Speedtest without Flash, using HTML5
9,019 (1.37/day)
System Name Black Panther
Processor i9 9900k
Motherboard Gigabyte Z390 AORUS PRO Wifi 1.0
Cooling NZXT Kraken X72 360mm
Memory 2 x 8GB Corsair Vengeance RGB Pro DDR4 3600Mhz
Video Card(s) Palit RTX2080 Ti Dual 11GB DDR6
Storage Samsung EVO 970 500GB SSD M.2 & 2TB Seagate Barracuda 7200rpm
Display(s) 32'' Gigabyte G32QC 2560x1440 165Hz
Case NZXT H710i Black
Audio Device(s) Razer Electra V2 & Z5500 Speakers
Power Supply Seasonic Focus GX-850 Gold 80+
Mouse Some Corsair lost the box forgot the model
Keyboard Motospeed
Clicked begin test and it did nothing for me on my work computer.
Same here, stuck at finding server.
From my crap work PC
Works for me. Nothing unexpected as I've had the same 20/2 plan for probably 10 years now.
Worked for me, and it further confirms I have to take my ISP by the horns on why I'm getting a 23ms ping and barely 5Mbps download whereas I'm paying for 15Mbps...
Please Flash just go away
So, I've used Speedtest.net quite a bit. Gives very reliable results. I guess my question is, did it use Flash in the past and now is using HTML5? I was just curious why the specifics in the title.
As far as I know it's always been Flash until the new beta site that's linked on the OP post.
Oh okay, thanks! So the results may be different.
I use openspeedtest.net .. HTML5 and works on everything.
I'm paying for 50/15.. There's a Netflix stream running too so thats why DL is a little low.
50/50 fiber (using wifi and 2 other systems online) not bad.
Much snappier than the clunky old Flash interface. I miss the map, but other than that, I like it. 500/500 fiber from our office to Seattle. Between 150-200 combined in use pretty typically.
I actually quite like speedof.me, but the Amazon servers that host it don't have enough bandwidth for the faster connections. My tests max out just a little over 100Mbps.
Nice. I just wish that pingtest.net had a version that didn't need Java to work :(
  • Like
Reactions: xvi
All I see is a broken image...
Not real sure why it was doing that. You could click on it to see results so just switched to a link.
Still battling the WiFi driver on Windows 10. Should've been somewhere around 100 | 100Mbit/s.
HTML5 version is 4 times slower for both UL/DL for some reason.
