I'm attempting to resurrect an old Surface Pro. The battery died and soon after the performance tanked... A friend suggested ThrottleStop as he said the CPU is throttled when the battery is end of life. Installed TS and on first use the Settings & Monitoring GUIs started. Today I tried to start TS and only the Monitoring GUI comes up. No Settings screen. Any suggestions on getting the settings (left) screen to display? I did try deleting the config file, no luck. Thanks
