New item for wire management
8,258 (2.07/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
I was looking around for a 90 degree 6 & * pin adapter so I wouldnt have to to run and bend the video card cable in all kinds of angles. What I found is that EVGA has a new item that would make cable management to your video card much easier and cleaner. Its an L-shaped adapter. Here is the link to the EVGA page.
So far I have only found it for sale on the EVGA site for $30 bucks. I want one!
I also found some idiot post a negative review of this thing without even owning one.
I agree its a great item for that clean look, but damn $30EVGA?!!
Thats a tad high imo.
Definitely cool tho,
Well they know that ppl that wants better management r willing to pay :laugh:
Not sure about new, it was posted about already on this site a while ago, but I can't be stuffed chasing up links.
well other than a few right angle connected extension cables there isn't another product like that on the market that I know of.
It's definitely a great product, not many cards have the power connectors at the back edge.
And what did the guy say? He might have made some good points that made total sense.
Frankly, there might be some idiocy in the thing - regardless how well it is designed and fabricated. And no doubt this product is well designed and well made. But I note the EVGA promo claims,
The EVGA PowerLink has one primary function: to make your PC look even more awesome.
So it is all about aesthetics. Not about performance (and don't claim cooling because with a little attention to detail, proper cable management is easy to obtain).
EVERY TIME you add any break/connector in a circuit - especially a mechanical connector - you add some resistance, and possibly some parasitic capacitance and maybe some unwanted inductance too - both of which affect continuity in the circuits. But you also add the much greater potential a poor connection due to damage to the contacts, dust and other contaminants and corrosion too. Or just a loose connection due to poor assembly by the user, knocks during cleaning or other maintenance, or vibrations during transport, fan bearings, or heavy footfalls. And the potentials for any of these faults occurring increase over time as the device ages - especially after being connected and disconnected several times.
But note this device does not simply add two connectors in line (input and output), but multiple connections where you swap in and out the necessary power connector(s) to the card itself. And it adds UNNEEDED filtering in the circuit too.
If someone feels the filtering is needed, then they are suggesting their power supply is low quality! Including EVGA PSUs! I note better cards themselves have very efficient filtering and regulation.
A couple cable tie wraps can make for a very tidy case interior for just a couple pennies.
Look at this picture and note this device brings the power cable connector out to the end of the card - right into the middle of the air flow in the case, perhaps in the way of cooling for you RAM. Is that really better? Even for aesthetics?
Personally, I like EVGA products. As of late, I really like their PSUs - in part because EVGA PSUs have excellent regulation and ripple suppression to begin with. That is, EVGA and other quality PSUs have excellent filtering already!
This is just EVGA's marketing departing attempting to convince enthusiasts they need something they don't. Is that just a good marketing strategy, or idiocy? You decide. Would you think it was a needed product if it had Microsoft's or the HP brand name on it? Or idiocy?
I think I will stick with my tried and trued strategy and keep my cables dressed and tied back and pay attention to what's on my monitors.
A little dielectric grease can go a long way with multiple connections.
Everything said about extra connectors also depends on the different metals used and how long the cables are, so many other factors too, including Time. Metals (copper, aluminum, etc.) used in cables and connectors, and other electronics, have less impurities than decades ago, so copper on copper has a lesser chance of contact corrosion than copper on stainless or aluminum, even with the disimilar metal contact any corrosion will take ages to make a difference. It make it sound like the sky is falling.
What isnt offered, is a way to offset those horrible, horrible conditions, IF they ever happen. Molex chains of 4,5 and 6+ connectors didnt fail, why would only 2 connectors suddenly be such an issue? its not, but if the sky must falling, then it is.
Any resistance, and for any other sky is falling issues, can be reduced with a tiny amount of a good conductive material, like dielectric grease.
What I think is unique about this EVGA item is that it seems to be the first of its kind, its not easy to find a 90 degree elbow connector/adapter.
If it didnt say EVGA on it, id get it. But not for $30. $15 max. With shipping.
Any resistance...can be reduced with a tiny amount of a good conductive material, like dielectric grease.
