Risk with 3.3v rail out of range?
349 (0.06/day)
Valencia, Venezuela
System Name Tropicaliente | A515-43-R19L
Processor FX-6300 | R3 3200U
Motherboard ASRock 970 Extreme 4 | Grumpy_PK
Cooling EVGA CLC120 | Stock
Memory 16GB DDR3-1600 | 16GB DDR4-2666
Video Card(s) PowerColor RX-570 4GB Red Dragon | Vega 3
Storage 256GB SSD (OS) + (512GB+256GB) SSD (Games) + 2TB HDD | 128GB NVME + 512GB SSD
Display(s) Asus VN247H-P | 15.6" FHD
Case Antec ONE
Audio Device(s) on board + Logitech Z623 | on board
Power Supply MSI MAG A600DN | Powerbrick ac/dc
Mouse MS Wired Desktop 600
Keyboard MS Wired Desktop 600
Software Win 11 x64 Pro | Win 10 x64 Home
I have a corsair tx750w since 2 years ago, but I've noticed that voltage on 3.3v rail has been decreasing over time.
I know it must be 3.3v ± 5% which means any reading between 3.135v and 3.465v is ok,
3.3v is an orange wire at "20+4pin & sata connectors only" (not molex, nor pci-e, nor 4+4pin connectors).
My pc is on 24/7 and I've noticed the following...
If pc is on for long time, 3.3v rail readings begin to fall.
I switched pc off for 5 or 10 minutes, then I switch it on and readings go back to normal.
A month ago it was 3.26v idle and 3.22v full load,
but now it's 3.136v idle and 3.072v full load,
and didn't back to normal after doing powercycle.
I have 2 gfx cards(570 + 460) and "full load" means both cards running FAH-gpu.
If I take out 570 and leave 460 only, readings are: 3.182v idle and 3.154v full load.
All voltage reading were made with Everest (don't have a multimeter) and they match idle reading in bios.
Well...
I know the easiest and fastest solution is buy a new psu but...
What is the worst thing could happen if I don't buy a new psu?
Could this problem burn any component?
Which could be the more sensitive to get damaged?
MB & sata drives right? Or am I wrong?
Thanks in advance.-
qubit
Overclocked quantum bit
17,865 (2.81/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Your PSU is faulty and must be changed. Is it still under warranty?
As the voltage is apparently simply dropping, then you will eventually see a malfunction, but no damage to your PC. However, it may be spiking, which you can't see and this may well damage your PC.
Running a faulty PSU is never a good idea, especially with two graphics cards.
I don't know what devices use 3.3v nowadays, so the PC may not notice the problem at all.
Using a failing PSU is never a good idea, however. The fault will spread and unbalance the rest of it, which could lead to voltage spikes, which may well take out your PC. Note that as this is a quality brand, the protection circuits in it are likely to save you, but don't rely on them.
4,815 (0.74/day)
Wangas, New Zealand
System Name Darth Obsidious
Processor Intel i5 2500K
Motherboard ASUS P8Z68-V/Gen3
Cooling Cooler Master Hyper 212+ in Push Pull
Memory 2X4GB Corsair Vengeance DDR3 1600
Video Card(s) ASUS R9 270x TOP
Storage 128GB Samsung 830 SSD, 1TB WD Black, 2TB WD Green
Display(s) LG IPS234V-PN
Case Corsair Obsidian 650D
Audio Device(s) Infrasonic Quartet
Power Supply Corsair HX650w
Software Windows 7 64bit and Windows XP Home
Benchmark Scores 2cm mark on bench with a razor blade.
Something is not replenishing charge in your PSU from the sounds of things.
Most likely failing capacitors.
Since it is only getting worse then eventually your system is going to fail.
I personally thought the rail supplying 3.3v was directly to RAM.
349 (0.06/day)
Valencia, Venezuela
Case Antec ONE
Thanks for your answers.
I'll try to find the invoice in order to do rma,
anyways I think I'll buy a new one, may be more powerfull.-
p_o_s_pc
F@H&WCG addict
13,006 (1.98/day)
Newark ohio
System Name el'lappy|Cruncher | Cruncher 2
Processor intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz
Motherboard some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3
Cooling dual 80mm cooling fan | WC'ing ) |cheapo
Memory 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s
Video Card(s) onboard | 60 1GB(hd7770 ) |8800GTS
Storage Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD
Display(s) 17in | 42" 1080P HD 3D TV
Case lappy case | CM HAF XB |none yet
Audio Device(s) onboard | onboard | onboard
Power Supply Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon)
Software Windows 7 Ult. 64bit---->------->
if you can get it replaced but still want something else you could always sell it. People are crazy about that brand of PSUs so selling it shouldn't be hard at all.
349 (0.06/day)
Valencia, Venezuela
Case Antec ONE
:rolleyes:
How much could I ask for it the way it is?
p_o_s_pc
F@H&WCG addict
13,006 (1.98/day)
Newark ohio
:rolleyes:
I dont know that anyone would even pay for a defective PSU unless they had a way to get it replaced or has 1337 skillz and can repair them. maybe $20 shipped
4,815 (0.74/day)
Wangas, New Zealand
I agree $20 max.
There are people out there who can repair PSUs and have the spare parts to do so.
Out the back of where I work we have dozens of PSUs for machines which had been removed from machines.
349 (0.06/day)
Valencia, Venezuela
Case Antec ONE
Readings went back to normal:
3.248~3.264v idle
3.216~3.232v full load
Frick
Fishfaced Nincompoop
20,070 (2.87/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
The reading could be wrong too. My +12V line is apparently running at 9V, so always take software/bios voltage readings with a grain of salt.
You really need a multimeter or better yet an oscilliscope to see how it really does.
qubit
17,865 (2.81/day)
Quantum Well UK
Keyboard Yes
3.248~3.264v idle
It just means the PSU is intermittent. It's still faulty.
4,815 (0.74/day)
Wangas, New Zealand
I can say I have come across system boards which drained PSUs, but to the point where the the machine would not work.
I don't think it's the case here.
If you are going to just buy another PSU, I suppose you could try out this power supply in another machine when you have the chance and see if the drain is the same.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
I wouldn't do anything until I confirmed these readings with a multimeter. Even a cheap one from Harbor Freight would give more accurate reading than the sensors on the motherboard.
