Brightness is an issue but not the way people think... The oled gets bright -- super bright, much brighter than most gaming monitors but only at about 1/4 - 1/2 of the screen holds that brightness.
This is the biggest drawback to using it as a work monitor is the ABL / DIMMING features, as these are by far the most annoying:
-- i.e. OLEDS can't display a full white screen at full brightness - they dim, so for flashing or like bright games that use white screen effects (when you exit a tunnel into the outside, for example) this is noticeable.
-- if you maximize a WHITE / mostly white browser window full screen (like TPU) this will happen,
-- if you keep the white window up with static content for any amount of time, it will also sense that there is no motion and dim - You can disable this feature but at stock this is what will happen.
Picture quality, especially in moving scenes and games and motion response and input latency are just nuts on it. Better than any IPS i've had. It's fast enough for me to comfortably play competitive shooters at 48", with insane visuals. It also helps that the target is usually the size of a coaster.
If you're mostly doing work / excel and you like white/light themes on the desktop and only game a seldomly then I would get something else. For gaming there isn't really a much better display, esp if you like HDR.
I also own a Samsung G7 and an Alienware 34DW (ips) and i can say that the OLED is by far the display with the least compromises of them when it comes to visual quality and gaming, and the most when it comes to work.
(2) SECRET LG Oled Menu For BX, CX, GX, WX, And ZX 2020 Models! - YouTube <- definitely do this when you get it, it makes the colors look insane.
