NVFlash help with Bios for FE 2080 ti.
Freyzez
13 (0.01/day)
Hello TechPowerUp.
i have a FE RTX 2080 ti chillin on 49C on max load and oc power limited on the 320 watts with custom water block. i would like to push that to 373 as i see some evga bios has and should be the max it can support yes?
i would like to ask for guidance to what bios to take, should i even do it and so on.
FE Bios is 90.02.17.00.04
Best Retards.
44,267 (6.80/day)
Please take picture of white stickers on card back and get GPU-Z and get a screenshot from there, post it all here.
What cpu and motherboard do you have?
Hello TechPowerUp.
Best Retards.
Freyzez
13 (0.01/day)
Hello sir thanks for helping out!
the White stickers im not sure if i can see as i have custom backplate on but i still have the box if its on there?
my setup is:
Asus Maximus XI Extreme
ROG Thor 1200W power supply
I9-9900k 5ghz 2 cores 4.9ghz 6 cores oc.
G.Skill TridentZ DDR4-3600mhz 32GB
RTX 2080 ti FE with custom block and backplate. currently hitting +1200 on memory +89core 100% voltage and power 123% max this is as high as i go before powerlimit on 320 watts running all games 100%. i was thinking maybe i could push to 375 watts max as its only 49C.
44,267 (6.80/day)
You are running the stock bios right?
44,267 (6.80/day)
Ok let me look
Back up your current bios to your desktop, put in a folder, use gpu-z to do it, click arrow next to uefi check box and proceed. I have 1 bios for you that is for ln2 users but you should be ok.
yes i have not touched anything yet.
Let me know you have backed up your bios
@Freyzez
Freyzez
13 (0.01/day)
Ok let me look
okey cool thank you. i have already done it. it just felt like a zoo in here with so many bios :p i want the right one and not destroy my 7.5k euro system :p i appreciate the help.
44,267 (6.80/day)
Freyzez
13 (0.01/day)
That's the file.
Use this tool to flash.
okey. i just have some questions so i understand myself what i am doing, 1x DisplayPort 1x HDMI 1x USB-C 2x Mini-DiplayPort in that bios that is not the same mine has what does that matter to my ports? and 2000 watts? :D if i go 380-390 watts it will damage the system no? as i understand 75 watts from the pcie16 port and 2x 150 watts from the 2x8 pinns connected.
44,267 (6.80/day)
Hold off, yeah dont install it
Freyzez
13 (0.01/day)
hehe okey i have not touched anything yet before i know what im doing.
that bios here is 373 watts which i thought would be best target? but does that work i cannot find out what is the difference that some can work some cant.
44,267 (6.80/day)
Use this file.
The file i provided previously is for LN2 modders.
44,267 (6.80/day)
Or use this file.
Since you already backed up and you have a core i9 cpu, you can reflash your gpu incase of a failure.
what is LN2 modders? :D and this bios 336 watts i gain 16 more.
LN2 is Liquid Nitrogen.
I just helped a user with a RX5700 flash to a RX5700XT.
@Freyzez
Freyzez
13 (0.01/day)
Or use this file.
@Freyzez
ahh okey. now i get alot more already. so the evga i linked is that the best target as its 2 watts below as i understand i can pull? am i right in the 375 watts? and if i go 380 will it die? :D
will this Evga 373w bios work?
44,267 (6.80/day)
Give it a shot otherwise use the other. If it bricks put the old bios back in.
Freyzez
13 (0.01/day)
I would like to be sure about atleast the watt limit first before i give it a shot? :D dont wanna fry it if it works as its suppose but cant handle the 373 watt over 320.
44,267 (6.80/day)
Since you water cool it, it will be fine.
Freyzez
13 (0.01/day)
alright. well im not worried about GPU temp more the actualy cables the 2x 8 pinns and the pci16 express that i dont pull too much and damage either motherboard or psu. is it right with the 150+150+75 watt ?
and thanks alot for the help sir! means alot.
44,267 (6.80/day)
You have a 1200 Watt psu, no problem.
44,267 (6.80/day)
Start with 373
Just do it and press on.
If you need 450 watts you need a card that has 3 8pin connectors, so 373 is plenty.
Freyzez
13 (0.01/day)
Start with 373
okey thanks. all that understood now. But i find soo many different 373 bios also from other brands. there is 7 evga of the EVGA FTW ones i linked. help me out in this zoo of bios please :D and are they same PCB as mine thats the part i cant find to match.
44,267 (6.80/day)
I suggested 1 earlier
Freyzez
13 (0.01/day)
i just presumed someone in here could confirm atleast a bios worked on the FE around the 375w range and not try this or maybe try this and see what happends :D from what i can read around the forums on web is if i flash that evga ftw bios on my fe it will brick my card....
this bios has cofirmation and guide to it. it is a 380w though.
