NVIDIA GeForce RTX 3070 Crashes With All Unreal Engine Games - HELP!
Thank you for your continued help. I have reached out to CyberPower and will download Furmark and give that a go. Thank you again so far, much gratefulness!
Good luck - let us know how you get on. As it's a CyberPower pre-built then it should be covered under warranty and as much as it's admirable to troubleshoot it yourself - you did pay a premium to CyberPower for the warranty and support compared to buying the parts and assembling it yourself - so you might as well take advantage of that, and you don't want to risk invalidating that warranty by messing around too much with it yourself.
Doing the Furmark "Burn In" is that the correct test? Been going for 7 minutes no issues, GPU temp at 74% - avg 172 FPS
So I have been running the Furmark "Burn In" for 13 minutes, zero issues, 172 avg FPS, GPU temp 75. Is this the right test? Does it ever stop? Should I stop and run a different Furmark?
30 minutes, 77 temp, still 172 FPS
What does this mean? It looks good?
30 minutes Furmark GPU burn-in stable is proof that your GPU isn't defective at least, but in isolation it doesn't do much. Furmark is really just used to hit your TDP with a constant/stable 100% load and from what you said, it only crashes when the total system power gets too high - so you need a combined CPU+GPU load, not just a GPU-only load.
You can run these two concurrently:
With a 5700X you want to set the CPU burner to 15 threads, not 16 - because you'll need to leave a little bit of CPU headroom just to run the GPU stress test effectively.
That's the GPU-only test by the looks of things. You can run these two concurrently:
OK will do, also downloading Forza Horizon 5 as Google says its one of the more graphic intensive games on GamePass, I intend to try and max out and run and send my results as well.
4 minutes in running both, cant see what CPU Burner is doing because Stress is full screen. I didn't change threads because didn't know how, just clicked run on both. 6 mins in - AVG FPS - 115 : TEMP 71
Just restarted, changed to 15, biggest issue I see outside of the test, Temp at 95, guessing this is CPU, because test says GPU at 76. Pic attached.
<->[NORMAL]#00000001#Mon Feb 26 15:07:21 2024#Geeks3D FurMark 1.38.1.0 is starting up...
<->[NORMAL]#00000002#Mon Feb 26 15:07:21 2024#New FurMark 2 with OpenGL and Vulkan support: https://geeks3d.com/furmark/v2/
<->[NORMAL]#00000003#Mon Feb 26 15:07:21 2024#Discord server: https://geeks3d.com/discord/
<->[NORMAL]#00000004#Mon Feb 26 15:07:21 2024#FurMark folder: C:\Program Files (x86)\Geeks3D\Benchmarks\FurMark\
<->[NORMAL]#00000005#Mon Feb 26 15:07:21 2024#Log file: C:\Program Files (x86)\Geeks3D\Benchmarks\FurMark\furmark_0001.txt
<->[NORMAL]#00000006#Mon Feb 26 15:07:22 2024#CPU/System info:
<->[NORMAL]#00000007#Mon Feb 26 15:07:22 2024#- CPU: AMD Ryzen 7 5700
<->[NORMAL]#00000008#Mon Feb 26 15:07:23 2024#- CPU speed: 3899 MHz
<->[NORMAL]#00000009#Mon Feb 26 15:07:23 2024#- System memory: 32562 MB
<->[NORMAL]#00000010#Mon Feb 26 15:07:23 2024#- OS: Windows 11 64-bit build 22631
<->[NORMAL]#00000011#Mon Feb 26 15:07:23 2024#Detecting GPUs...
<->[NORMAL]#00000012#Mon Feb 26 15:07:23 2024#Found 1 GPUs.
<->[NORMAL]#00000013#Mon Feb 26 15:07:23 2024#- GPU 1: NVIDIA GeForce RTX 3070 LHR
<->[NORMAL]#00000014#Mon Feb 26 15:07:23 2024# - Cores: 5888
<->[NORMAL]#00000015#Mon Feb 26 15:07:23 2024# - Memory size: 8191MB
<->[NORMAL]#00000016#Mon Feb 26 15:07:23 2024# - Memory type: GDDR6
<->[NORMAL]#00000017#Mon Feb 26 15:07:23 2024# - TDP: 220W
<->[NORMAL]#00000018#Mon Feb 26 15:07:23 2024# - Bus ID: 1
<->[NORMAL]#00000019#Mon Feb 26 15:07:23 2024# - Bios: 94.04.67.00.3c
<->[NORMAL]#00000020#Mon Feb 26 15:07:23 2024# - Graphics driver: R551.61
<->[NORMAL]#00000021#Mon Feb 26 15:07:23 2024# - GPU temperature: 35.0 C
<->[NORMAL]#00000022#Mon Feb 26 15:07:23 2024# - True clocks - GPU clock: 1440MHz - Memory clock: 6498MHz - GPU voltage: 0.000V
<->[NORMAL]#00000023#Mon Feb 26 15:07:23 2024# - GPU base clock: 1500MHz - GPU boost clock: 1770MHz
<->[NORMAL]#00000024#Mon Feb 26 15:07:23 2024# - GPU power target: 100.0 % TDP
<->[NORMAL]#00000025#Mon Feb 26 15:07:23 2024# - Fan speed: 58%
<->[NORMAL]#00000026#Mon Feb 26 15:07:23 2024# - Fan speed: 1341 RPM
<->[NORMAL]#00000027#Mon Feb 26 15:07:23 2024#GPU monitoring thread started up ok.
<->[NORMAL]#00000028#Mon Feb 26 15:07:23 2024#oZone3D Engine is starting up - kernel build: [v3.4.3 - Jan 16 2023 @ 20:43:01] - codename: Kantalium
<->[NORMAL]#00000029#Mon Feb 26 15:07:23 2024#oZone3D initialization in progress...
<->[NORMAL]#00000030#Mon Feb 26 15:07:23 2024#oZone3D - OpenGL renderer creation ok.
<->[NORMAL]#00000031#Mon Feb 26 15:07:23 2024#o3RendererOpenGL INFO: OpenGL version: 4.6.0 NVIDIA 551.61
<->[NORMAL]#00000032#Mon Feb 26 15:07:23 2024#o3RendererOpenGL INFO: OpenGL Shading Language (GLSL) version: 4.60 NVIDIA
<->[NORMAL]#00000033#Mon Feb 26 15:07:23 2024#oZone3D initialization ok.
<->[NORMAL]#00000034#Mon Feb 26 15:07:23 2024#Checking for new version...
<->[NORMAL]#00000035#Mon Feb 26 15:07:24 2024#Your version of FurMark is up to date
<->[NORMAL]#00000036#Mon Feb 26 15:07:36 2024#Render thread - affinity mask set to 0
<->[NORMAL]#00000037#Mon Feb 26 15:28:05 2024#Render thread - affinity mask set to 0
95C is too hot for a 65W chip that has PBO disabled. Not that I've seen hot chips cause crashing but I guess I can't claim to have seen everything.
What's the cooler CyberPower used - is it the Wraith Stealth?
It's "the bare minimum" for a 65W CPU (actually 88W peak consumption due to confusing "TDP vs PPT" metrics) - but even that wimpy cooler typically keeps temperatures in check for 88W, it just tends to get loud.
Just so I have this clear, this is the summary so far, right?
  • Unreal games - fail, crash frequently
  • Other games - pass, crash infrequently
  • OCCT CPU tests - pass, no crash
  • OCCT power test - fail, crash
  • Furmark GPU-only - pass, no crash
  • Furmark GPU+CPU - pass, very hot 95C
Yes your summary sounds correct, and the software I was using for the 95C is legit and accurate?
How do I find out the cooler model?
Also, if everyone is thinking the PSU is the issue, even with overheating on a few of the tests?
Would a new appropriate PSU fix the overheating too?
