- Jan 25, 2009
- 496 (0.09/day)
System Name | The Venerable One |
Processor | Intel Core i7 980x 3.33GHz |
Motherboard | EVGA X58 FTW3 |
Cooling | Big Ass fan pointed at the motherboard with the side panel off FTW |
Memory | 12GB DDR3 1333 |
Video Card(s) | EVGA GeForce GTX 680 Superclocked X2 in SLI |
Storage | Samsung 840 Pro 256MB SSD/1.5TB HDD internal |
Display(s) | Samsung SyncMaster 2443BWX 24" 1920X1200 |
Case | SK-503 Super Case |
Audio Device(s) | X-Fi Xtreme Music |
Power Supply | SeaSonic 1000W Platinum Rated |
Software | Windows 7 Home SP1 64-bit |
Benchmark Scores | epic |
All,
My voltages are way low in Speedfan and my system doesn't work right as well. I haven't run any business apps, but game emulators like Dolphin and PCSX don't work right at all. Games that should be @ constant 60 FPS, aren't. I know the PSU is fine because I used it in my last system and it worked just fine with normal voltage readings. Ever since I put it in the new build though, the voltages have been too low from the start. Do I need to replace the motherboard or is there a way I can fix this? Here are the readings and see the attached screenshot.
Vcore1: 1.01V -12V: -4.13V
Vcore2: 2.11V -5V: -0.78V
+3.3V: 1.57V +5V: 5.54V
+5V: 6.85V Vbat: 3.15V
+12V: 4.74V
thx all
+12V: 4.74V
thx all
