So which is it ? Title ans post say 2 different things .....
Power 3 1070 Tis
or \
Adding three 1070s ... adding them to what ?
If we go by NVidia''s public specs:
https://www.nvidia.com/en-us/geforce/products/10series/geforce-gtx-1070-ti/
Thermal and Power Specs:
Maximum GPU Temperature (in C) = 94
WGraphics Card Power (W) = 180
Recommended System Power (W) = 500
Supplementary Power Connectors = 8 pin
You'll need 500 for the system and 1st card + 2 x 180 watts or 860. If anything is overclocked, that will drive wattage up.
Looking at the EVGA model tested by TPU, it peaked at 204 watts in gaming and 210 watts under zFurmark ... MSI Afterburner allows up to an increase on the power limit when overclocking so if going that route ... you have a theretical 280 watts max per card (840 watts for the cards alone) , or 100 watts additional per card... or 1060 ***theoretical*** overclocked and gaming. Mining shouldn't bring you anywhere near that ... Id want an 850 (for up to 675 watts of real load). I use the common rule of thumb of 1.25 times max power draw for light - medium duty and 1.5 times fpor serious overclocking / gaming boxes
However, might be worth considering that PSUs are most effecient at 50% power, so you don't want to be mining 24/7 if your are in countries with high electric rates.. In India, reported average electric cost was $0.08 per kw hr in 2017 which is pretty good .... in some areas of Inbdia tho, it's double that..... Let's do worse case @ $0.16 which still isn't so bad.
Let's examine two scenarios
0.600 kilowatts x 24 hours x 365 days x 3 years x $0.16 = $2,523 at 100% effieciency
650 watt Platinum PSU w/ 600 watt load ... (90.5% efficient)
At 90.5& efficiency this cost is $2,787.71
1050 watt Platinum PSU w/ 600 watt load ... (93.5% efficient)
At 93.5& efficiency this cost is $2,698.27
So the savings is about $90 for getting the bigger, quieter PSU.
In short, if you can pay $90 more for a 1050 watter, it works .. pay now for the more expensive PSU or pay later to the electric comapany . If ya lived in Germany where average cost is double that, buying the bigger PSU makes sense . It will also run quieter, have loads of headroom which should deliver longer life as well as provide plenty of room for future expansion. I'd do a 850, but a 650 w/ three 8 pin power cables would work
A Seasonic X650 Gold has (4) 6+ 2 Pins
EVGA 650 P2 has (2) 8-pins and (2) 6+2 pins
A Corsair CX650M w/ (2) 6+2 pins just isn't gonna cut it
Obviously the bigger PSUs in these series will be capable of doing the job but more efficiently, quieter and at lower electric cost ... You will have to run your own numbers to see if that costs offsets the difference in purchase price.