So i just crashed a couple minutes in to Nightingale, pics show Ryzen monitoring at time of crash, anomaly is volt at 1.35 of 1.35, can I amp this up or down? How?
And 2nd pic is error that comes up.
So my Forza 5 download just finished and I ran a benchmark, see pic.
What does this mean, I guarantee I can sit and play this game for hours with no crash but have no interest. What's with unoptimized or optimized Unreall games?
While playing the game at ultra settings I got these Ryzen readings. Alt-TAB into Chrome, zero issue, sent screenshot, Alt-TAB back in zero issue seamless playing....
What is the deal?
Ryzen Master should be accurate enough in terms of temperatures. Nothing using on-board sensors is ever going to be 100% accurate but it's close enough.
If you post a decent, in-focus photo of the inside of the case with the side panel off, I'm pretty sure people here can identify the cooler.
A new PSU definitely won't solve the overheating; That's an issue with the CPU cooler, or possibly the motherboard BIOS having an issue with the 5700X. You *can* manually adjust the voltages yourself but it 100% shouldn't be necessary for any CPU running at stock settings with DOCP/XPM disabled. If you update the BIOS on your motherboard, there's a slim chance that a newer BIOS fixes the high voltages and it doesn't cost you anything to try. There have been some BIOS releases on AM4 that apply too much voltage which is a significant cause of high temperatures at lower TDPs.
I mostly build workstations and when I get the occasional CPU behaving with marginal stability I don't try to tweak it with voltages to get stability back because CPUs do degrade very slowly over time and that instability will likely return a few weeks/months later. I always take advantage of the warranty whilst it's still in effect.
The PSU is a strong suspect just because it doesn't appear to be a legit EVGA model, and weird, hard-to-nail-down crashes are so often the result of cheap, inadequate PSUs - but without swapping parts (ruling out components one at a time by swapping out for known-good parts) we're probably left at guessing, so unless you have spare PSU/cooler lying around this is the point you take a backup copy of your personal files and prepare to RMA through CyberPower. Your PSU may even be genuine EVGA - but just something obscure and unlisted. Contacting EVGA with your concerns is one option, you can always link them to this forum thread.
Your CPU is definitely too hot, so updating the BIOS to the latest version and checking on the CPU cooler are a priority.
Your PSU is an unknown, I would wait on CyberPower to respond, and like I said - you could email EVGA with your model/serial number to see if they can confirm its authenticity.
more than likely need better psu and dump shitty b550 repaste cpu
Does she use Discord and if so does she have overlay on?
Also, get us a picture showing insides of the PC as well as the case itself. If that Ryzen 5700 is reaching 95C in any test then there's something wrong.
Hello.
Lately, Unreal Engine launcher had some problems.
In some cases after the launcher started , after some times it crashed or in other cases in the middle of the game you were playing.
Well that was not about your card, it was related to them.
I updated Epic Launcher as they suggested (i did it yesterday after 3 weeks of nightmares) and the problem is gone now.
This was my case and i own a system with RED force in it (AMD).
Here is the article from Epic Games how to solve the crash-es :
can you pull out the first set of sticks and replace them with the one's you bought, or have you already done this/someone suggested this?
System Information
Time of this report: 2/28/2024, 13:02:26
Machine name: PANDAPOWEREDXL
Machine Id: {25F74478-EEE0-4F48-86F1-F7FD8A3BB364}
Operating System: Windows 11 Home 64-bit (10.0, Build 22631) (22621.ni_release.220506-1250)
Language: English (Regional Setting: English)
System Manufacturer: ASUS
System Model: System Product Name
BIOS: 3202 (type: UEFI)
Processor: AMD Ryzen 7 5700 (16 CPUs), ~3.9GHz
Memory: 32768MB RAM
Available OS Memory: 32562MB RAM
Page File: 4624MB used, 38690MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, no HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.4.9
DxDiag Version: 10.00.22621.0001 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce RTX 3070
Manufacturer: NVIDIA
Chip type: NVIDIA GeForce RTX 3070
DAC type: Integrated RAMDAC
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_10DE&DEV_2488&SUBSYS_404E1458&REV_A1
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 24299 MB
Dedicated Memory: 8018 MB
Shared Memory: 16281 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
HDR Support: Not Supported
Display Topology: Extend
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.650391,0.329102), Green(0.331055,0.622070), Blue(0.151367,0.052734), White Point(0.313477,0.329102)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: VG248
Monitor Id: ACI24A4
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: Displayport External
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported
Driver Name: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvldumdx.dll
Driver File Version: 31.00.0015.5161 (English)
Driver Version: 31.0.15.5161
DDI Version: 12
Feature Levels: 12_2,12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 3.1
Hardware Scheduling: DriverSupportState:Stable Enabled:False
Displayable: Supported
Graphics Preemption: Pixel
Compute Preemption: Dispatch
Miracast: Not Supported by Graphics driver
Detachable GPU: No
Hybrid Graphics GPU: Discrete
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: 2/14/2024 4:00:00 PM, 785152 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B71E3E-67C8-11CF-C163-41600EC2D235}
Vendor ID: 0x10DE
Device ID: 0x2488
SubSys ID: 0x404E1458
Revision ID: 0x00A1
Driver Strong Name: oem13.inf:0f066de31a1a610b:Section071:31.0.15.5161:pci\ven_10de&dev_2488
Rank Of Driver: 00CF2001
Video Accel:
DXVA2 Modes: {86695F12-340E-4F04-9FD3-9253DD327460} DXVA2_ModeMPEG2_VLD {6F3EC719-3735-42CC-8063-65CC3CB36616} DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD {32FCFE3F-DE46-4A49-861B-AC71110649D5} DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 {20BB8B0A-97AA-4571-8E99-64E60606C1A6} {15DF9B21-06C4-47F1-841E-A67C97D7F312} DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC {9947EC6F-689B-11DC-A320-0019DBBC4184} {33FCFE41-DE46-4A49-861B-AC71110649D5} DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2 {DDA19DC7-93B5-49F5-A9B3-2BDA28A2CE6E} {B8BE4CCB-CF53-46BA-8D59-D6B8A6DA5D2A} {6AFFD11E-1D96-42B1-A215-93A31F09A53D} {914C84A3-4078-4FA9-984C-E2F262CB5C9C} {8A1A1031-29BC-46D0-A007-E9B092CA6767}
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 4
MPO Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB,IMMEDIATE,HDR (MPO3)
MPO Stretch: 10.000X - 0.500X
MPO Media Hints: resizing, colorspace Conversion
MPO Formats: NV12,P010,YUY2,R16G16B16A16_FLOAT,R10G10B10A2_UNORM,R8G8B8A8_UNORM,B8G8R8A8_UNORM
PanelFitter Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB,IMMEDIATE,HDR (MPO3)
PanelFitter Stretch: 10.000X - 0.500X
Monitor Id: ACI24A5
Output Type: HDMI
DDI Version: 12
Detachable GPU: No
WHQL Logo'd: Yes
Vendor ID: 0x10DE
Device ID: 0x2488
Revision ID: 0x00A1
Video Accel:
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 1
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
PanelFitter Caps: Not Supported
PanelFitter Stretch: Not Supported
Sound Devices
Description: Realtek Digital Output (Realtek(R) Audio)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0897&SUBSYS_10438814&REV_1005
Manufacturer ID: N/A
Product ID: N/A
Type: N/A
Driver Name: RTKVHD64.sys
Driver Version: 6.0.9489.1 (English)
WHQL Logo'd: Yes
Date and Size: 3/6/2023 4:00:00 PM, 6454680 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Emulation Only
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Speakers (Realtek(R) Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Product ID: N/A
Type: N/A
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: VG248 (NVIDIA High Definition Audio)
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_009E&SUBSYS_1458404E&REV_1001
Product ID: N/A
Type: N/A
Driver Name: nvhda64v.sys
Driver Version: 1.3.40.14 (English)
WHQL Logo'd: Yes
Date and Size: 1/18/2023 4:00:00 PM, 121880 bytes
Other Files:
Driver Provider: NVIDIA Corporation
Cap Flags: 0xF1F
HW Memory: 0
Product ID: N/A
Type: N/A
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: SteelSeries Rival 110 Gaming Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1038, 0x1729
