Problem with Board power sensor on GPUz 2.60 and 2.66
5,829 (1.03/day)
Gougeland (NZ)
System Name Cumquat 2021
So I have just noticed the when I run GPUz and perform the GPGPU test using the graphics card the sensor reading for GPU Board power does not read properly
See pic above where it only reads 20W for Board Power Draw and then below pic is when I turn on AMD's onscreen sensor readings
It now reads the correct Board power Draw as seen in the uptick everything else reads it correctly AIDA, AMD Sensor, HardINFO
it also happens with the ? PCIe Render test until I start AMD onscreen Sensors it will only say 20W in the Board Power Draw section aswell
Just back from holidays. That's very interesting .. especially considering other apps show the correct info, they are all reading from the same sensor through the driver. Will look into it in the next days.
This is Windows 11, latest AMD drivers?
Yup windows 11 Pro 24H2 latest drivers for both chipset and GPU
