- Jun 3, 2012
- 1,791 (0.41/day)
- Denmark
Processor | ryzen 9 5900x |
Motherboard | MSI B550 a-pro |
Cooling | Thermalright Peerless Assassin 120 |
Memory | 2x16gb 3600mhz cl 16 corsair vengeance lpx |
Video Card(s) | GIGABYTE GeForce RTX 3060 WindForce OC |
Storage | 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives |
Display(s) | LG 32GP850, IIyama G2470HSU-B1 |
Case | Corsair 5000D airflow tg |
Audio Device(s) | Yamaha R-N600A Triangle Esprit Titus Ez |
Power Supply | Corsair RM850X White |
Mouse | Logitech G PRO Superlight |
Keyboard | Corsair K70 RGB TKL Champion |
Software | Windows 11 64 bit, Free bitdefender |
I have rma'ed my Asus Maximus Vii Ranger Z97 mb and currently using a msi Z97S SLI KRAIT with my artic F12 PWM case fans, i don't think it is doing a good job keeping the fans at a constant low rpm.
Most of my artic fans i am using in pst mode and since i have asked on another forum about how long rma could take, (could take many weeks before i get a new mb or my old back, 100% working) i would have to get a fan controller to be able to better control the fan speed, unless i want to wait for my old mb or a new one to aarive from rma (could take weeks), i have ordered the NZXT Sentry Mix 2 for 6 fans which is exactly how many case fans i use.
https://www.nzxt.com/product/detail/129-sentry-mix-2-fan-control.html
My Msi mb can go as low as 25% for my Noctua NH-D15 cpu cooler, but unfortunately it can only go as low as 50% for case fans,(The NZXT fan controller can go as low as 40%) but according to artic specs my fans are surpose to be able to run as low as 200-300 rpm or 20% pwm = low noise.
If i want to run my fans at 20% and up using the NZXT Sentry Mix 2 fan controller can i use low noise fan adapters like the ones from noctua http://www.noctua.at/main.php?show=productview&products_id=69&lng=en which is not that expensive considering how much noctua fans costs, to make the minimum speed less then 40% (closer to 20% then 40%)
