Temp problem? Or something normal?
58 (0.05/day)
CPU temp is 76c while gaming with fans spinning at 1022 rpm
GPU temp is 75c while gaming with fans spinning at 2972 rpm
RAM temp is 56c while gaming (heatsinkless ddr3)
(Temps measured using hwmonitor)
Specs:
I7 3770
Cooler master hyper 212 led turbo
2x8gb Samsung ddr3 1600mhz(heatsinkless, stock clocks)
XFX RX 470 4gb
120mm fan from the front as intake and a rear 80mm fan as an exhaust
(Keep in mind that I had the side panel off with a house fan blowing air directly into the case)
Ambient temp: 33.1c
AMF
720 (0.49/day)
USA
System Name MR T System price $2464
Processor Ryzen 9 3900x 325$ 4.725Ghz boost pbo +50+75 enhance .1875.-+offset auto voltage -.2500 offset soc
Motherboard ROG STRIX X570-E Gaming $ 125 open box
Cooling 280mm ARCTIC FREEZER II idle temps 25c cpu 28c cpu diode 20c vrm 25c motherboard b stock 60$
Memory 2x 16GB Dual rank G Skill Trident Z Neo F4-3600C16-16GTZNC @3800 1.405v 16-19-16-19-35-54-1T $96
Video Card(s) Asrock RX 6950XT Oc formula 705$ pcie4x16 2599 min 2699mhz 2799boost 1110v 2392mhz mem 19GB/s
Storage 500 GB WD SN850 PCI-E 4.0x4 85$ pcie 4.0x4
Display(s) Vizio M50QXM-K01 4k@120hz 2.5k 120hz 2k@240hz $448
Case Cougar Panzer Max G Full Tower Tempered Glass 150$
Audio Device(s) Vzio M51a 5.1 Soundbar Dolby Atmos goodwill 45$!!!!
Power Supply Seasonic SS-1250XM2 Bought in 2013 350$ 11 y/o hasnt lost any voltage or watts
Mouse Perixx eRGO wireless Trackball 25$ 2000dpi
Keyboard Corsair K57 50$
VR HMD Dont give a damn about vr
Software win 11 pro modded by me no ai no remote connections free hehe
Benchmark Scores 8188 multi 540 single cinebench r20
Specs:
I7 3770
XFX RX 470 4gb
Ambient temp: 33.1c
seems like u need a higher airflow case with a lot better fans.......... but that ambient room temp is quite hi so that seems about right im really surprised it isnt worse than that
58 (0.05/day)
Well the problem is this is an oem Fujitsu case(yes, an upgraded office PC) specifically the esprimo p910 so I really can't do anything about airflow.
I tried ziptying 1 80mm fan to the back and I can wedge another one in the front (80mm).
AMF
720 (0.49/day)
USA
whenver or if u do get to build a new pc just message me i can show you some really good hi flow cases and nice power supplies ..... and yes a shitty psu will make things run warmer sometimes
but it wont matter anyways if u cant get your room temp down.... honestly 91 f is roasting my balls would be sweating
freeagent
10,391 (4.30/day)
Winnipeg, Canada
Cooling Thermalright Phantom Spirit 120 EVO, 2x T30
Memory 2x 16GB Lexar Ares @ 6400 28-36-36-68 1.55v
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
33c ambient is gross. Its like trying to cool your PC with hot breath :twitch:
  • Like
Reactions: Lei
2,373 (0.55/day)
Audio Device(s) A LOT
Gonna have to rip out those drive bays, tear that plastic front panel off and start drilling :eek:
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Specs:
I7 3770
XFX RX 470 4gb
Ambient temp: 33.1c
They're all hot, and right on the edge of when those devices lose performance due to thermal throttling.
if you need the side panel off and it STILL got that hot, it implies the thermal paste is no good.
Make sure they've got a good application of new thermal paste, clean dust out of heatsinks and fans and make sure your case airflow actually flows, front to back and bottom to top
These are not high wattage parts, they shouldn't get that hot. 3770's could run as low as 50c on basic cooling at full load.
post a photo of the system, without that desk fan in the way. Using that just proves somethings wrong, and you're forcing dust into the heatsinks bypassing the cases filters.
If your cases layout is similar to the the 910-L then you can add a front and rear fan
2,373 (0.55/day)
Gotta read the thread my guy
Lei
1,143 (0.82/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
If your ambient was 25, all other temps would be fine.
May be you should start cooling yourself first before your PC
Chilling Chill Out GIF by La Guarimba Film Festival
631 (0.54/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
Temps are as expected with that ambient temp. Should be able to get rid of the desk fan if you have a case with improved air flow and more fans. New thermal paste/pads might help a couple degrees. I would be surprised if you can find more than a few degrees better cooling performance.
