AsRock
TPU addict
- Jun 23, 2007
- 19,254 (2.95/day)
- UK\USA
Processor | AMD 3900X \ AMD 7700X |
Motherboard | ASRock AM4 X570 Pro 4 \ ASUS X670Xe TUF |
Cooling | D15 |
Memory | Patriot 2x16GB PVS432G320C6K \ G.Skill Flare X5 F5-6000J3238F 2x16GB |
Video Card(s) | eVga GTX1060 SSC \ XFX RX 6950XT RX-695XATBD9 |
Storage | Sammy 860, MX500, Sabrent Rocket 4 Sammy Evo 980 \ 1xSabrent Rocket 4+, Sammy 2x990 Pro |
Display(s) | Samsung 1080P \ LG 43UN700 |
Case | Fractal Design Pop Air 2x140mm fans from Torrent \ Fractal Design Torrent 2 SilverStone FHP141x2 |
Audio Device(s) | Yamaha RX-V677 \ Yamaha CX-830+Yamaha MX-630 \Paradigm 7se MKII, Paradigm 5SE MK1 , Blue Yeti |
Power Supply | Seasonic Prime TX-750 \ Corsair RM1000X Shift |
Mouse | Steelseries Sensei wireless \ Steelseries Sensei wireless |
Keyboard | Logitech K120 \ Wooting Two HE |
Benchmark Scores | Meh benchmarks. |
Does it work using the RCA\Phono outputs ?, or does the tuner work ? ( try without DSP settings ). if no maybe the DSP chip is\has failing which is a very common problem with receiver HDMI devices.
I have 677 unit here and it's not to bad, how ever the HDMI HDCP meets your requirements as it don't support HDCP 2.2 which maybe or may not be a concern.
EDIT: If the RX-v677 is on your list make sure the HTR-6067 and RX-A740 as they are pretty much the same units.
Well, I already started looking for another make and think between Yamaha RX-V677 or Sony STR-DN1050 or other which supports 4K!
What is your advice as pro in this category!