FF Driver: n/a
Device Name: Corsair Gaming K55 RGB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1B1C, 0x1B3D
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: AURA LED Controller
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0B05, 0x1939
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (USB 3.0)
| Vendor/Product ID: 0x1022, 0x1639
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 2/17/2024 13:43:14, 726496 bytes
+-+ USB Composite Device
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 2/17/2024 13:43:13, 230784 bytes
| +-+ SteelSeries Rival 110
| | | Matching Device ID: USB\VID_1038&PID_1729&MI_01
| | | Lower Filters: sshid
| | | Service: mshidkmdf
| | | Driver: sshid.sys, 2/23/2022 21:16:26, 48800 bytes
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 5/6/2022 21:19:25, 69632 bytes
| | | | Driver: mouclass.sys, 5/6/2022 21:19:25, 95592 bytes
| | +-+ HID Keyboard Device
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 5/6/2022 21:19:25, 73728 bytes
| | | | Driver: kbdclass.sys, 5/6/2022 21:19:25, 95576 bytes
| Service: USBHUB3
| | Service: usbccgp
| +-+ USB Input Device
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 11/18/2023 08:39:30, 77824 bytes
| | | Driver: hidclass.sys, 11/18/2023 08:39:30, 278528 bytes
| | | Driver: hidparse.sys, 11/18/2023 08:39:30, 90112 bytes
| | | | Service: kbdhid
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 154.1 GB
Total Space: 953.2 GB
File System: NTFS
Model: WD Blue SN570 1TB
System Devices
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_166E&SUBSYS_00000000&REV_00\3&11583659&0&C4
Driver: n/a
Name: AMD PSP 10.0 Device
Device ID: PCI\VEN_1022&DEV_15DF&SUBSYS_88091043&REV_00\4&3293EFF9&0&0241
Driver: C:\Windows\system32\DRIVERS\amdpsp.sys, 5.26.0000.0000 (English), 11/13/2023 10:27:40, 62392 bytes
Driver: C:\Windows\system32\amdtee_api.dll, 5.26.0000.0000 (English), 11/13/2023 10:27:44, 525744 bytes
Driver: C:\Windows\SysWOW64\amdtee_api.dll, 5.26.0000.0000 (English), 11/13/2023 10:27:42, 397232 bytes
Device ID: PCI\VEN_1022&DEV_1630&SUBSYS_88091043&REV_00\3&11583659&0&00
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1633&SUBSYS_88091043&REV_00\3&11583659&0&09
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.22621.2861 (English), 12/15/2023 17:06:33, 579056 bytes
Device ID: PCI\VEN_1022&DEV_1671&SUBSYS_00000000&REV_00\3&11583659&0&C7
Driver: n/a
Device ID: PCI\VEN_1022&DEV_43EA&SUBSYS_33081B21&REV_00\5&2F50B2B4&0&480211
Device ID: PCI\VEN_1022&DEV_1632&SUBSYS_00000000&REV_00\3&11583659&0&40
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1632&SUBSYS_00000000&REV_00\3&11583659&0&10
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1632&SUBSYS_00000000&REV_00\3&11583659&0&08
Driver: n/a
Name: AMD USB 3.10 eXtensible Host Controller - 1.10 (Microsoft)
Device ID: PCI\VEN_1022&DEV_1639&SUBSYS_87E11043&REV_00\4&3293EFF9&0&0441
Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.22621.2506 (English), 11/18/2023 08:39:30, 677232 bytes
Driver: C:\Windows\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.22621.2506 (English), 11/18/2023 08:39:30, 170856 bytes
Name: Realtek PCIe GbE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_86771043&REV_15\6&30A0F5B4&0&00480211
Driver: C:\Windows\System32\DriverStore\FileRepository\rt68cx21x64.inf_amd64_75af912c76141870\rt68cx21x64.sys, 1168.09.0614.2022 (English), 1/23/2024 10:51:12, 656288 bytes
Device ID: PCI\VEN_1022&DEV_1639&SUBSYS_87E11043&REV_00\4&3293EFF9&0&0341
Device ID: PCI\VEN_1022&DEV_166C&SUBSYS_00000000&REV_00\3&11583659&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_790B&SUBSYS_87E11043&REV_51\3&11583659&0&A0
Driver: n/a
Name: NVIDIA GeForce RTX 3070
Device ID: PCI\VEN_10DE&DEV_2488&SUBSYS_404E1458&REV_A1\4&7D659FE&0&0009
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NVWMI\nvPerfProvider.man, 2/15/2024 08:42:00, 14175 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NVWMI\nvWmi.mof, 2/15/2024 08:42:00, 148921 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NVWMI\nvWmi64.exe, 2.36.0000.0000 (English), 2/17/2024 00:09:08, 4518536 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\NVDisplay.Container.exe, 1.39.3323.1171 (English), 2/17/2024 00:07:54, 1274992 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\NvContainerRecovery.bat, 2/15/2024 08:42:00, 1951 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\NvMessageBus.dll, 3.12.3354.5005 (English), 2/17/2024 00:07:56, 3493408 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\dlsargs.xml, 2/15/2024 08:42:00, 544 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\dlsnetparams.csv, 2/15/2024 08:42:00, 201870 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\messagebus_client.conf, 2/15/2024 08:42:00, 313 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\nvgwls.exe, 2/17/2024 00:07:56, 3940872 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\nvtopps.db3, 2/15/2024 08:42:00, 126976 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\plugins\LocalSystem\NvXDCore.dll, 31.00.0015.5161 (English), 2/17/2024 00:08:04, 1893384 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\plugins\LocalSystem\NvcDispCorePlugin.dll, 31.00.0015.5161 (English), 2/17/2024 00:07:58, 521248 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\plugins\LocalSystem\NvcDispWatchdog.dll, 1.39.3323.1171 (English), 2/17/2024 00:08:02, 760352 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\plugins\LocalSystem\_DisplayDriverRAS.dll, 1.10.0000.0000 (English), 2/17/2024 00:08:10, 2711568 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\plugins\LocalSystem\_NvMsgBusBroadcast.dll, 3.12.3354.5005 (English), 2/17/2024 00:08:16, 3491360 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\plugins\LocalSystem\_nvtopps.dll, 31.00.0015.5161 (English), 2/17/2024 00:08:16, 11492896 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\plugins\LocalSystem\messagebus.conf, 2/15/2024 08:42:00, 313 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\plugins\LocalSystem\wksServicePluginZ.dll, 31.00.0015.5161 (English), 2/17/2024 00:08:06, 279560 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\plugins\Session\_NvGSTPlugin.dll, 31.00.0015.5161 (English), 2/17/2024 00:08:26, 2653192 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\plugins\Session\nvprofileupdaterplugin.dll, 31.00.0015.5161 (English), 2/17/2024 00:08:22, 2228744 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\plugins\Session\nvxdsyncplugin.dll, 8.17.0015.5161 (English), 2/17/2024 00:08:22, 1839112 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\Display.NvContainer\plugins\Session\wksServicePlugin.dll, 31.00.0015.5161 (English), 2/17/2024 00:08:24, 314400 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\Drs\dbInstaller.exe, 31.00.0015.5161 (English), 2/17/2024 00:00:36, 735240 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\Drs\nvdrsdb.bin, 2/15/2024 08:42:00, 1936004 bytes
Driver: C:\Windows\system32\nvcpl.dll, 8.17.0015.5161 (English), 2/17/2024 00:01:32, 5912608 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nv3dappshext.dll, 6.14.0015.5161 (English), 2/17/2024 00:01:08, 1004560 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nv3dappshextr.dll, 6.14.0015.5161 (English), 2/17/2024 00:01:10, 97800 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvcoproc.bin, 2/15/2024 08:42:00, 10551347 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvcpl.dll, 8.17.0015.5161 (English), 2/17/2024 00:01:32, 5912608 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvdevtools.dll, 31.00.0015.5161 (English), 2/17/2024 00:02:14, 4592264 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvdevtoolsr.dll, 31.00.0015.5161 (English), 2/17/2024 00:02:16, 245896 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvdisps.dll, 31.00.0015.5161 (English), 2/17/2024 00:02:22, 11656840 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvdispsr.dll, 31.00.0015.5161 (English), 2/17/2024 00:02:28, 11575408 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvgames.dll, 31.00.0015.5161 (English), 2/17/2024 00:03:02, 12491912 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvgamesr.dll, 31.00.0015.5161 (English), 2/17/2024 00:03:04, 13321328 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvlicensings.dll, 6.14.0015.5161 (English), 2/17/2024 00:04:08, 4578848 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvlicensingsr.dll, 6.14.0015.5161 (English), 2/17/2024 00:04:10, 363120 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvshext.dll, 