What??? NO WAY!!!!!! NEVER with dielectric grease!
Dielectric, by definition, implies an "insulator". Therefore, dielectric grease is non-conductive. So if you put dielectric grease on the electrical contacts inside any connector, you are inserting an insulator! That would be bad. Dielectric grease is used on the exterior of connectors to prevent moisture and other contaminants from entering the connection.
What is Dielectric Grease?
It does not matter the quality of the connector! Every and any connector in a wire adds resistance - compared to an uncut straight wire. You can minimize but never eliminate that resistance. If you have two connectors, that's twice the added resistance - even in a perfect world. And this devices adds more than two! Even the most technically perfect solder joint adds resistance and the potential for parasitic capacitance.
Plus, the electrical contacts of this device are though plug-in connectors - mechanical devices. Therefore, they WILL have wear and tear, lose tension, and become dirty over time.
So it depends on what your priority is. If it is for maximum performance and reliability, don't insert extra mechanical devices in the middle. If your priority is a pretty case which 99% of the time no one will see, then go for this device.
But note you will STILL need to provide good cable management because this device does not eliminate your cables - it just forces your cables out into the middle of the case where they could much more easily interfere with desired air flow through the case.
Copper, on the whole, is shittier today than it was in the past. Reason is because we are running low on raw copper, which necessitates recycling. Anyone who scraps metals will know that copper has been steadily increasing in price. That isn't to say you can't get good copper, you just gotta pay for it, something like UP-OCC
When evga psu's come with resistors soldered into the connector end of mobo and vga cables to maintain super low ripple, a device like this seems odd.
And yes, i know in reality you wouldnt be able to tell the difference between having one of these or not, the same could be said for the resistors lots of psu manufacturers see fit to leave inside the psu.
I would rather make a custom wire that use a plastic pos
dielectric grease is for high energy ignition to contain the spark and keep the rubber boot from sticking as well as keep moisture out
Ummm, no. Sorry, but none of that is true at all.
Copper is recycled because it is so easy to do so - and inexpensive to recycle too - compared to extracting copper from ore. Just melt it again and the impurities burn off and you are good to go. And the melting point of copper is pretty low comparatively - almost the same as gold.
Copper extraction techniques today are much more efficient than those of even 50 years ago - so that copper leaving the smelters is much purer to begin with. And then it is much easier to clean out the impurities in recycled copper than it is to extract new copper from ore, and again, cheaper too.
And we are not really running low of copper either. Copper can be recycled over and over and over again indefinitely. Thus is considered a sustainable metal. And not only that, but big copper cables are being recycled by the tons every day and replaced more and more by fiber. And copper pipes are being recycled by the tons daily too and replaced by PVC/plastic pipes. Thus more and more copper is actually becoming available - in spite of the fact China is demanding more and more.
But in spite of that, the Earth's crust still has 100s of billions of tons of viable copper ore within easy reach of current mining techniques.
Oh? That's funny because the price of copper keeps going down too.
5 year Copper Prices
FTR - my first real job was driving a train 2015 feet underground in a copper mine in San Manual, Arizona (the Copper state) way back in 1970 - 1971. At one point in time, it was the worlds largest underground copper mine with 80 miles of rail road track on the 2015 foot level alone!
Right - back on topic - and the point being it is used on the exterior of the connection, not between the conductors.
Dielectric grease might have been the wrong example, I fully meant an electronic contact grease/material.
Okay, but understand nothing is better than direct metal to metal contact. So anything, no matter how conductive it might be, will improve conductivity or reduce the resistance through a connection. The most perfect mechanical connection will still add some resistance (and potential points of failure) to the circuit compared to a straight wire with no breaks or connections between the end points. The best any "electronic contact grease/material" can hope to achieve is to minimize/delay the inevitable degradation by sealing out any moisture, contaminants, and perhaps oxygen that may promote corrosion.
You should've posted this in the co2 conversion thread I'm guessing?
At any rate, copper is not increasing in price. This is like spam for a copper investment scheme being placed here, lol.