58 (0.05/day)
I did repaste the CPU and GPU with the arctic mx5, issue still exists :(
Yes that's my case I added an 80mm delta fan(for airflow obviously) as an exhaust in the back and a deepcool rf 120 from the front, (the stock fan was either useless below 1800 rpm or too loud over that)
Lei
1,143 (0.82/day)
usually in my shirt
Yes that's my case I added an 80mm delta fan(for airflow obviously) as an exhaust in the back and a deepcool rf 120 fs from the front, (the stock fan was either useless below 1800 rpm or too loud over that)
Pictures of your case please...
8,312 (5.24/day)
São Paulo, Brazil
Cooling Pichau Lunara ARGB 360 + Honeywell PTM7950
Memory 32 GB G.Skill Trident Z5 RGB @ 7600 MT/s
Video Card(s) Palit GameRock GeForce RTX 5090 32 GB
Storage 500 GB WD Black SN750 + 4x 300 GB WD VelociRaptor WD3000HLFS HDDs
Display(s) 55-inch LG G3 OLED
Case Cooler Master MasterFrame 700 benchtable
Mouse Microsoft Classic IntelliMouse
Software Windows 10 Pro 22H2
With that ambient, your temps are great
But your case is cramped, the airflow setup is terrible, and you need to do cable management, you need to improve on that
18,584 (2.63/day)
System Name AlderLake
See if you can turn over the CPU cooler 90 degrees so the hot air gets blown out straight of the back of the PC.
58 (0.05/day)
I'll try to but keep in mind that there's almost no place for cable management
I can turn it but I'll have to place a piece (between the CPU heatsink and GPU) of paper to prevent the shortage but it doesn't seem righto_O
Lei
1,143 (0.82/day)
usually in my shirt
I'll post a better one later and btw it's upside down since the PSU doesn't lineup with the case
Also the CPU cooler is horizontal since I'm running the gpu in the upper pcie slot (pcie 3.0)
If I do make it vertical it'll short with the gpu
Place the PSU out of the case and change the front/back panel fan with something bigger like 14cm or 20cm.
Bigger fans make less noise and blow more air.
It's counter intuitive, but in fact the smaller the fan the more noise it makes and yields less airflow.
Just as a laptop has its power brick outside of its body, you can have your PSU outside the case box.
Why? Doesn't turning the cpu fan make the gpu and cpu further away? (Oh I see, 90° :D understood)
Is there piece of paper between your gpu and hard disk? .... Place the hard disk outside of case too. You can get a cheap hdd bracket and put your hdd on top of the case (on the roof not the below the ceiling)
So to get better airflow, it would be buying a bigger case, bigger fans, and perhaps AIO cooler for cpu. But to spend less you can try placing psu and hdd outside of case and get a 14cm fan.
In your scenario, both cpu and gpu are trying to suck air from vacuum. They're competing for air that doesn't exist.
Oh, the legend of 90°
Your psu and cpu are also vacuuming the air.
Buying a bigger case is the official FIFA solution.
By placing psu outside the case you can reduce air sucking competition and deliver more from front/back by using bigger intake/exhaust fans.
Although your temps would be fine if ambient was standard, nevertheless you have the most unfit type of cpu cooler for this tangled case.
freedom GIF
Let's look at it this way: you don't have a small case, you have a fat mini PC. And your temps are better than all laptops. So cheers :toast:
8,312 (5.24/day)
São Paulo, Brazil
Lots of cable ties and some smart cable placement does wonders, even if they can't be hidden, they can be put aside to minimize obstruction :D
  • Like
Reactions: Lei
2,373 (0.55/day)
Another option is to flip your fans to exhaust. Negative pressure works pretty well with high ambients ime
58 (0.05/day)
freedom GIF
I can't mount a 140mm fan
Case width is 138mm
And I can mount a 120mm aio max
Mussels
58,412 (7.78/day)
Oystralia
I had to rotate that image to make sense of what i was seeing
Whats with the giant metal shield blocking all front air intake to the GPU and CPU? That's going to force any intake air down into the hard drive(s)
We cant see how those fans are oriented, or if they're obstructed - a better angle would help a lot
remember that intakes and exhausts do nothing with the side panel off, they just suck outside air outside - it has to be enclosed to guide it over components
Tidy up loose cables, those cases have mounting places for them. Excess cables can be stuffed into an unused DVD or floppy bay and tied there.
You may have places to put them you're simply unaware of, that we can explain with a better image
I'm pretty sure you have that SATA HDD In backwards, the cases like that i've seen the power and SATA cables go at the rear of the drive - and thats why you have the cables in the way
