Orthos Stability and CPU Help.
JrRacinFan
Served 5k and counting ...
20,126 (3.03/day)
Youngstown, OH
System Name Snow White
Processor Ryzen 7900x3d
Motherboard AsRock B650E Steel Legend
Cooling Custom Water 1x420
Memory 32GB T-Force Deltas
Video Card(s) PowerColor 7900 XTX Liquid Devil
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Tt CTE 600 Snow Edition
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Corsair K65 Mini
Benchmark Scores Avermedia Live HD2
Can anybody else make sense of this ....
To myself it looks like first core is fried, I have my cpu core voltage set for 1.4. Would it need a little more?
Also, in case you want to know
Never used that option in Orthos, but when I would use it, I remembered that usually the cores would finish the calculations differently, although that does look to be a big difference, did it change after more time or just stay there?
It just takes a little longer for CPU 0 to process calculations in that test. Right now im doing a blend. . ..
Hmmmm
When I have done the blend the cores usually get off but it takes a while, maybe drop to stock speeds and test everything?
K, will do that and report results with a few quick runs.
Sorry for the double post but ....
Jeebus! Triple post and I think everything is good to go .....
Bumped it up to 1.44.
Anyone have any ideas on how I can lower temps or be able to lower my vcore needed?
