alexp999
Staff
- Jul 28, 2007
- 8,012 (1.31/day)
- Dorset, UK
System Name | Gaming Rig | Uni Laptop |
Processor | Intel Q6600 G0 (2007) @ 3.6Ghz @ 1.45625v (LLC) / 4 GHz Bench @ 1.63v | AMD Turion 64 X2 TL-62 2 GHz |
Motherboard | ASUS P5Q Deluxe (Intel P45) | HP 6715b |
Cooling | Xigmatek Dark Knight w/AC MX2 ~ Case Fans: 2 x 180mm + 1 x 120mm Silverstone Fans |
Memory | 4GB OCZ Platinum PC2-8000 @ 1000Mhz 5-5-5-15 2.1v | 2 x 1GB DDR2 667 MHz |
Video Card(s) | XFX GTX 285 1GB, Modded FTW BIOS @ 725/1512/1350 w/Accelero Xtreme GTX 280 + Scythe sinks| ATI X1250 |
Storage | 2x WD6400AAKS 1 TB Raid 0, 140GB Raid 1 & 80GB Maxtor Basics External HDD (storage) | 160GB 2.5" |
Display(s) | Samsung SyncMaster SM2433BW @ 1920 x 1200 via DVI-D | 15.4" WSXGA+ (1680 x 1050 resolution) |
Case | Silverstone Fortress FT01B-W ~ Logitech G15 R1 / Microsoft Laser Mouse 6000 |
Audio Device(s) | Soundmax AD2000BX Onboard Sound, via Logitech X-230 2.1 | ADI SoundMAX HD Audio |
Power Supply | Corsair TX650W | HP 90W |
Software | Windows 7 Ultimate Build 7100 x64 | Windows 7 Ultimate Build 7100 x64 |
Benchmark Scores | 3DM06: 19519, Vantage: P16170 ~ Win7: -CPU 7.5 -MEM 7.5 -AERO 7.9 -GFX 6.0 -HDD 6.0 |
Okay, rather than writing out it all myself. Someone over at Pc perspective forums has worded it perfectly.
Then they update with this:
Source
Now everytime I turn the PC off at the mains, when I turn it back on and boot it, it powers up then after about 1 sec it turns off for about 2 secs then repowers up. usually what happens on a bad oc or bios flash, and I'm assuming it boots from the other chip. Leaving it on at the mians and its fine. although, yeasterday night, I clicked shutdown and the PC rebooted but doing the same on and off thing. The only differene with mine over this guys problem is that I DO NOT lose my settings.
Would it by worth trying to swap out the bios chips? or am I using the wrong bios flash program have used windows and ezflash in the bios (when i had nothing but problems with my previous mobo, the only thing that fixed it was a dos bios flash - boot from floppy) but the bios file is 2MB!!! How do i do it!
Only other thing I can think of is that maybe the bios chips were installed the wrong way round at the factory?? please help guys!.
Cheers!
any time i switch power off from my system completely, using the psu switch or unplugging the power cable, EZ Flash wants to reflash my bios.
it's getting to be darn annoying, i have to reset all my settings every time, it even loses my oc profiles.
could this be a dead cmos battery?
update: switched the battery with one from my last board and it still does this. even checked the battery in the board with the multimeter and it reads 3v.
it does this whether i flash to the original bios or the updated official bios.
gonna try a beta bios and see if it still does it, otherwise i just can't figure it out.
made sure the cmos jumper is in the correct position too btw.
i think i fingered it out.
posted this in another thread, but it really should be in here too, in the rare case this happens to somebody else.
as a last ditch effort i decided to switch the bios chips, literally just put one in the others space.
booted fine, flashed to a newer bios, powered down the system completely like before and it booted fine, tried it a couple times. this would have forced me to reflash before.
my guess is the main bios chip was bad, so what that means is if this good bios chips gets corrupted somehow, i'm totally screwed, i'll need to get a new bios chip somehow, in the past asking for one never worked, but maybe asus will throw me a bone, otherwise i'll have to buy one from somewhere, none of my old boards use this sort of bios chip, otherwise i'd just use my old bios savior.
anyways, anyone know where i can purchase bios chips?
Source
Cheers!
