pubg low gpu usage
8 (0.00/day)
Processor R5 2600 @ 3.6
Motherboard ROG B450-F
Cooling Stock
Memory (hyperX Fury 8GB DDR4-3200 CL18 ) x 2 Dual-channel
Video Card(s) rx vega 56 msi air boost oc (1660MHz - 875MHz)
Power Supply cooler master masterwatt lite 700 watt 80 plus
my specs :
r5 2600 (non oc)
rx vega56 8gb (oc + uv)
2x8 3200MHz ram
i don't know what is the problem since i play any game without issues
but when i play pubg, i have a strange gpu utilization issue
ultra settings = 95% or above gpu usage = 80 - 100 fps
competitive settings = 70% or below = 60 -90 fps
every thing is perfect ( bios up to date - set xmp to the max - win 10 up to date - all drivers up to date )
32 (0.02/day)
Los Angeles CA
Processor i7 9700K @ 5.0ghz
Motherboard ASROCK Phantom Gaming Mini ITX
Cooling NZXT Kraken X62
Memory Crucial 16GB RAM @ 3200mhz
Video Card(s) EVGA RTX 2080 Super
Storage 2TB Silicon Power NVME M2
Display(s) Dell 27" 1440p 144hz
Case NZXT H200i
Audio Device(s) Corsair Void RGB Wireless Headset
Power Supply Seasonic 650
Mouse Steel Series Rival 650 Wireless
Keyboard Corsair K65 RGB Mechnical Wireless
Software WIN 10
I have no idea , very odd. And this is the only game thats causing this issue for you?
2,455 (1.18/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
what power supply do you have?
8 (0.00/day)
Cooling Stock
yes, thats the only game cause this issue
700 watt 80 plus (cooler master masterwatt lite)
i think there is no problem with it , i test it with many different benchmark programs like heaven for about an hour and the watt consumption is stable .
19,381 (3.46/day)
It isn't the power supply. You dont get less fps if it is failing. ;)
When you say competitive settings, what exactly does that mean compared to ultra? No resolution change right? Just turning a bunch of settings down? 1080p, yes?
If you overclock the cpu, do you get more fps and GPU use?
8 (0.00/day)
Cooling Stock
yes the same resolution 1080p, all settings on very low except AA and Texture on ultra , oc the cpu to 3.9 make no difference to gpu usage and fps .
crazyeyesreaper
Not a Moderator
9,841 (1.67/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
PubG is unbalanced and doesnt typically run all that well on AMD hardware, your also using an Older AMD GPU. Back when the game came out aa Vega 56 was lucky to get 60 FPS when a 1080 Ti was getting a 120+
Even as they have improved the game performance on AMD GPUs has never really been stellar. So while performance has improved at the end of the day PubG remains fairly unoptimized and at 1080p Ultra settings performance is all over the board and dropping settings doesn't typically improve performance all that much. The game is just a hodge podge of issues sometimes its great other days forget it.
In today's version of the game going from say 1080p ultra to 1080p medium on a Vega 56 your likely only to go from around 90 fps or so to 110 fps or so.
Its the game not your hardware and a google search and reviews of the games performance will tell you this.
Back in the day PubG tried suing Epic over support of Unreal Engine 4, at this point Epic has fixed all the major issues they were having but PubG made a bunch of changes and custom code, so older engine, with issues numerous patches and fixes to gloss over issues results in a game that honestly doesn't run that well considering the level of hardware you can throw at it.
Last i knew the game was using unreal engine 4.14 or 4.16. Considering that was 2019, and the Unreal Engine is on 4.25 with Vulkan support. With the launch of version 4.2 of UE they typically saw a 30% performance bump on AMD hardware. Obviously PubG hasn't gotten there yet and likely never will. Games fairly old now and their mismanagement and lack of improvements and drawn out issues means Fortnite eclipsed it long ago. Even if I still prefer PubG myself its no longer the shiny battle royale game.
2,455 (1.18/day)
LV-426
System Name Custom
Processor i9 9900k
Mouse Logitech G403
yeah its not failing :), but could possibly be not supplying enough juice..
