x180mm case fans
Memory 6GB A-DATA vitesta DDR2 900mhz (2x1gb + 2x2gb)
Video Card(s) LEASTEK GTX 260 (701/1408/1105)
Storage SAMSUNG F1 640GB SATAII/SEAGATE 250gb SATAII
Display(s) SAMSUNG 226BW 1680x1050 2ms
Case ANTEC three hundred
Audio Device(s) ASUS SupremeFX, SONY surround AMP
Power Supply XION 630W
Software VISTA ULTIMATE x64
Benchmark Scores 3dmark06:15126 (701/1408/1105) vantage: 11698
Intel's has this speed stepping option right?? u might want to turn it off if ur want to OC the right way
beck92
30 (0.00/day)
ok well i heard many ppl saying dell are hard to oc... is it because they got bad vent or what? how much do u ppl think i should increase my bus speed to?
if i take from 266 to 300 will there be any problems? overheat, or causing it to run unstable or any bad things?
beck92
30 (0.00/day)
well running torture test now, it has run for 15 minutes now and is on test 8 my temp is around 55 C on both cores and i havent even overclocked it yet. should i get another vent?
beck92
30 (0.00/day)
10 minutes later: it doesnt seem to go higher than 56C.. is this very bad?
beck92
30 (0.00/day)
omg omg!!! pressed f2 whilse starting computer and entered setup... once there it says none of these settings are changeable!!! CAN IT REALLY BE RIGHT??? its a dell and on another forum a guy said u couldnt overclock this processor!!!! WTF??? wtf should i do??
it cant be inpossible !! isnt there another place were i can change fsb??
caveman_1990
269 (0.04/day)
Sydney, Australia
The reason that you can't change your fsb or anyother setting e.g. vcore is because your BIOS (Basic input output system) doesn't support any of those setting. Many of the motherboard that is 3~4 years old doesn't support overclocking features.
There is 2 way to solve this problem:
1- Flash your BIOS but I wouldn't recommanded and I am not expert in flashing.
2- The easier way is just buy a new motherboard. When you buy a mother baord choose:
gigabyte
asus
msi
some intel board e.g bad axe 2
abit
BFG
DFI
and even some foxconn board they have become pretty good in oc'in recently.
When buying choose the one with an award BIOS and the more mb a BIOS has the more feature it have. e.g my board have 8MB most board have 4MB
beck92
30 (0.00/day)
but its a brand new computer... 2 -3 months!! arent there any programs i can use?
1,124 (0.18/day)
Chicago
Processor Amd Ryzen 5 5600x kryonaut paste
Motherboard Asus Prime X570 P bios 4021
Cooling Thermaltake Water 3.0 360mm (top mounted for exhaust) 3 Thermaltake 140mm riing rgb case fans
Memory G.Skill Trident Z Neo DDR4 3600 cl16 2x16 dual rank
Video Card(s) Sapphire Nitro+ RX 5700XT OC
Storage Seagate Firecuda 520 500gb NVMe PCIE Gen4 x 4 boot drive XPG S70 Blade Gen 4 x 4 NVMe gaming drive
Display(s) MSI Mag321CQR 32 inch curved 144 hz 1ms
Case Thermaltake View 31
Audio Device(s) Corsair Void USB RGB Dolby Digital 7.1 Headphones
Power Supply Thermaltake Grand RGB 750w
Mouse Corsair Harpoon RGB
Keyboard Corsair K55 RGB
Why did you buy a dell anyway?
caveman_1990
269 (0.04/day)
Sydney, Australia
It doesn't matter when you bought it. The only thing that is stopping you from oc'ing is the motherboard and the BIOS. I can buy a motherboard which is 4 days ago and I still can't oc because the board is not manufactured for overclocking. Do you see what I mean Beck92?
