Strange AMD FX 8350 overheat problem
26,256 (6.05/day)
So a little update. I found the HPC setting and it had no effect. I also updated to the latest bios and that did not help. So I tried my CPU in my wife's system and her's in mine. The CPU I had shows 35*C idle in her system and her CPU is showing 62*C in mine. At this point I think my motherboard is the culprit. I think it's time to replace it.
Thermal sensor is bad, your choice of replacing it or getting a hsf contact thermometer.
I would suggest a Sabertooth 990FX or R 2.0
3,603 (1.06/day)
Oregon, USA
System Name GLaDOS
Processor AMD FX-9590 X8 4.7GHz
Motherboard ASUS Sabertooth 990FX
Cooling Corsair H80i v2
Memory Corsair DDR3 1333Mhz (4 x 4GB) with CMXAF2 GTL Cooler
Video Card(s) ASUS ROG-STRIX-RX580-O8G-GAMINGOC
Storage 3 WD 1TB
Display(s) 2 Acer S231HL 23" LED backlit LCD's on a Dual LCD stand
Case Corsair 600T White edition
Power Supply Corsair 850HXi 850W
Mouse Corsair Sabre RGB
Keyboard Corsair K70 LUX RGB
Software Microsoft Windows 10 Pro 64 Bit
Yeah, at this point I think it's a good excuse for an upgrade. I appreciate all the help!
144 (0.08/day)
System Name Blackbelt 2
Motherboard ASUS M5A99FX PRO R 2.0
Cooling Cooler Master Hyper TX3 evo
Memory 8GB Corsair Value Select DDR3
Video Card(s) ASUS R7260X DC2OC 2GB
Storage INTEL 530 series SSD 120 GB, Seagate Barracuda 1 TB 7200 RPM
Display(s) DELL ST 2240L
Case Cooler Master Elite 311
Power Supply CORSAIR VS Series 550W
Software Windows 7 Ultimate 64 Bit
Benchmark Scores 3DMark 11 6532
Glad you solved it..:)..which mb do you have in mind..
I use one of these to double check my cpu temps...i stick. The probe on my heatsink..
3,603 (1.06/day)
Oregon, USA
System Name GLaDOS
Storage 3 WD 1TB
Purchased a ASUS Sabertooth 990 FX as a replacement. It's working awesome so far!
3,800 (5.82/day)
Poland
System Name skurwiel szatan
Processor i7 5775c @4.3GHz/1.385v/EDRAM @2GHz
Motherboard Z97X Gaming 5
Cooling Noctua D15S
Memory Crucial Ballistix Tactical LP 1600 CL8 @2133 CL8
Video Card(s) MSI GTX 1080 Ti Gaming X Trio 2GHz
Storage SU900 128 (OS)/850 PRO 256+256+ 512,860 EVO 500,XPG SX950U 480 (games)/4TB of external HDDs (3+1)
Display(s) Acer XB241YU+Dell S2716DG dual monitor setup
Case Full tower
Audio Device(s) Mad Catz FREQ wireless
Mouse G403 wireless + Steelseries DeX + Roccat rest
Keyboard Razer Deathstalker
Benchmark Scores A LOT
Exactly.
If you ask me, you should've bught a new cpu instead of a new h80i and use the box cooler for now.
3,603 (1.06/day)
Oregon, USA
System Name GLaDOS
Storage 3 WD 1TB
Exactly.
CPU wasn't the issue. It was the motherboard.
3,800 (5.82/day)
Poland
Cooling Noctua D15S
Case Full tower
time for upgrade anyway ;)
1,227 (0.42/day)
Greece
Processor AMD FX-8350 4GHz@1.3V
Motherboard Gigabyte GA-970A UD3 Rev3.0
Cooling Zalman CNPS5X Performa
Memory 2*4GB Patriot Venom RED DDR3 1600MHz CL9
Video Card(s) XFX RX580 GTS 4GB
Storage Sandisk SSD 120GB, 2 Samsung F1 & F3 (1TB)
Display(s) LG IPS235
Case Zalman Neo Z9 Black
Audio Device(s) Via 7.1 onboard
Power Supply OCZ Z550
Mouse Zalman ZM-M401R
Keyboard Trust GXT280
Software Win 7 sp1 64bit
Benchmark Scores CB R15 64bit: single core 99p, multicore 647p WPrime 1.55 (8 cores): 9.0 secs
Most possibly the sensor had failed then. Have fun with the Sabertooth now.
