Please Help! W10 limiting ethernet download speed
TheB
2 (0.00/day)
I have Comcast internet with the 1200 mbps. No matter what I do I can not get my computer to hit much above 300 mbps download Here is a link to results history. https://www.speedtest.net/results?sh=86c765dd21d39a1dbf31949539a092c3
My computer is an Asrock z87 Extreme 6 with an i7 4770 slightly OC to 4.2 ghz and 20 gig of ram. Not the latest but still a pretty fast system I have updated all drivers and even tried another network card using a USB-2 interface which needed an addon card. Same results.. Last run on the Chromebook over wifi was 372 mbps.
I have a basic Asus Chromebook which gets 349 mbps over wifi Using the external ethernet connection I get 925-960 mbps.
WTH? I'm at a complete loss on what to try next. Anyone have any suggestions, this is driving me crazy!
7,084 (1.04/day)
Asked my ISP.... 0.0
System Name Lynni PS \ Lenowo TwinkPad T480
Processor AMD Ryzen 7 7700 Raphael \ i7-8550U Kaby Lake-R
Motherboard ASRock B650M PG Riptide Bios v. 2.02 AMD AGESA 1.1.0.0 \ Lenowo 20L60036MX Bios 1.47
Cooling Noctua NH-D15 Chromax.Black (Only middle fan) \ Lenowo WN-2
Video Card(s) Asus GeForce RTX™ 4070 Dual OC GPU: 2325-2355 MEM: 1462| Nvidia GeForce MX™ 150 2GB GDDR5 Micron
Storage Gigabyte M30 1TB|Sabrent Rocket 2TB| HDD: 10TB|1TB \ SKHynix 256GB 2242 3x2 | WD SN700 1TB
Display(s) LG UltraGear 27GP850-B 1440p@165Hz | LG 48CX OLED 4K HDR | AUO 14" 1440p IPS
Case Asus Prime AP201 White Mesh | Lenowo T480 chassis
Keyboard Akko 3108 DS Horizon V2 Cream Yellow | T480 UK Lumi
Software Win11 Pro 23H2 UK
What CAT rated cable are you using? Plus is it possible to test with a PCI-E ethernet card just to see that it's not the onboard nic that have a weird issue?
You could also try to run a iperf test between 2 devices on your network to see what your onboard nic really can do on your motherboard and then if you verify that you can get like 900-1000Mbps in iperf then try a online server.
Not a year ago I used iperf test to prove to a COAX ISP that their Sagemcom PS router was not giving the speed on LAN that they could test to COAX.
20,787 (3.41/day)
System Name Pioneer
Processor Ryzen R9 7950X
Case Thermaltake Core X31
Software Gentoo Linux x64
You will need a multigig ethernet adapter to see over 1000mbps. Such cards are very modern tech. You'll furthermore never see speeds even near 1000 on a usb2 card, or wifi.
7,084 (1.04/day)
Or get a 2.5G, 5G or 10G card shouldn't that be fine?
20,787 (3.41/day)
System Name Pioneer
7,084 (1.04/day)
Any of those qualify as multigig, so yes.
But it's also important if he goes through and long cables or switches that they take the speed otherwise he will be back to square one.
20,787 (3.41/day)
System Name Pioneer
Yeah, if not a relatively short run he should be using CAT6A cables.
If it's short you can get away with plain CAT6 or CAT5e maybe even.
TheB
2 (0.00/day)
I have a new cat 7 . I did test (as I said) with a USB-c to Ethernet card which gave me 920 n- 950 mbps on a Chromebook so I trust that interface, This is a short cable, 6 feet.
20,787 (3.41/day)
System Name Pioneer
Thankfully not. 2.5/5G NICs rolled out in force in the last decade and a decent mid-spec 2.5G NIC can be had for barely $30.
I meant vs his mobos builtin hardware, but I hear you.
Mussels
Freshwater Moderator
58,413 (8.18/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Interested in this one, and how it pans out
Gigabit should get around the 950Mb mark reliably, although USB 2 devices wont come close
(USB 3 or PCI-E gigabit cards are the minimum)
