PS3 to GPU??
433 (0.09/day)
Processor Core i5 3470 (3.20 GHZ)
Cooling Intel OC27vv
Memory 16 GB DDR3 667mhz
Video Card(s) XFX Radeon HD 5670
Storage Seagate - 500GB | 7200RPM | 32MB Cache | Sata-3G
Display(s) BenQ RL2455
Case Dell Tower
Audio Device(s) On-board
Power Supply Corsair 600w
My television decided it wanted to crap out on me. Is it possible to connect a PS3 directly to the GPU? I know it will work psychically, because HDMI to HDMI. But how do you select the source so the PS3 will display on the monitor? Do I need to purchase a DVI to HDMI adapter instead?
874 (0.16/day)
Nairobi, Kenya
Processor Intel Core Ultra 7-265K
Motherboard ASUS ROG STRIX Z890-A
Cooling ID-Cooling FROZN A620 Pro SE
Memory Crucial Pro 96GB Kit (48GBx2) DDR5-5600
Video Card(s) Intel ARC A770 Limited Edition
Storage Solidigm P44 Pro (2TB x 2) / PNY CS3140 2TB
Display(s) Philips 32M1N5800A
Case Lian Li O11 Air Mini (White)
Power Supply Seasonic Prime Fanless Titanium 600W
Keyboard Dell KM714 Wireless
Software Windows 11 Pro x64
No, you realize GPU (Graphics Processing Unit) eg NVIDIA Geforce or AMD Radeon
On the other hand you can connect your PS3 to a Monitor/Display that has DVI-D, HDMI or Display Port
Kreij
Senior Monkey Moderator
13,817 (2.08/day)
Cheeseland (Wisconsin, USA)
As Prot stated, you cannot plug the output of your PS3 into your GPU (they're both outputs).
Unless the GPU card has a HDMI-pass through function, your out of luck.
You can plug it into the monitor (if it has an HDMI port) or you can get a HDMI switcher (2 in, 1 out, switch with button or whatever) so you don't have to switch cables when you want to use one device or the other.
433 (0.09/day)
Case Dell Tower
How can I tell if my GPU supports pass through? I have an ATI Radeon HD 5670.
So it seems like my only option is to get an HDMI to DVI?
Kreij
13,817 (2.08/day)
Your card does not support pass-through. It would have to have 2x HDMI port on the back to do so (and then the hardware on the board to allow it).
If you are using the HDMI port on the 5670 as output, using a HDMI switcher would be your best bet. One cable from the GC to the switcher and one from the PS3 to the switcher, and then one cable from the switcher to the monitor.
433 (0.09/day)
Case Dell Tower
Okay, thanks to you both! Happy Holidays! =)
lyndonguitar
I play games
1,878 (0.34/day)
Philippines
System Name X6 | Lyndon-ROG
Processor Intel Core i7-8700k | Intel Core i7 6700HQ
Motherboard Gigabyte Z370 Aorus Gaming 5 | Asus ROG-GL552VX
Cooling Deepcool Captain 240EX
Memory 16GB Corsair Vengeance LED | 8 GB
Video Card(s) NVIDIA GTX 1080 8 GB GDDR5X | NVIDIA GeForce GTX 950M 4GB
Storage SSDs: 500GB, HDDs: 2TB, 2TB, 3TB | SSD: 250GB, HDD: 1TB
Display(s) Samsung 49" CHG90 3840x1080@144Hz, Panasonic 32" HDTV, | 15.6"1080p
Case Cougar Panzer Max
Audio Device(s) HyperX Cloud II | Corsair Gaming H1500 7.1 | ROCCAT Kave 5.1 | Edifier M3200
Power Supply EVGA 750GQ
Mouse Logitech G403 | Razer Deathadder Chroma | Logitech G302 | Mad Catz Cyborg R.A.T. 5
Keyboard Corsair Vengeance K70 Cherry MX Red
What do you mean decided to crap out on you? If only the HDMI of the TV itself is "crapping out", then you can still use a ps3 component cable for the meantime, or just plug in the PS3 to the Monitor.
433 (0.09/day)
Case Dell Tower
It started about six months ago, or so, not really sure. My TV would lose picture, then the picture comes back in. From then to now it was a rare occurrence. Now, it's worse! It happens about ever five secs. My TV would go black for few secs then come back in again. I thought it was my PS3. So, I decided to watch cable TV, and it does the same but not as frequent. I wonder if both HDMI ports are going bad. When it happens, it never display "No signal" just total blackness. Perhaps I shouldn't have thrown the A/V cables away. =(
JrRacinFan
Served 5k and counting ...
20,126 (3.04/day)
Youngstown, OH
System Name Snow White
Processor Ryzen 7900x3d
Motherboard AsRock B650E Steel Legend
Cooling Custom Water 1x420
Memory 32GB T-Force Deltas
Video Card(s) PowerColor 7900 XTX Liquid Devil
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Tt CTE 600 Snow Edition
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Corsair K65 Mini
Benchmark Scores Avermedia Live HD2
First thing I would check is the cable itself being bad. I have an HDMI cable here that's chincy cheap that will only display 720p that used to not have a problem with 1080i.
433 (0.09/day)
Case Dell Tower
What kind of HDMI cable do you recommend? The old thing about this whole ordeal, I tried the A/V video cables that came with the PS3, and I get "no signal" it doesn't even try to detect the PS3 via A/V
JrRacinFan
20,126 (3.04/day)
Youngstown, OH
Storage 20+ TB
Any kind would do. Now that you mention the A/V problem, just double check your connection and make sure you're hooked up to an input instead of an output.
433 (0.09/day)
Case Dell Tower
My television only has one A/V. With the PS3 plugged in, it does not get a signal. So, I decided to try an old DVD player, it worked. It also support HDMI and it does the same thing as the PS3; pictures goes in and out. I'll replace the cables and hopefully that will fix my problem. How often do HDMI cables go bad? They are less than a year old.
JrRacinFan
20,126 (3.04/day)
Youngstown, OH
Storage 20+ TB
