RTX 2080 memory bandwidth issue
5,517 (1.03/day)
Hi w1z, seems like this RTX 2080 turned into an 8800GT :p
bug
14,337 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Maybe it deactivates bandwidth when it doesn't need it? :D
You know, like engines shut down cylinders?
218 (0.03/day)
Croatia
System Name Cabal
Processor intel i9 9900k @ 5.0ghz 1.33v - cache @ 4.7ghz
Motherboard Asrock z370 fatal1ty gaming k6
Cooling Corsair H115i with 2x Corsair LL140mm rgb fans
Memory Corsair Dominator Platinum 32GB(4x8kit) ddr4 4000mhz@4100mhz
Video Card(s) Msi rtx 5070ti Gaming OC 16gb
Storage samsung evo 860 500gbx2, sandisk 3d ultra 500gbx2, kingston hyperX ssd 480gb, Seagate Barracuda3TB
Display(s) Asus ROG Swift pg278q G-Sync
Case Corsair 760t Graphite Series with 3x Corsair LL140mm fans
Audio Device(s) Sound Blaster X ae-5
Power Supply Corsair RM850i
Mouse Roccat Tyon
Keyboard Corsair RGB Strafe mechanical keyboard
Software win10pro 64bit
yeah i noticed it too, very curious...maybe a gpuz needs an update maybe it is like bug said...
bug
14,337 (3.95/day)
No way it's like I said, I was just poking fun.
540 (0.17/day)
System Name Gaming PC / I7 XEON
Processor I7 4790K @stock / XEON W3680 @ stock
Motherboard Asus Z97 MAXIMUS VII FORMULA / GIGABYTE X58 UD7
Cooling X61 Kraken / X61 Kraken
Memory 32gb Vengeance 2133 Mhz / 24b Corsair XMS3 1600 Mhz
Video Card(s) Gainward GLH 1080 / MSI Gaming X Radeon RX480 8 GB
Storage Samsung EVO 850 500gb ,3 tb seagate, 2 samsung 1tb in raid 0 / Kingdian 240 gb, megaraid SAS 9341-8
Display(s) 2 BENQ 27" GL2706PQ / Dell UP2716D LCD Monitor 27 "
Case Corsair Graphite Series 780T / Corsair Obsidian 750 D
Audio Device(s) ON BOARD / ON BOARD
Power Supply Sapphire Pure 950w / Corsair RMI 750w
Mouse Steelseries Sesnsei / Steelseries Sensei raw
Keyboard Razer BlackWidow Chroma / Razer BlackWidow Chroma
Software Windows 1064bit PRO / Windows 1064bit PRO
maybe u need multiply that for 6 cos it use gdr6 XD
Ruru
S.T.A.R.S.
13,778 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
It just shows the "true", it doesn't recognize it as DDR. So multiply that with 4.
6,396 (0.87/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
The formula for calculating memory bandwidth is (bus bandwidth / 8) * (memory clock speed) * (memory type bits per cycle). So for stock GTX 2080 that's (256 / 8) * 1750 * 8 = 448 000 MB/s = 448 GB/s. My guess is that @W1zzard 's calc for memory doesn't know about GDDR6 (or isn't detecting it correctly) and is thus defaulting to standard DDR, which has only 2 bits/cycle versus GDDR6 which has 8 bits/cycle.
All the GPU-Z screenshots in the GTX 2080/2080 Ti reviews have the same issue... Wiz is gonna have to redo all of those once he fixes this bug!
Ruru
S.T.A.R.S.
13,778 (3.05/day)
Jyväskylä, Finland
So in a nutshell, this means that it's quadruple like GDDR5?
5,517 (1.03/day)
Memory bandwidth throughput is memory bandwidth throughput. It does not need calculations, multiplier or anything else. Never did.
I just put it here so w1zz could fix it. That's all. Basically what @Assimilator said
6,396 (0.87/day)
Ikenai borderline!
Mouse Logitech G604
Nope, octuple. GDDR5 is 4 bits/cycle which is why GTX 1070 needs to run its 256bit GDDR5 at 2GHz to reach "only" 256GB/s bandwidth, while RTX 2080's 256bit GDDR6 purrs along at a much lower 1.75GHz yet is able to reach almost double the bandwidth of 1070 @ 448GB/s.
On the other hand, GDDR5X (which GDDR6 is essentially the successor of) is also 8 bits/cycle, hence why GTX 1080 can get 320GB/s bandwidth (far higher than GTX 1070) at only 1250MHz memory clock (far lower).
1,042 (0.32/day)
Pristina
System Name My PC
Processor 4670K@4.4GHz
Motherboard Gryphon Z87
Cooling CM 212
Memory 2x8GB+2x4GB @2400GHz
Display(s) HP envy 32 1440p
Case CM Mastercase 5
Audio Device(s) Sbz ZXR
Power Supply Antec 620W
Mouse G502
Keyboard G910
Software Win 10 pro
O man i feel sorry for you, wasted money eh?
Ruru
S.T.A.R.S.
13,778 (3.05/day)
Jyväskylä, Finland
Ah, ok. It's always nice to be a little wiser. :D
bug
14,337 (3.95/day)
23,843 (6.15/day)
19,379 (3.46/day)
Will the Texture Fillrate GT/s issue on the 2080's also be fixed with the memory bandwidth correction? The 278.8 for the 2080 does not match the NV whitepapers.
19,379 (3.46/day)
BUMP. @W1zzard
(cant seem to edit this post??????)
Also had the question in another thread since wedesnday. Confirmation or if its just me would be great!
Low quality post by Tomgang
3,076 (0.82/day)
Nvidia has done it again. They gimped turing like they gimped Maxwell (GTX 970) if any one remember. This time its just more official:roll:
5,517 (1.03/day)
W1zz, GPU-Z has to be fixed to suite RTX cards.
Base clock slot became extremely irrelevant this time around.
Having default and current is fine when it is accurate - it isnt as for 2.11.0
No mention of RT or Tensor cores in any way.
Boost is just the official stuff, and while being in the same realm of Intel's CPU boost clocks, the numbers were not relevant since GTX 900 four years ago.
Maybe time to move those slots into real-time reading? or at least real time vs official in the box below.
No RTX 2080 Ti is going to operate at 1350Mhz core under 3D load.
Stuff has to change.
bug
14,337 (3.95/day)
Oh, good. For a moment there I was worried we ran out of people that can tell others what they need to do :p
