Nvidia control panel 'Prefer Maximum Performance' Issue
Edelweiss
1 (0.00/day)
Hey Community
My problem is that when I set the power managment mode to Prefer Maximum Performance it does not affect my card at all tried to reinstall drivers still the same problem you got an idea what causes this Issue ?
Operating System: Windows 10
Processor: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz (8 CPUs), ~4.0GHz
Memory: 16384MB RAM
Card name: NVIDIA GeForce GTX 970
6,270 (0.89/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
Hey Community
Memory: 16384MB RAM
What drivers do you have installed?
I have a GTX 960M and it works as it should on mine.
The GPU clocks will still fluctuate a bit but wont down clock nearly as much as the other settings. IT WILL NOT STAY AT MAX CLOCKS all the time even with Max Performance.
Welcome to TPU :lovetpu:
qubit
Overclocked quantum bit
17,865 (2.81/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
That setting doesn't always affect the card. Also, is this the global version of the setting or the game specific one? Make sure that for the game that you're testing that you ensure the specific setting is set to either mirror the global one, or set specifically to the one you want.
