Should I use DDU before installing drivers using NVCleanInstall?
Are you just upgrading the driver version? then no need for DDU
Generally I found very little use for DDU, unless there's issues.
No, I Am reinstalling using NVCLeanInstall to get fps boost, i am worried about residue, i read from other sources you should use DDU before you NVCleanInstall, it makes sense, just wanted to ask if that is necessary.
You know what never mind. I will probably use it to be sure, I never had an issue before.
While having all kinds of issues with Driver Updates in the past - DDU became a tradition for installing GPU/Sound Drivers (just to be sure - type of thing).
Tho, unless i notice any issues - where GPU drivers can be the culprit - i don't bother anymore with every new driver release. Even more than that - I switched from Game Ready Drivers to Studio Drivers - since i find the latter to be more stable. Maybe in the past was different - but i didn't notice any drops in FPS while using either GRD or SD. Then again... i guess they're simply staying true the name - rushing some Driver optimizations for recently released titles. Which i rarely play (been awhile since an upcoming released peaked my interest) - so others might see some improvement with those (be it higher FPS or resolved issues impacted by older drivers) .
Hmm I read it boosted fps sometimes for users, it is worth of trying! I Am very tight RTX 3070 2080mhz OC from 1935, 4800mhz 9600KF (CPU is barely not maxed), 3200mhz 2x8GB g.skill.
Should I try disable telemetry, do you think there is any potential for fps increase? IT is experimental, so i left it off for now...
I will try disable telemetry when using NVCleanInstall, any other interesting features that I could enable for fps boost?
I need every bit of boost for RE4 :D