4,667 (0.69/day)
Washington, US
System Name Rainbow
Processor Intel Core i7 8700k
Motherboard MSI MPG Z390M GAMING EDGE AC
Cooling Corsair H115i, 2x Noctua NF-A14 industrialPPC-3000 PWM
Memory G. Skill TridentZ RGB 4x8GB (F4-3600C16Q-32GTZR)
Video Card(s) ZOTAC GeForce RTX 3090 Trinity
Storage 2x Samsung 950 Pro 256GB | 2xHGST Deskstar 4TB 7.2K
Display(s) Samsung C27HG70
Case Xigmatek Aquila
Power Supply Seasonic 760W SS-760XP
Mouse Razer Deathadder 2013
Keyboard Corsair Vengeance K95
Benchmark Scores 4 trillion points in GmailMark, over 144 FPS 2K Facebook Scrolling (Extreme Quality preset)
8 (0.00/day)
Cooling Stock
8 (0.00/day)
Cooling Stock
  • Wow
Reactions: xvi
4,667 (0.69/day)
Washington, US
System Name Rainbow
3,984 (1.08/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
my cpu can not reach 3.7 don't no why ( update bios to latest and enable D.O.C.P )
That would be your problem. As you start scaling down graphics, the CPU becomes more of a restriction (doesn't mean it is, just more prominent).
If your CPU can't get past 3.7 you either have miserable cooling or you need to check some UEFI settings.
Off topic but I love how competitive settings mean making the game look like shit.
Edit: Also, if you don't have a monitor with at least 100fps, then you are chasing stuff that will do you no good other than fixing this a clock problem.
miller11
14 (0.01/day)
Time to time the same happens to me, 1080p.
Kanan
Tech Enthusiast & Gamer
3,517 (0.99/day)
Europe
System Name eazen corp | Xentronon 7.2
Processor AMD Ryzen 7 3700X // PBO max.
Cooling Noctua NH-D14 SE2011 w/ AM4 kit // 3x Corsair AF140L case fans (2 in, 1 out)
Memory G.Skill Trident Z RGB 2x16 GB DDR4 3600 @ 3800, CL16-19-19-39-58-1T, 1.4 V
Video Card(s) Asus ROG Strix GeForce RTX 2080 Ti modded to MATRIX // 2000-2100 MHz Core / 1938 MHz G6
Storage Silicon Power P34A80 1TB NVME/Samsung SSD 830 128GB&850 Evo 500GB&F3 1TB 7200RPM/Seagate 2TB 5900RPM
Display(s) Samsung 27" Curved FS2 HDR QLED 1440p/144Hz&27" iiyama TN LED 1080p/120Hz / Samsung 40" IPS 1080p TV
Case Corsair Carbide 600C
Audio Device(s) HyperX Cloud Orbit S / Creative SB X AE-5 @ Logitech Z906 / Sony HD AVR @PC & TV @ Teufel Theater 80
Power Supply EVGA 650 GQ
Mouse Logitech G700 @ Steelseries DeX // Xbox 360 Wireless Controller
Keyboard Corsair K70 LUX RGB /w Cherry MX Brown switches
VR HMD Still nope
Benchmark Scores 15 095 Time Spy | P29 079 Firestrike | P35 628 3DM11 | X67 508 3DM Vantage Extreme
Classic old game CPU bottleneck problem, Ryzen 2nd gen has not enough clock to satisfy this game which underutilizes modern CPU's (doesn't use all cores the CPU has). But you can be happy it is only 5% GPU util that you're losing out on. I had much worse problems with GTA 5 and 1080 TI before I switched to the new system.
PS. I'm not sure the "overclock" you did for just 200 MHz over baseclock is worth it. I'm pretty sure it is not. AMD Ryzen is best left alone, the max single core boost is 3.9 GHz, a lot better than the manual clock you chose. I would try, reverting back to that and using PBO / XFR2 instead.
Adismo
1 (0.00/day)
I just find the answer! Your AMD gpu are limited by your limiter power in your panel settings by default 0, just slide to 10 to give all the power that your gpu needs and you will get the 100 usage
