Sempron LE-1250 - Overclocking
michal13225
2 (0.00/day)
Hello everyone :D
I'd like to Overclock my CPU which is in Topic Title. Please tell, if someone already tune up this CPU, what is stable voltages, and FSB and please tell me what i should change in my BIOS of my MOBO.
My PC Spec:
CPU: Sempron LE-1250 AM2
Cooler: BOX
MOBO: ECS GeForce6100sm-m
RAM: 2GB (Aeneon AET760UD00-25DB97X and GoodRAM GR667D264L5/1G)
GPU: GF 8800GTS 320/320 (only for 1 day)/ GF 6150 nFroce 430 :shadedshu
PSU: Fortron ATX-300GTF / for 1 day I have a Enermax Modu82+ II
I had a lot of CPU in my life, and OC all of them but these was only Intel, not AMD, so please for explain every move i should do :D
you can try to raise the HT frequency but its seems your motherboard can't take it so you should be careful
its not the highest end board so just be careful not to pop the board. push the HT up i doubt you will get it over 250mhz you need to drop the ram down to a 667 divider. other than that it should be fine on stock volts
that chip can clock very well
that was on ln2 by knopflerbruce
I had that same CPU once, on the same motherboard I have now. My board isn't the best, but not as bad as yours (no offense). I know I got it to 3GHz stable, but I don't remember what voltage I used... might have been 1.30v. I let the HTT frequency climb with it. The only thing I changed was cpu voltage.
1.3v is about average on hwbot when i looked
300 on your Mobo? Wow!
Apparantly so... I was surprised too.