1.02.0000.0001 (English), 2/17/2024 00:05:54, 133128 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvsmartmax.dll, 6.14.0010.10003 (English), 2/17/2024 00:05:56, 199176 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvsmartmax64.dll, 6.14.0010.10003 (English), 2/17/2024 00:06:02, 236576 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvsmartmaxapp.exe, 6.14.0010.10003 (English), 2/17/2024 00:06:06, 273928 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvsmartmaxapp64.exe, 6.14.0010.10003 (English), 2/17/2024 00:06:08, 285216 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvsvc64.dll, 31.00.0015.5161 (English), 2/17/2024 00:06:10, 2673288 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvsvcr.dll, 31.00.0015.5161 (English), 2/17/2024 00:06:12, 1801752 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvsvs.dll, 31.00.0015.5161 (English), 2/17/2024 00:06:14, 5101064 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvsvsr.dll, 31.00.0015.5161 (English), 2/17/2024 00:06:16, 2013704 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvui.dll, 8.17.0015.5161 (English), 2/17/2024 00:06:26, 6654088 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvuir.dll, 8.17.0015.5161 (English), 2/17/2024 00:06:28, 2649096 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvvitvs.dll, 31.00.0015.5161 (English), 2/17/2024 00:06:34, 7461408 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvvitvsr.dll, 31.00.0015.5161 (English), 2/17/2024 00:06:36, 4263432 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvwss.dll, 31.00.0015.5161 (English), 2/17/2024 00:07:08, 12268552 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvwssr.dll, 31.00.0015.5161 (English), 2/17/2024 00:07:10, 9529352 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvxdapix.dll, 8.17.0015.5161 (English), 2/17/2024 00:07:14, 9412640 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvxdbat.dll, 8.17.0015.5161 (English), 2/17/2024 00:07:16, 1653880 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvxdplcy.dll, 8.17.0015.5161 (English), 2/17/2024 00:07:18, 1895560 bytes
Driver: C:\Windows\system32\lxss\lib\libcuda.so, 2/15/2024 08:42:00, 162552 bytes
Driver: C:\Windows\system32\lxss\lib\libcuda.so.1, 2/15/2024 08:42:00, 162552 bytes
Driver: C:\Windows\system32\lxss\lib\libcuda.so.1.1, 2/15/2024 08:42:00, 162552 bytes
Driver: C:\Windows\system32\lxss\lib\libcudadebugger.so.1, 2/15/2024 08:42:00, 10524136 bytes
Driver: C:\Windows\system32\lxss\lib\libnvcuvid.so, 2/15/2024 08:42:00, 11742584 bytes
Driver: C:\Windows\system32\lxss\lib\libnvcuvid.so.1, 2/15/2024 08:42:00, 11742584 bytes
Driver: C:\Windows\system32\lxss\lib\libnvdxdlkernels.so, 2/15/2024 08:42:00, 115888416 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-encode.so, 2/15/2024 08:42:00, 572008 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-encode.so.1, 2/15/2024 08:42:00, 572008 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-ml.so.1, 2/15/2024 08:42:00, 244344 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-opticalflow.so, 2/15/2024 08:42:00, 362960 bytes
Driver: C:\Windows\system32\lxss\lib\libnvidia-opticalflow.so.1, 2/15/2024 08:42:00, 362960 bytes
Driver: C:\Windows\system32\lxss\lib\libnvoptix.so.1, 2/15/2024 08:42:00, 72656 bytes
Driver: C:\Windows\system32\lxss\lib\libnvwgf2umx.so, 2/15/2024 08:42:00, 67608808 bytes
Driver: C:\Windows\system32\lxss\lib\nvidia-smi, 2/15/2024 08:42:00, 715296 bytes
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\license.txt, 2/15/2024 08:42:00, 35335 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\_nvngx.dll, 31.00.0015.5161 (English), 2/17/2024 00:07:52, 1552904 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\cudnn_infer64_7.dll, 2/17/2024 00:00:32, 22774208 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvngx.dll, 30.00.0014.9516 (English), 2/17/2024 00:04:22, 488776 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvngx_update.exe, 31.00.0015.5161 (English), 2/17/2024 00:04:22, 1139824 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\FreqTransfer32.exe, 2/17/2024 00:08:34, 3764872 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\FreqTransfer64.exe, 2/17/2024 00:08:34, 4057736 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\GreenScreenBG01.jpg, 2/15/2024 08:42:00, 281528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\GreenScreenBG02.jpg, 2/15/2024 08:42:00, 499736 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\HighresBlender32.exe, 2/17/2024 00:08:38, 3860600 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\HighresBlender64.exe, 2/17/2024 00:08:40, 4163192 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\NvCamera32.dll, 7.01.0000.0000 (English), 2/17/2024 00:08:40, 8184072 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\NvCamera64.dll, 7.01.0000.0000 (English), 2/17/2024 00:08:42, 8684696 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\NvCameraAllowlisting32.dll, 7.01.0000.0000 (English), 2/17/2024 00:08:42, 520360 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\NvCameraAllowlisting64.dll, 7.01.0000.0000 (English), 2/17/2024 00:08:44, 666608 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\NvCameraEnable.exe, 2/17/2024 00:08:48, 374896 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\NvImageConvert32.exe, 2/17/2024 00:08:54, 3763720 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\NvImageConvert64.exe, 2/17/2024 00:08:56, 4037744 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\ReShadeFXC32.exe, 2.00.0000.0000 (English), 2/17/2024 00:08:58, 776824 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\ReShadeFXC64.exe, 2.00.0000.0000 (English), 2/17/2024 00:09:04, 891400 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\ShotWithGeforce518x32.rgba, 2/15/2024 08:42:00, 66304 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\SphericalEquirect32.exe, 2/17/2024 00:09:06, 3716616 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\SphericalEquirect64.exe, 2/17/2024 00:09:08, 3941512 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\Sticker01.png, 2/15/2024 08:42:00, 49695 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\Sticker02.png, 2/15/2024 08:42:00, 474002 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\Sticker03.png, 2/15/2024 08:42:00, 380006 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\Sticker04.png, 2/15/2024 08:42:00, 86881 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\Sticker05.png, 2/15/2024 08:42:00, 59304 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\Sticker06.png, 2/15/2024 08:42:00, 13547 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\Sticker07.png, 2/15/2024 08:42:00, 6342 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\Sticker08.png, 2/15/2024 08:42:00, 96493 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\d3dcompiler_47_32.dll, 6.03.9600.16384 (English), 2/17/2024 00:08:26, 3470864 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\d3dcompiler_47_64.dll, 6.03.9600.16384 (English), 2/17/2024 00:08:28, 4178032 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\scratches.jpg, 2/15/2024 08:42:00, 346354 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\tools_licenses.txt, 2/15/2024 08:42:00, 15970 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvCamera\ui.tga, 2/15/2024 08:42:00, 120236 bytes
Driver: C:\Windows\system32\MCU.exe, 1.01.5204.20580 (English), 2/17/2024 00:01:02, 853000 bytes
Driver: C:\Windows\system32\nvdebugdump.exe, 6.14.0015.5161 (English), 2/17/2024 00:02:06, 459384 bytes