397 (0.52/day)
Processor AMD Ryzen 1700X 8-Core 3.4Ghz
Motherboard ASRock X370 Taichi
Cooling Thermalright Le Grand Macho RT, 2x front Aerocool DS 140mm fans, 1x rear Aerocool DS 140mm fan
Memory 16GB G.Skill Flare X DDR4 3200Mhz
Video Card(s) PowerColor Red Devil Vega 64
Storage Samsung 960 Evo 500GB NVME SSD - Boot drive, Samsung 850 Evo 1TB SSD - Main storage
Display(s) Acer XG270HU Red 27" 1ms 144HZ WQHD 2K FreeSync Gaming Monitor
Case Fractal Design Define R6 USB C-Type Blackout Edition (Non TG)
Audio Device(s) Sennheiser GSP 301 Headset, Sennheiser Game Zero Special Edition Headset, Logitech Z623 System
Power Supply Seasonic AirTouch 850w 80 Plus Gold
Mouse SteelSeries Rival
Keyboard Razer Ornata Chroma
Software Windows 10 Professional 64bit
First of all, long time no see for those of you who remember me. Been busy with work and haven't had much time for hobbies.
So here's my issue. My AMD FX 8350 is supposedly overheating according to the motherboard temperature readings. I noticed this recently after my system hard locked while playing State Of Decay 2, and was able to reproduce that with heavyload just stress testing the CPU. Currently idle temp is 65*C and I've seen up to 80*C during testing. I thought maybe it was thermal paste at first, but replacing it did not alleviate the issue. I then replaced my old Corsair H50 with a new H80i. Still the same temps. I did notice that the coolant temps according to corsair link is in the 33*C-35*C range during testing.
I'm starting to wonder if the CPU itself is dying or if the overheat shutoff is kicking in and the temperature is reading incorrectly.
Thoughts?
Slap a Thermalright Le Grand Macho RT on it- problem solved! :)
26,256 (6.05/day)
His msi board was crap, got a Sabertooth. Problem solved.
I have the Ashura Cooler on mine, ticks at 5.0GHz stable.
397 (0.52/day)
I miss the Sabertooth line, come on Asus bring it back!
26,256 (6.05/day)
3,800 (5.82/day)
Poland
Cooling Noctua D15S
Case Full tower
Idk when they went low quality but it was certainly after the 990FX board...
since z270, they launched z270 tuf mark 1 enthusiast and z270 tuf mark 2 which was tuf in name only.
397 (0.52/day)
26,256 (6.05/day)
Yeah that whole lineup went to hell :(
Basically what was happening is that people were getting the same performance if not better and reliability and stability out of theTUF lineup for Less than people were paying for the ROG Line up so they got greedy and decided to start putting lower-quality Parts on the tuf series
3,603 (1.06/day)
Oregon, USA
System Name GLaDOS
Storage 3 WD 1TB
Not kidding this was the 2nd RMA replacement of that MSI motherboard. The ASUS board is working beautifully however. :D
790 (0.71/day)
System Name BOX
Processor Xeon E5-1680 v2 @ 4,3GHz
Motherboard Sabertooth X79 (BIOS 4801 + NVMe mod + uCode update)
Cooling Thermalright Venomous-X (w/LGA 2011 kit) + 2x Delta PWM Push-Pull
Memory 8x A-Data Xtreme 2000X 2GB (1868MHz CL8.9.8.24 CR2T @ 1,65V)
Video Card(s) ASUS GTX 1080 (FE)
Storage Samsung SM961 256GB NVMe, RAID0 2x WD10EZEX (1TB), HGST HUS726060ALE610 (6TB)
Display(s) Samsung T240
Case NZXT Tempest (Nanoflux/PWM fans only, some w/LEDs)
Audio Device(s) ASUS Essence ST Deluxe 7.1
Mouse Roccat Savu
Keyboard Logitech UltraXPremium
Benchmark Scores https://www.passmark.com/baselines/V9/display.php?id=108080818886
I think VRM was overheating...
If VRM doesn't have it's own sensor available in AIDA64/HWInfo - you simply get a shut down.
