- Nov 5, 2006
- 25 (0.00/day)
- UK
System Name | Home Desktop |
Processor | AMD FX-6300 Piledriver 3.5GHz |
Motherboard | Gigabyte G8-78LMT-S2P |
Cooling | Out-of-the-box cooler |
Memory | 4GB of Corsair VS2GB 1333D3 |
Video Card(s) | Saphire R7 250 1GB GDDR5 |
Storage | Seagate Barracuda ST500DM002 SATA 3 |
Display(s) | ACER V173 17" |
Case | Novatech |
Audio Device(s) | Onboard |
Power Supply | Novatech 750W |
Software | Windows 7 Home Premium 64bit |
Hi, have recently been given a Foxconn Digitalife ELA motherboard (http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000398). Since I'm not one to look the gift horse in the mouth, I'm now going to put together something resembling a decent system, centred around the mobo. Problem I'm having is that I'm actually pretty naff at picking out decent components, since previously I've gone on the basis of whatever was cheapest without consideration for quality, preventing bottlenecking between components, etc etc.
The intention is to match up the components so as to minimise any bottlenecks that might occur due to mis-matching bus speeds, FSB etc, and to maximise the capabilities of the motherboard (eg. using fastest poss RAM, CPU), and to select components that will compliment rather than hinder each other (i.e. which cpu runs best in coordination with the chipset? what graphics cards should I use for the crossfire system?).
So, my question to you, good gents & ladies, what are your suggestions or helpful hints for when I get around to looking for components? I.e. useful websites, what should I be looking for when picking components, any ideas for which makes/models you reccommend, what do I need to look for in a cooling system? Assume for the moment there is no limit to the budget
Any input whatsoever would be greatly appreciated.