Driver: C:\Windows\system32\nvidia-smi.exe, 8.17.0015.5161 (English), 2/17/2024 00:03:26, 842272 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvopencl32.dll, 31.00.0015.5161 (English), 2/17/2024 00:04:48, 18415736 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvopencl64.dll, 31.00.0015.5161 (English), 2/17/2024 00:04:54, 11132552 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvlddmkm.sys, 31.00.0015.5161 (English), 2/17/2024 00:04:00, 59965448 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvvm32.dll, 31.00.0015.5161 (English), 2/17/2024 00:06:38, 60441224 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvvm64.dll, 31.00.0015.5161 (English), 2/17/2024 00:06:54, 68302360 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\gsp_ga10x.bin, 2/15/2024 08:42:00, 37090848 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\gsp_tu10x.bin, 2/15/2024 08:42:00, 24479384 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\libcuda.so.1.1, 2/15/2024 08:42:00, 8980168 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\libcuda_loader.so, 2/15/2024 08:42:00, 162552 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\libcudadebugger.so.1, 2/15/2024 08:42:00, 10524136 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\libnvcuvid.so.1, 2/15/2024 08:42:00, 11742584 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\libnvdxdlkernels.so, 2/15/2024 08:42:00, 115888416 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\libnvidia-encode.so.1, 2/15/2024 08:42:00, 572008 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\libnvidia-ml.so.1, 2/15/2024 08:42:00, 1722024 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\libnvidia-ml_loader.so, 2/15/2024 08:42:00, 244344 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\libnvidia-nvvm.so.4, 2/15/2024 08:42:00, 27968664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\libnvidia-opticalflow.so.1, 2/15/2024 08:42:00, 362960 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\libnvidia-ptxjitcompiler.so.1, 2/15/2024 08:42:00, 28543272 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\libnvoptix_loader.so.1, 2/15/2024 08:42:00, 72656 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\libnvwgf2umx.so, 2/15/2024 08:42:00, 67608808 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nv-vk64.json, 2/15/2024 08:42:00, 671 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvAIDVC.dll, 31.00.0015.5161 (English), 2/17/2024 00:01:10, 4581408 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvAIDVCx.dll, 31.00.0015.5161 (English), 2/17/2024 00:01:12, 4699656 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvAIHDR.dll, 31.00.0015.5161 (English), 2/17/2024 00:01:18, 2853920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvAIHDRx.dll, 31.00.0015.5161 (English), 2/17/2024 00:01:26, 2980896 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvDecMFTMjpeg.dll, 31.00.0015.5161 (English), 2/17/2024 00:02:08, 507528 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvDecMFTMjpegx.dll, 31.00.0015.5161 (English), 2/17/2024 00:02:08, 657520 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvEncMFTH264.dll, 31.00.0015.5161 (English), 2/17/2024 00:02:44, 915064 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvEncMFTH264x.dll, 31.00.0015.5161 (English), 2/17/2024 00:02:46, 1165944 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvEncMFThevc.dll, 31.00.0015.5161 (English), 2/17/2024 00:02:48, 919664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvEncMFThevcx.dll, 31.00.0015.5161 (English), 2/17/2024 00:02:48, 1174664 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvcubins.bin, 2/15/2024 08:42:00, 24584224 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvcuda32.dll, 31.00.0015.5161 (English), 2/17/2024 00:01:38, 22601328 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvcuda64.dll, 31.00.0015.5161 (English), 2/17/2024 00:01:46, 10424336 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvd3dumx.dll, 31.00.0015.5161 (English), 2/17/2024 00:00:08, 37693752 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvdlistx.dll, 31.00.0015.5161 (English), 2/17/2024 00:00:32, 236504 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvdlppx.dll, 31.00.0015.5161 (English), 2/17/2024 00:00:34, 13419920 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvdxdlkernels.dll, 2/17/2024 00:02:34, 121091208 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvgpucomp32.dll, 31.00.0015.5161 (English), 2/17/2024 00:00:38, 29078768 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvgpucomp64.dll, 31.00.0015.5161 (English), 2/17/2024 00:00:50, 36259256 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvidia-smi, 2/15/2024 08:42:00, 715296 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvldumdx.dll, 31.00.0015.5161 (English), 2/17/2024 00:01:08, 785152 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvml.dll, 8.17.0015.5161 (English), 2/17/2024 00:04:16, 1616400 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvoglv64.dll, 31.00.0015.5161 (English), 2/17/2024 00:04:38, 46177928 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvoptix.bin, 2/15/2024 08:42:00, 99616380 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvoptix.dll, 8.00.0000.0000 (English), 2/17/2024 00:05:00, 56386696 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvppe.dll, 31.00.0015.5161 (English), 2/17/2024 00:01:10, 775184 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvppex.dll, 31.00.0015.5161 (English), 2/17/2024 00:01:12, 1259936 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvptxJitCompiler32.dll, 31.00.0015.5161 (English), 2/17/2024 00:05:20, 17375760 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvptxJitCompiler64.dll, 31.00.0015.5161 (English), 2/17/2024 00:05:24, 20014088 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvrtum64.dll, 31.00.0015.5161 (English), 2/17/2024 00:05:32, 70175776 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvwgf2umx.dll, 31.00.0015.5161 (English), 2/17/2024 00:01:34, 68358168 bytes
Driver: C:\Windows\system32\NvFBC64.dll, 6.14.0015.5161 (English), 2/17/2024 00:03:00, 2173552 bytes
Driver: C:\Windows\system32\NvIFR64.dll, 6.14.0015.5161 (English), 2/17/2024 00:03:56, 1541640 bytes
Driver: C:\Windows\system32\OpenCL.dll, 3.00.0003.0000 (English), 2/17/2024 00:07:26, 1488008 bytes
Driver: C:\Windows\system32\nvEncodeAPI64.dll, 31.00.0015.5161 (English), 2/17/2024 00:02:52, 1024136 bytes
Driver: C:\Windows\system32\nvapi64.dll, 31.00.0015.5161 (English), 2/16/2024 23:59:52, 6943328 bytes
Driver: C:\Windows\system32\nvcuda.dll, 31.00.0015.5161 (English), 2/17/2024 00:01:56, 3721864 bytes
Driver: C:\Windows\system32\nvcudadebugger.dll, 0.00.0000.0000 (English), 2/17/2024 00:01:50, 5773344 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0015.5161 (English), 2/17/2024 00:02:02, 12928136 bytes
Driver: C:\Windows\system32\nvinfo.pb, 2/15/2024 08:42:00, 119184 bytes
Driver: C:\Windows\system32\nvml.dll, 8.17.0015.5161 (English), 2/17/2024 00:04:20, 1046152 bytes
Driver: C:\Windows\system32\nvofapi64.dll, 31.00.0015.5161 (English), 2/17/2024 00:04:28, 669816 bytes
Driver: C:\Windows\system32\vulkan-1-999-0-0-0.dll, 1.03.0275.0000 (English), 2/17/2024 00:07:36, 1445224 bytes
Driver: C:\Windows\system32\vulkan-1.dll, 1.03.0275.0000 (English), 2/17/2024 00:07:36, 1445224 bytes
Driver: C:\Windows\system32\vulkaninfo-1-999-0-0-0.exe, 1.03.0275.0000 (English), 2/17/2024 00:07:48, 2031464 bytes
Driver: C:\Windows\system32\vulkaninfo.exe, 1.03.0275.0000 (English), 2/17/2024 00:07:48, 2031464 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nv-vk32.json, 2/15/2024 08:42:00, 671 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvIccAdvancedColorIdentity.icm, 2/15/2024 08:42:00, 3288 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvd3dum.dll, 31.00.0015.5161 (English), 2/16/2024 23:59:58, 36620272 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvdispco64.exe, 1.00.0016.0000 (English), 2/17/2024 00:02:18, 1739400 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvdlist.dll, 31.00.0015.5161 (English), 2/17/2024 00:00:24, 200056 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvldumd.dll, 31.00.0015.5161 (English), 2/17/2024 00:01:00, 623912 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvoglv32.dll, 31.00.0015.5161 (English), 2/17/2024 00:04:30, 32932976 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\nvwgf2um.dll, 31.00.0015.5161 (English), 2/17/2024 00:01:18, 51877496 bytes
Driver: C:\Windows\SysWow64\NvFBC.dll, 6.14.0015.5161 (English), 2/17/2024 00:02:58, 1625200 bytes
Driver: C:\Windows\SysWow64\NvIFR.dll, 6.14.0015.5161 (English), 2/17/2024 00:03:52, 1199112 bytes
Driver: C:\Windows\SysWow64\OpenCL.dll, 3.00.0003.0000 (English), 2/17/2024 00:07:26, 1227400 bytes
Driver: C:\Windows\SysWow64\nvEncodeAPI.dll, 31.00.0015.5161 (English), 2/17/2024 00:02:50, 787064 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 31.00.0015.5161 (English), 2/16/2024 23:59:48, 6030464 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 31.00.0015.5161 (English), 2/17/2024 00:01:52, 6780424 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 7.17.0015.5161 (English), 2/17/2024 00:01:58, 16033824 bytes
Driver: C:\Windows\SysWow64\nvofapi.dll, 31.00.0015.5161 (English), 2/17/2024 00:04:26, 505456 bytes
Driver: C:\Windows\SysWow64\vulkan-1-999-0-0-0.dll, 1.03.0275.0000 (English), 2/17/2024 00:07:48, 1295208 bytes
Driver: C:\Windows\SysWow64\vulkan-1.dll, 1.03.0275.0000 (English), 2/17/2024 00:07:48, 1295208 bytes
