Sunkist123
- Nov 11, 2022
- 8 (0.01/day)
I have a desktop PC. The Acer monitor is much older than the Dell PC tower. Both were working fine til a couple of months ago.
The tower appears to be working. However, most times when I try to start the system, monitor does not fully go on. For the most part the screen stays black, but occasionally the brand logo flickers briefly.
I've disconnected and reconnected both ends of all cords. Although I usually use a power bar, I tried plugging the cords directly into the wall. Otherwise, all I've been able to do is turn off the power bar, turn it back on, and hope it starts. I know this isn't good for a PC; in most cases numerous attempts have caused it to start, but there have also been a few instances (like today) where it will not start at all.
I've never used the on/off button on the monitor. When finished with computer, I log off, shut the computer down, turn off power bar, and disconnect it from the wall. I tried pressing the on/off button to see if that'd make a difference, but the button doesn't seem to work. It continues to flash gold-green, instead of staying solid green as it should when it is on.
Before the problem started, I hadn't moved either of the components. All I did around that time was try to clean dust off the back of the monitor- and don't know if some may have fallen into it. The monitor is not one that can be opened. I also learned long ago that compressed air is useless.
In the meantime, I'm losing a lot of work time, and have important emails I need to address, but can't do anything without a working PC.
Would someone here know what is causing this problem?
