need some help with ps3
Corduroy_Jr
1,102 (0.19/day)
barrie ont
Processor Phenom II 965
Motherboard Biostar TA870+
Cooling Zalman CNPS10X Performa
Memory Kingston hyperx 1600mhz 2x8gb
Video Card(s) ASUS Radeon HD 6870 DirectCU II 990/1250 stock volts
Storage Seagate 500gb, Wd 1tb black
Display(s) SAMSUNG 2433BW 24
Case Thermaltake v3 black edition
Audio Device(s) onboard, Logitech x540
Power Supply Antec true power modular 650 watt
Software Windows 7 x64 ultimate
any place in tpu, to get help setting up my ps3 to get online with secondary computer over the network
The computer has internet and you want to route it to the ps3? Like though another ethernet port..?
yeah, m2n sli deluxe has dual lan, one port i have connected to the net naturally the other lan port i wanna get online with ps3
i like tpu so i thought i post hear first, i was guessing there was support consoles too, tnx all ill look for official ps3 forums for help
first computer is connected by isp modem no router, second computer is connected over the network by wired lan, I'm basically trying too hook up second computer that has dual lan to ps3
How is PC2 connected to the internet? you have only one modem with only 1 connection im assuming connected to pc1. so where is pc2 plugged into.
pc2 is connected to pc1 with wired lan. goes like this pc1 gets connected by isp modem, then with second add on pci lan card installed on pc1 i connect that to from pc1 to pc2, so pc2 has dual onboard lan one port I'm not using which i wanna connect ps3 to it
ah ok. settings should be the same as on pc1.
i highly recommend purchasing a router. as for this all machines have to be on to get networking to the ps3. and when using the ps3 now, the other machines will be working to give it network access. it is faster to get a router.
But no reason this shouldnt work in the meantime.
i have a router was causing some troubles before locking certain ports
actually pc2 is assigned with a different ip address, but there has to be a way to get connect manually assigning the correct numbers, ip dns etc..
It should work if you bridge the connections on pc2. I believe you can chain the lan but you should check your firewalls first.
firewall is on, if i take it off i lose internet connection from pc1, also should i set connection to share, and then bridge connection
btw dont tease me with new bf bad company 2, i want :nutkick: lol
You can use sharing to connect the ps3 for media* purposes and bridge the connections to get the ps3 on the network.
Aphexdreamer said:
Then get PS3 Media Server
http://ps3mediaserver.blogspot.com/
Install it run it and your good to go.
edit: actually I think you may have an ip issue as I dont think you have any dhcp in your chain.
So the first computer is the DHCP server, as long as the second computer isn't assigning a IP it should work.
exactly, but i want to use second lan port on pc2 to connect ps3
pc2 ip address has a total different ip address then pc1
Please list the ip, subnet mask, and gateway for each PC.
ok what about dns numbers
sure might as well put up the dns.
xp pro 32bit first, windows 7 64bit ultimate second