Driver: C:\Windows\SysWow64\vulkaninfo-1-999-0-0-0.exe, 1.03.0275.0000 (English), 2/17/2024 00:07:50, 1578856 bytes
Driver: C:\Windows\SysWow64\vulkaninfo.exe, 1.03.0275.0000 (English), 2/17/2024 00:07:50, 1578856 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_dispsig.inf_amd64_195ec6a4e5afbb7e\NvTelemetry64.dll, 14.03.0060.0000 (English), 2/17/2024 00:06:22, 4466224 bytes
Device ID: PCI\VEN_1022&DEV_43EA&SUBSYS_33081B21&REV_00\5&2F50B2B4&0&400211
Device ID: PCI\VEN_1022&DEV_166F&SUBSYS_00000000&REV_00\3&11583659&0&C5
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1022&DEV_790E&SUBSYS_87E11043&REV_51\3&11583659&0&A3
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.22621.0001 (English), 5/6/2022 21:19:04, 54608 bytes
Name: Standard SATA AHCI Controller
Device ID: PCI\VEN_1022&DEV_43EB&SUBSYS_10621B21&REV_00\4&9E877F&0&0111
Driver: C:\Windows\system32\DRIVERS\storahci.sys, 10.00.22621.2506 (English), 11/18/2023 08:39:02, 214400 bytes
Device ID: PCI\VEN_1022&DEV_43E9&SUBSYS_02011B21&REV_00\4&9E877F&0&0211
Device ID: PCI\VEN_1022&DEV_166A&SUBSYS_00000000&REV_00\3&11583659&0&C0
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1634&SUBSYS_88091043&REV_00\3&11583659&0&12
Device ID: PCI\VEN_1022&DEV_1634&SUBSYS_88091043&REV_00\3&11583659&0&11
Device ID: PCI\VEN_1022&DEV_43EE&SUBSYS_11421B21&REV_00\4&9E877F&0&0011
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_228B&SUBSYS_404E1458&REV_A1\4&7D659FE&0&0109
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.22621.2792 (English), 12/15/2023 17:06:31, 192512 bytes
Driver: C:\Windows\system32\DRIVERS\drmk.sys, 10.00.22621.2506 (English), 11/18/2023 08:38:58, 143360 bytes
Driver: C:\Windows\system32\DRIVERS\portcls.sys, 10.00.22621.2506 (English), 11/18/2023 08:38:58, 471040 bytes
Device ID: PCI\VEN_1022&DEV_15E3&SUBSYS_88141043&REV_00\4&3293EFF9&0&0641
Name: Standard NVM Express Controller
Device ID: PCI\VEN_15B7&DEV_501A&SUBSYS_501A15B7&REV_00\4&39D769C7&0&0012
Driver: C:\Windows\system32\DRIVERS\stornvme.sys, 10.00.22621.3085 (English), 2/16/2024 07:51:34, 251376 bytes
Device ID: PCI\VEN_1022&DEV_166D&SUBSYS_00000000&REV_00\3&11583659&0&C3
Driver: n/a
Name: Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC
Device ID: PCI\VEN_10EC&DEV_C821&SUBSYS_304A1A3B&REV_00\6&3174EFA4&0&00400211
Driver: C:\Windows\system32\DRIVERS\rtwlane.sys, 2024.10.0138.0003 (English), 1/23/2024 10:50:57, 12235504 bytes
Driver: C:\Windows\system32\DRIVERS\rtldata.txt, 1/23/2024 10:50:56, 307397 bytes
Device ID: PCI\VEN_1022&DEV_43EA&SUBSYS_33081B21&REV_00\5&2F50B2B4&0&000211
Device ID: PCI\VEN_1022&DEV_145A&SUBSYS_88091043&REV_C8\4&3293EFF9&0&0041
Driver: C:\Windows\system32\DRIVERS\AMDPCIDev.sys, 1.00.0000.0090 (English), 11/3/2022 12:18:20, 39008 bytes
Device ID: PCI\VEN_1022&DEV_1670&SUBSYS_00000000&REV_00\3&11583659&0&C6
Driver: n/a
Device ID: PCI\VEN_1022&DEV_166B&SUBSYS_00000000&REV_00\3&11583659&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1635&SUBSYS_88091043&REV_00\3&11583659&0&41
Device ID: PCI\VEN_1002&DEV_1637&SUBSYS_88091043&REV_00\4&3293EFF9&0&0141
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.22621.2506
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.22621.2506
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.22621.2506
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.22621.2506
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.22621.0001
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.22621.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.22621.2506
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.22621.0001
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.22621.0001
DV Muxer,0x00400000,0,0,qdv.dll,10.00.22621.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.22621.2506
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.22621.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.22621.2506
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.22621.2506
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.22621.2861
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.22621.3155
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.22621.0001
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.22621.2861
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.22621.2506
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.22621.2506
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.22621.2506
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.22621.0001
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.22621.0001
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.22621.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.22621.2861
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.22621.2506
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.22621.2506
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.22621.2506
DV Splitter,0x00600000,1,2,qdv.dll,10.00.22621.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.22621.2506
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.22621.2506
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.22621.2506
Video Renderer,0x00800001,1,0,quartz.dll,10.00.22621.2506
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.22621.2861
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.22621.2506
Video Renderer,0x00400000,1,0,quartz.dll,10.00.22621.2506
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.22621.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.22621.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,10.00.22621.0001
File writer,0x00200000,1,0,qcap.dll,10.00.22621.0001
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.22621.2506
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.22621.2506
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.22621.2506
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.22621.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.22621.0001
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.22621.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.22621.0001
Null Renderer,0x00200000,1,0,qedit.dll,10.00.22621.0001
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.22621.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.22621.2506
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.22621.2861
Smart Tee,0x00200000,1,2,qcap.dll,10.00.22621.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.22621.2506
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.22621.2506
Wave Parser,0x00400000,1,1,quartz.dll,10.00.22621.2506
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.22621.2506
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.22621.2506
File stream renderer,0x00400000,1,1,quartz.dll,10.00.22621.2506
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.22621.2506
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.22621.2861
AVI Mux,0x00200000,1,0,qcap.dll,10.00.22621.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.22621.2506
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.22621.2506
File Source (URL),0x00400000,0,1,quartz.dll,10.00.22621.2506
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.22621.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.22621.2506
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.22621.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.22621.2506
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.22621.0001
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.22621.0001
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.22621.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.22621.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.22621.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.22621.2506
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.22621.0001
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.22621.0001
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.22621.2506
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.22621.2506
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.22621.2506
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.22621.2506
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.22621.2506
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.22621.2506
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.22621.2715
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.22621.2715
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.22621.2715
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.22621.2506
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.22621.2506
WDM Streaming Capture Devices:
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.22621.0001
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.22621.0001
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,10.00.22621.0001
,0x00000000,0,0,,
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.22621.0001
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,10.00.22621.0001
,0x00000000,0,0,,
,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.22621.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.22621.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.22621.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.22621.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.22621.0001
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.22621.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.22621.0001
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek(R) Audio),0x00200000,1,0,quartz.dll,10.00.22621.2506
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.22621.2506
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.22621.2506
DirectSound: VG248 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,10.00.22621.2506
DirectSound: Speakers (Realtek(R) Audio),0x00200000,1,0,quartz.dll,10.00.22621.2506
DirectSound: Realtek Digital Output (Realtek(R) Audio),0x00200000,1,0,quartz.dll,10.00.22621.2506
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation File Versions
mfcore.dll, 10.00.22621.3155
mfreadwrite.dll, 10.00.22621.2506
mfcaptureengine.dll, 10.00.22621.0001
mfsensorgroup.dll, 10.00.22621.2506
windows.media.dll, 10.00.22621.2715
frameserver.dll, 10.00.22621.2792
frameserverclient.dll, 10.00.22621.2506
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
<transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
NVIDIA MJPEG Video Decoder MFT, {70F36578-2741-454F-B494-E8563DDD1CB4}, 0x4, 8, nvDecMFTMjpegx.dll, 31.00.0015.5161
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.22621.3155
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.22621.0001
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.22621.0001
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.22621.3155
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.22621.0001
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.22621.2506
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.22621.0001
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.22621.0001
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.22621.0001
HEIFImageExtension
VP9VideoExtensionDecoder
RawImageExtension
WebpImageExtension
HEVCVideoExtension
Video Encoders:
NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264x.dll, 31.00.0015.5161
NVIDIA HEVC Encoder MFT, {966F107C-8EA2-425D-B822-E4A71BEF01D7}, 0x4, 8, nvEncMFThevcx.dll, 31.00.0015.5161
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.22621.0001
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.22621.0001
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.22621.0001
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.22621.0001
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.22621.2506
HEIFImageExtension
VP9VideoExtensionEncoder
HEVCVideoExtensionEncoder
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.22621.0001
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.22621.2506
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.22621.2506
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.22621.0001
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.22621.2506
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.22621.2506
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.22621.3007
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.22621.0001
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.22621.2506
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.22621.2792
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.22621.3155
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.22621.3155
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.22621.2506
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.22621.0001
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.22621.0001
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.22621.2792
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.22621.2506
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.22621.3155
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.22621.3155
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.22621.2506
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.22621.0001
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.22621.3155
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.22621.2506
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.22621.2506
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.22621.2506
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.22621.3155
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.22621.0001
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.22621.0001
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.22621.0001
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.22621.2506
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.22621.0001
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.22621.0001
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.22621.0001
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.22621.2506
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.22621.0001
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.22621.2506
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.22621.3085
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.22621.3155
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
EnableEncoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtsps:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D8033-DB46-11CF-B4D1-00805F6CBBEA}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
{C2FE6F0A-4E3C-4DF1-9B60-50863091E4B9}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket 1841242429349130825, type 5
Event Name: RADAR_PRE_LEAK_64
Response: Not available
Cab Id: 0
Problem signature:
P1: ForzaHorizon5.exe
P2: 0.0.0.0
P3: 10.0.22631.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER1 +++:
Fault bucket , type 0
Event Name: LiveKernelEvent
Cab Id: 0
Problem signature:
P1: 141
P2: ffffc7037165e010
P3: fffff80659c212d0
P4: 0
P5: 71c
P6: 10_0_22631
P7: 0_0
P8: 768_1
P9:
P10:
+++ WER2 +++:
Cab Id: 0
Problem signature:
P1: 141
P4: 0
P5: 71c
P6: 10_0_22631
P7: 0_0
P8: 768_1
P9:
P10:
+++ WER3 +++:
Cab Id: 0
Problem signature:
P1: 141
P2: ffff8d8d7a861010
P3: fffff8032a2212d0
P4: 0
P5: 1434
P6: 10_0_22631
P7: 0_0
P8: 768_1
P9:
P10:
+++ WER4 +++:
Cab Id: 0
Problem signature:
P1: 141
P4: 0
P5: 1434
P6: 10_0_22631
P7: 0_0
P8: 768_1
P9:
P10:
+++ WER5 +++:
Cab Id: 0
Problem signature:
P1: 141
P2: ffffd38fab502050
P3: fffff8037a4612d0
P4: 0
P5: 2e50
P6: 10_0_22631
P7: 0_0
P8: 768_1
P9:
P10:
+++ WER6 +++:
Cab Id: 0
Problem signature:
P1: 141
P4: 0
P5: 2e50
P6: 10_0_22631
P7: 0_0
P8: 768_1
P9:
P10:
+++ WER7 +++:
Fault bucket 125946542339, type 5
Event Name: ScriptedDiagFailure
Cab Id: 0
Problem signature:
P1: Microsoft Windows.NetworkDiagnostics.4.0
P2: Default
P3: 1.0.0.0
P4: Default
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER8 +++:
Cab Id: 0
Problem signature:
P2: Default
P3: 1.0.0.0
P4: Default
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER9 +++:
Cab Id: 0
Problem signature:
P1: 141
P2: ffffd38fa8ec7460
P4: 0
P5: 23cc
P6: 10_0_22631
P7: 0_0
P8: 768_1
P9:
P10:
If I were to buy a new PSU how can I figure out the best one that will give MAX allowed power on the rig annnnnnd 2... How hard is it to swap a PSU?
And is anyone able to explain, if there are hardware issues, unbeknownst to the benchmark software and stress test software I am using. How can I still run FORZA 5 on ULTRA for an hour with no issues, crashes, temps, etc? I Can't get past that when weighing in on sinking money into this comp.
Hello.
Lately, Unreal Engine launcher had some problems.
In some cases after the launcher started , after some times it crashed or in other cases in the middle of the game you were playing.
Well that was not about your card, it was related to them.
I updated Epic Launcher as they suggested (i did it yesterday after 3 weeks of nightmares) and the problem is gone now.
This was my case and i own a system with RED force in it (AMD).
Here is the article from Epic Games how to solve the crash-es :
Updated EPIC, guess it was way out of date but that didn't fix. Re-verified all Unreal engine builds, two 5.x and two 4.x
Nada, same crashes...
And you say that your problems start only when you work with Unreal Engine?
Maybe it is not related to your setup, rather then to the software platform itself.
As i did, i read many forums for hours and hours, until Epic decided to release a "f*cking" update that magically solved peoples problems.
So not all the time, the solution is on your side.
Dude, you've already isolated your problem. There's no need to do further troubleshooting without first attempting to fix the issue you've found.
But when I run the "Power" test it sends my temps through the roof immediately and shuts down after a minute
The OCCT power test is designed to stress your cooling and PSU, it failed both.
Replace your PSU with a known good model, and see what you can do to improve temperatures (airflow, cleaning, maybe reduce boost clocks).
Swapping a PSU can be pretty involved if you're new to PC-building as there are several chunky, stiff cables that need both force to insert properly, but also care not to bend/crack the things you're plugging the cables into. If the machine has been cable-managed properly it will also involve cutting zip ties and carefully untangling the PSU cables from the fan cables and buttons/ports of the case.
Did you get anywhere with CyberPower or EVGA regarding the PSU and whether the machine is still under warranty with CyberPower?
People here are likely to be able to guide you through a PSU swap and CPU cooler swap but we haven't had any new info about the PSU or CPU since the weekend so we've got nothing new to go on. A photo from the side of the PC showing the motherboard, processor cooler, graphics card, and general condition would be useful I think - just to rule out anything obvious in the build. I saw you ran the OCCT memory benchmark but we haven't completely ruled out the RAM yet either - there are stability tests and you should run the memory one when you get half an hour of spare time:
As for the hardware issues only manifesting in some cases - FORZA 5 will only use a few of your CPU cores, the CPU will never be under 100% load, just like many other games. Until you can pass a CPU/Power stress test reliably, your system is classified as "unstable" and you should expect crashes, which is why you want to sort out the CPU cooling and possibly the power supply depending on what Cyberpower/EVGA say about your 800GD model.
@HumongousGigantic I would hold off swapping your psu for the moment. Fix the cooling issue's first. This is why i say this: if the rig is getting that hot its going to suck up more wattage from the psu to try and maintain a stable continuous voltage, which will end up making more heat until either the psu cuts the load to save everything and itself or the mobo does. Remember, alot of this heat is dumping into the case itself and heating up other components also, maybe not to a huge degree but enough collectively to make another issue worse, like the one your having.
You gotta clean the fans also, the edges of the blades cause they will stack dust there after awhile. DO NOT let the fan blades turn while cleaning them, i mean spin fast, cause if you spin them backwards they will generate a charge and fry things. The psu is probably fine.
Overheating whilst undesirable, it should never be the sole cause of instability, if a hot system gets unstable, it means either a component isnt working properly or something like a PSU is under spec'd (as power drives heat).
Both GPUs and CPUs are e.g. designed to throttle themselves at manufacturer defined limits and still run stable at these max limits.
I basically dont see a way out of this without either swapping out components (which the OP really seems against doing) or just sending the system back to the seller and telling them its not stable, leaving them to deal with it.
The OP is very fortunate there is two systems, so swapping GPU super easy, RAM is a bios change (very unlikely to be unstable at jedec).
GPUs are one of the easiest components to swap, that could have been done very quickly, likewise resetting the RAM to jedec also would have been super quick. PSU's are more of a pain, and I wouldnt go down that route until RAM and GPU are ruled out. But if heat is causing instability, it means some other component is the root cause.
Cooling or PSU was my first guess after reading OP's post. I agree before spending money on a PSU fix your cooling problems. Get a decent HSF on the cpu. You should never see 95c... not gaming...
Reading and waiting on your results with interest. Good luck, just have a bit of confidence and if you live in the uk near south yorks Id be happy to help. Otherwise we here in this forum can help you get it working perfectly.
:toast:
I am attaching pics from the inside of the PC, trying to gather purchase information for communicating with Cyber Power.
Ah, it's an AIO liquid cooler.
I'm going to bet that either the pump isn't running, it's not mounted correctly, or the "peel before use" sticker is still on the coldplate.
This is the user/installation manual. If you don't fancy sending it back to Cyberpower, you should check what you have matches the installation guide for AM4:
You should be able to feel/hear if the pump is running - but trace the pump back to the fan header on the board from your last photo and then see what RPM the pump is running at in OCCT's monitoring page.
AIO pumps should be connected to dedicated pump headers on the board if the board has one, otherwise they should be configured to run at 75-100% speed in the motherboard's fan speed control page, with the appropriate settings for PWM (4-pin) or DC (3-pin) set.
This is what OCCT shows me, does that show the AIO and pump info you wanted?
Abbreviating numerous times you've stated concerns this is a counterfeit.
BB and all their vendors, buyers, etc on down the line do not produce or sell products you can buy anywhere else. Kitchen appliances, accessory electronic cords, tv, computer, even Apple products are... it is all SKU specific to their line of stores. Internet searches on manufacturer pages will turn up less than nothing. Pause for a moment and reflect upon why BB was specifically called out in legislature on e-waste recycling. Mandatory free e-waste recycling at their stores.
First place I would start making corrections would be looking for evidence an alternative BIOS to replace compromised prebuilt OEM one with retail model is possible. This is a BIOS restriction followed by made to order SKU with likely lower quality expectations enforced by BIOS to make stability the only outcome.
Barring some highly rewarding outcome with provable results. Throwing new parts at a prebuilt is a fools errand. Sell it and get something capable or accept the realities of ownership without incurring higher expense for selfsame results.
BB and all their vendors, buyers, etc on down the line do not produce or sell products you can buy anywhere else. Kitchen appliances, accessory electronic cords, tv, computer, even Apple products are... it is all SKU specific to their line of stores. Internet searches on manufacturer pages will turn up less than nothing. Pause for a moment and reflect upon why BB was specifically called in legislature on e-waste recycling. Free e-waste recycling at their stores.
Thank you for taking the time to reply, you sound like you have some background in this. Can you help me let you know what BIOS I am running and you tell me if there is a better one I should install? That would be very helpful.
I don't want to create a false dialogue or expectations. We try to help, politely help.
You are asking more than this PC wants to provide and I feel there is reason to believe no parts replacement short of the motherboard will have the desired outcome. BIOS tied to this motherboard is very quietly conservative right up until you attempt getting forceful in attempts to make it work harder. System level development tying all these prebuilt parts together is very very deeply embedded.
In very basic terms - you bought a complete system and it should be respected as such. RAM or hard drive size upgrade, all good. System parts, historically a very low percentage of good outcomes. BIOS replacement was red herring to get your awareness how deeply tied together performance is with this exact set of parts. That very directly includes the RTX3070 shipped with this prebuilt. If the pump on your AIO is faulty it should be replaced. This may produce acceptable results contrasting with the harder line alternative thinking I'm trying to display. This is not a case of all good and all bad or right and wrong. Warranty parts should be excluded from my statement. The system should be working properly in order to be assessed.
Your use case is more suited to a build completed with intelligent selection of off the shelf parts. Watching for deals and putting it together on your own will remove (Intel is currently less finicky) a wide range of issues you are facing. Plug and play for many years with only OS updates or game bugs interfering.
I just re-ran OCCT Power test with zero crashes, screenshots included... what does this mean?
Re-running the OCCT power test with Fur Mark CPU burner active. Still running fine.
It holds steady temps on 16 cores for CPU Burner but when I switch to 15 cores The temp rises about 1 degree every 30 seconds, now it is at 82 C. Still running 4 mins in, no issues, but hotter on 15 cores not 16.
So I just tried to play Nightingale 4 times, 3 crashing right at start screen, once when I went into settings right from start screen. Then on Afterburner I just turned the core nad memory clocks as low as possible and applied.
Booted up the game and got in, playing flawless for about 10 minutes. Esc, try to go to settings, noise, crash.
Any creative insight?
